Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 07-09-2012, 02:28 PM   #1
302aod
Grenade Inspector
Default Bondo dries quick
I'm having trouble with Bondo. After replacing rusted out metal in my 64 F100, the bondo I'm using to smooth it out, dries after a couple minutes. So dry that it won't spread. Do they make any slow drying hardener?
offline   Reply With Quote
Old 07-09-2012, 02:29 PM   #2
rick3658
Grenade Inspector
Default Re: Bondo dries quick
put in less hardner and that will give you more time
Old 07-09-2012, 02:33 PM   #3
drjones96
Senior Member
drjones96's Avatar
Experiment a little on something that doesn't matter.
...you also don't have to use the whole tube of hardener all at once.
__________________
"I still consider the small block Chevrolet the most important motor ever created." - Ryan
Old 07-09-2012, 02:33 PM   #4
slddnmatt
Old School HAMBer
slddnmatt's Avatar
There's a happy medium if you put to little in it it won't harden correctly and you'll have to do it again.. when its hot you just have to be very quick!!
__________________
Quit dreaming and just build it already...
Townsends Customs & Hotrods
951-833-1835
Old 07-09-2012, 02:35 PM   #5
Irishman
Grenade Inspector
Irishman's Avatar
I had a similar issue with fibreglass resin. I dumped a whole tube of hardener into it. I thought I had a plastic container full of thermite!
And, yes, I was drunk.
Old 07-09-2012, 02:36 PM   #6
stainlesssteelrat
stainlesssteelrat's Avatar
lead is better.
__________________
Who you tryin' to get crazy with ese?
Don't you know I'm loco?
Old 07-09-2012, 02:37 PM   #7
drjones96
Senior Member
drjones96's Avatar
Quote:
Originally Posted by stainlesssteelrat View Post
lead is better.
well yeah...
...if you know how to lead....
__________________
Old 07-09-2012, 02:39 PM   #8
chaos10meter
Senior Member
chaos10meter's Avatar
Had an old body shop guy tell me to add a couple drops of fiberglass hardener to the Bondo mix .
He said it will keep it open a bit longer & give a little more work time ?
__________________
I love walks on the beach, fine wine & poking dead things with a stick
"Silent City Stockers"
Old 07-09-2012, 02:45 PM   #9
prewarcars4me
Senior Member
prewarcars4me's Avatar
Do it in the shade helps too. Sunlight changes the time.
__________________
Some of you guys are so tight with your money, I bet you can stretch a penny to wire your car.
Old 07-09-2012, 02:45 PM   #10
stainlesssteelrat
Quote:
Originally Posted by drjones96 View Post
well yeah...
could you think of a better time to learn?
__________________
Old 07-09-2012, 02:48 PM   #11
302aod
Grenade Inspector
I'm inside my shop, but it's hot in there. I'll use less hardiner next time, thanks guys.
Old 07-09-2012, 02:56 PM   #12
FlyFisher
Alliance Member
FlyFisher's Avatar
Default
Adding the hardener makes a chemical reaction that happens faster as the temperature goes up. Try less hardener in high temps but make sure it is completely blended or it will not set up.
__________________
Gold Chainers CC, Dallas Texas,
"Beer is living proof that God loves us and wants us to be happy." - -- Benjamin Franklin
Old 07-09-2012, 02:58 PM   #13
pitman
Old School HAMBer
pitman's Avatar
Quote: lead is better.
Bondo fumes are sweeter...I used to think.
Wait a minute!
Old 07-09-2012, 02:59 PM   #14
prewarcars4me
Senior Member
lead is better.
Go teach him
__________________
Old 07-09-2012, 03:15 PM   #15
Rhinodaddy
Newbie
Rhinodaddy's Avatar
It's hotter out, so the inital hardening is going to kick in faster. As was mentioned above, the bondo gets hot anyway, but you're starting out at a hotter temp to begin with during the summer, so the hardening kicks in quicker. Figure every 20 degrees over 70 F is going to make the bondo cure twice as fast as what is listed on the can.
Old 07-09-2012, 03:19 PM   #16
Carl La Fong
Senior Member
Carl La Fong's Avatar
Uhhhh, in moderate weather, bondo is supposed kick off in a couple of minutes. If you're having problems getting it smooth enough, before it gets too stiff, you need to work on your technique. Spread it as smooth as you can, wait for it to get hard enough to cheese grate, shape it with the grater, allow it to fully harden and hit it with your longboard
Old 07-09-2012, 03:19 PM   #17
Reman
Grenade Inspector
As already stated in different words.....Two things determine the set up time with bondo, amount of hardner and ambient temperature. Adjust one or the other and it will work correctly.
Old 07-09-2012, 03:24 PM   #18
Model T1
Senior Member
Model T1's Avatar
Quote:
It's actually too hot to use bondo right now. Use a fan and stay in the shade, as you say, inside. Try mixing smaller batches using only a spot of hardener then work up to maybe golfball sized gobs of Bondo and a 1/2" ribbon of hardener.
Do it early morning or later in the evening till the weather cools down.
__________________
Model T--Denny
Life is too serious to always be serious.
Old 07-09-2012, 03:27 PM   #19
belair
Old School HAMBer
belair's Avatar
Quote:
Wait a minute!
Gasoline too, as I remember.
Did I say that?
__________________
Every knee will bow
H.A.M.B. Chapel
322 Naihead and complete stick set-up for sale
Old 07-09-2012, 03:28 PM   #20
Model T1
Senior Member
Model T1's Avatar
Quote:
It's too damned hot to mow the yard. I'm sure not about to use Bondo here in Floriduuuh.
You can tell by most of our answers we've used way too much bondo and other fume producing things.
__________________
Model T--Denny
Old 07-09-2012, 03:38 PM   #21
Old School HAMBer
squirrel's Avatar
I try to do my bodywork in the spring....
__________________
Jim Forbes
my shtuff
Old 07-09-2012, 03:45 PM   #22
29moonshine
yea but in the winter it takes to much beer waiting for it to set up
Old 07-09-2012, 03:51 PM   #23
Dennis D
Grenade Inspector
Quote:
I keep my bondo and hardener in the house where the ac is on until I need to use it. Helps a bit. Dennis D
Old 07-09-2012, 03:53 PM   #24
larry k
Alliance Member
Sneek in the kitchen while your wife ain't lookin and put that gallon of mud in the refer ,not the freezer ! With lid on of course, when you wake up ,itt'l work slow as winter, cause, well, it thinks it is winter ?
Old 07-09-2012, 03:54 PM   #25
drjones96
Senior Member
drjones96's Avatar
no time like the present I suppose.
__________________
Old 07-09-2012, 04:15 PM   #26
Mopar Jack
Senior Member
Mopar Jack's Avatar
Yal,what they said...
Old 07-09-2012, 04:43 PM   #27
davidbistolas
Alliance Member
davidbistolas's Avatar
Do you mean fiberglass resin, and not hardener?
Old 07-09-2012, 04:48 PM   #28
mj40's
Old School HAMBer
mj40's's Avatar
Too damn hot to work at all in Boise today. 108°
__________________
Wife gave me an S U V birthday present"."Yup. Socks, Underwear and Viagra!"
WWW.USRI.ORG
Old 07-09-2012, 05:12 PM   #29
Model T1
Senior Member
Model T1's Avatar
I fail to see the problem here !
__________________
Model T--Denny
Old 07-09-2012, 05:50 PM   #30
Reman
Grenade Inspector
LOL. Yeah, I am in nw Floriduuh too. And yep, its hot.
Old 07-09-2012, 06:11 PM   #31
Ob1
Grenade Inspector
Evercoat Quantum has hot and cold hardeners.
Old 07-09-2012, 06:21 PM   #32
blinddaddykarno
Grenade Inspector
Have you been dating my ex-wife!!!!!!!!!!!
Old 07-09-2012, 07:00 PM   #33
pro 39
Newbie
pro 39's Avatar
2% by volume is all that is needed for hardener.
Old 07-09-2012, 07:33 PM   #34
RagtopRides
No offense intended. People have touched on it but never really said it... Bondo does not "dry", it cures. Two very different things.
Old 07-09-2012, 07:41 PM   #35
BORRACHO13
Alliance Member
BORRACHO13's Avatar
i worked at a body shop once and the guys were putting what they called 'honey' in the bondo mix. i do not know what exactly it was but i was told that you put some in there in order to keep the bondo from drying in hot weather. the hotter it was the more they used in the mix and vise versa when it was not hot they did nt even have to put any in. cant remember the name but they call it 'honey'.. looked syrupy like honey and came in can
Old 07-09-2012, 07:45 PM   #36
BORRACHO13
Alliance Member
BORRACHO13's Avatar
maybe thats what i mean lol...
Old 07-09-2012, 09:21 PM   #37
Rusty O'Toole
Old School HAMBer
Good advice to work in the shade or out of the sun, and to use less hardener. Also do a smaller amount of fill, like one dent at a time. It only takes a minute to file the bondo down if you catch it at just the right time. As long as you don't put on too large of an area.
Old 07-09-2012, 09:39 PM   #38
threedudesracing
Grenade Inspector
threedudesracing's Avatar
The "Honey" they were referring to is actually labled as a bondo thinner,believe it's actually fibre glass resin,looks,smells and tastes like it !!!! It will give you a little more work time plus will spread easier,provided you decrease your hardener somewhat. If you think your filler is trying too fast. Wait till you use your glazing putty,drys twice as fast as your filler does. I've had better luck using either one early early in the morning or later in the evening when it cools down a bunch.
Old 07-09-2012, 09:50 PM   #39
BORRACHO13
Alliance Member
BORRACHO13's Avatar
That sounds about right... Resin, it works great to help it from curing and to spread much more evenly
Old 07-09-2012, 10:11 PM   #40
K13
Alliance Member
K13's Avatar
As has been mentioned Evercoat makes a filler (Quantum) that has different speed hardeners. The slow one gives you twice as much working time as regular hardeners at any given temperature and as an added bonus it sands about twice as fast.
Old 07-09-2012, 10:29 PM   #41
flatheadhero
Grenade Inspector
flatheadhero's Avatar
The rule is, squeeze one stripe of hardner the width of, or across your blob of filler. mix it in.
Old 07-09-2012, 10:31 PM   #42
swissmike
Senior Member
Don't vary the amount of hardener! It will result in incompletely catalized filler.
__________________
HAMB Merc Club Member #394
WANTED: steel flywheel for 331 Caddy
Old 07-09-2012, 10:54 PM   #43
plodge55aqua
Senior Member
plodge55aqua's Avatar
Just dont mix it with your hands... .. I seen a guy do that once up here... a whole gallon in a wash Bucket with the hardner applied..
__________________
I live in the Never Finished CITY..
Old 07-10-2012, 01:17 AM   #44
davidbistolas
Alliance Member
Quote:
I've added it to improve 'flow'... it does cure slower too.
Old 07-10-2012, 11:38 AM   #45
Dave Zapatka
Newbie
Quote:
This works Great ! 20% slower Good Luck !
Old 07-11-2012, 02:05 PM   #46
302aod
Grenade Inspector
Using less hardener worked great. Mine cures with air bubbles in it when you sand it, then you have to spread some more to finish the job. Any fixes for this? Thanks and I've learned a lot on here.
Old 07-11-2012, 02:57 PM   #47
40FordGuy
Senior Member
If it's too hot to use Bondo,..it's too hot to be working anyway...Retreat to the airconditioned climes of the house ! (It's 99 here, at the moment)
4TTRUK
Old 07-11-2012, 06:21 PM   #48
K13
Alliance Member
K13's Avatar
More pressure when you are applying the product. Really push the first swipe into the metal. You still may be using too much hardener. What you are getting are called pinholes and the number one cause of them is too much hardener as the chemical reaction heats up the air that is trapped in the filler and causes it to expand and then your filler cures too quickly and traps the air.
Old 07-12-2012, 06:38 AM   #49
chopolds
Old School HAMBer
chopolds's Avatar
The way you mix it can make pinholes, as well. Don't "stir" it. Fold it onto itself, constantly scraping the bottom, and putting it on top, and pushing down and across.
If you get my drift!
__________________
Finished The Kart
Proud Member: Gold Chainers CC
Old 07-22-2012, 07:11 PM   #50
BORRACHO13
Alliance Member
BORRACHO13's Avatar
That's the best way I know how.. Works every time
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
