Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 07-07-2012, 08:47 PM   #1
Tattedkat
Grenade Inspector
Tattedkat's Avatar
Default Can You Weld In Holes On a Steering U-Joint?
Trusted a Helper Friend of Mine To BARELY Drill Out The Misaligned Holes on My Smaller Steering U Joint. He Made a MESS! Now Its Either By a New One for Like $50! Or Weld The Holes Up, Smooth out, And Redrill THE CORRECT WAY so that the Pin Will Fit. Is It Possible to Weld on The Smaller Steering UJ's, Or Am I just Gonna Have To Fork The Cash over and Buy a New one? Thanks.
P.S. Its a 3/4" DD to a 3/4" Round Smooth, No Splines.
Click image for larger version
offline   Reply With Quote
Old 07-07-2012, 08:54 PM   #2
F&J
Old School HAMBer
Default Re: Can You Weld In Holes On a Steering U-Joint?
If it is steel, not iron, I'd weld it for sure. These days with all the crappy parts, it might be cast iron?
Mig welding will leave a hardened spot, but a new sharp chainsaw file works nice to dress out the hole, if you just weld part of it up.
Wet a rag and wind it through the joint X to keep the heat away from the joint cups.
Old 07-07-2012, 09:06 PM   #3
nailhead29A
Alliance Member
nailhead29A's Avatar
If its a good quality joint it will be forged or machined from billet so tap a peice of brass the same size as the steering shaft into where the steering shaft fits to avoid having to try and file the inside of the hole , then Just quietly weld it up with the mig, a little at a time to keep the heat down and avoid shagging the u-joint, pull out the brass plug,clean up and redrill.
Old 07-07-2012, 09:08 PM   #4
kscarguy
kscarguy's Avatar
If it is on the DD side of the joint, you might consider inserting the DD shaft into the joint and making plug welds. I've welded steering joints to the shafts on several cars with thousands of miles and no issues. You want good weld penatration, but also want to avoid overheating the bearings. I fully agree with wrapping it with a wet rag. Let it cool slowly.
Old 07-07-2012, 09:11 PM   #5
kscarguy
kscarguy's Avatar
My advice...don't let your friend work on your brakes.
Old 07-07-2012, 09:11 PM   #6
Phil1934
Senior Member
Phil1934's Avatar
Why not drill a new hole 90 degrees from that?
Old 07-07-2012, 09:15 PM   #7
RodStRace
Senior Member
RodStRace's Avatar
Go over to your trusted friend. Remove 50 bucks from him.
This way there are 2 lessons learned:
1. You don't trust him with your life
2. He doesn't eff up parts
__________________
don't carve out a wooden wrench just 'cause it will be lighter and you have the wood on hand.
Old 07-07-2012, 09:17 PM   #8
Tattedkat
Grenade Inspector
Tattedkat's Avatar
I Could, But Wont It Look Shitty to The Eye with That big Ugly Hole?
Old 07-07-2012, 09:24 PM   #9
65standard
Grenade Inspector
65standard's Avatar
They look like weld on steering u-joints, so weld them on and forget about the bolts.
__________________
Tony Nicholas
online   Reply With Quote
Old 07-07-2012, 10:36 PM   #10
willie57
Grenade Inspector
willie57's Avatar
spend the money buy a new one. what is your life worth.
__________________
" when I die, I want to go peacefully like my Grandfather did, in his sleep--- not screaming like the passengers in his car."
Old 07-07-2012, 10:41 PM   #11
cjo13
Grenade Inspector
cjo13's Avatar
By the looks of it I would use the Wet Rag and weld it also.. Just make sure you have proper heat and penetration.
CJO13
__________________
Dad, You mean there was something other than a Chevy to Drive?
Old 07-08-2012, 12:54 AM   #12
Tattedkat
Grenade Inspector
Tattedkat's Avatar
After Some Research, Its A "Sweet" Brand Weld On 3/4" Smooth X 3/4" Smooth U-Joint. Although The Rod is a DD Shaped Rod, I Dont Think Ill Have a Problem After I Solidly Weld Both Pieces Together with a Flux Arc Stainless. Ill Keep It Cool at all times.
Old 07-08-2012, 01:41 AM   #13
Don's Hot Rods
Old School HAMBer
Don's Hot Rods's Avatar
Put your ground clamp on the side you are welding so current doesn't have to pass through the needle bearings.
Don
Old 07-08-2012, 01:59 AM   #14
Hellbentrodder
Grenade Inspector
Hellbentrodder's Avatar
Quote:
Why are you going to use stainless? Unless you have 309 ss, there is a good chance it will crack.
Old 07-08-2012, 02:02 AM   #15
Don's Hot Rods
Old School HAMBer
Even though you are welding it I would still drill a hole all the way through and put an appropriate sized roll pin in it just for giggles.
Don
Old 07-08-2012, 02:45 AM   #16
Tattedkat
Grenade Inspector
Tattedkat's Avatar
What About Manganese Hellbent?
Old 07-08-2012, 04:28 AM   #17
TUMBLEWEED GARAGE
Senior Member
TUMBLEWEED GARAGE's Avatar
If you are going to weld it, remove the u-joint. Keep the joint end as cool as possible. You won't have any problems.
__________________
Julie is home!!!!
Prospect, Goldchainers c.c.
Old 07-08-2012, 04:59 AM   #18
kaspar
Grenade Inspector
kaspar's Avatar
Put the u-joint in a bucket/cup of water and weld it, much easier than taking it apart. A friend tig-welded this Flaming River u-joint for me just the other day.
__________________
Lead Kings CC
Old 07-08-2012, 06:51 AM   #19
BRENT
Grenade Inspector
BRENT's Avatar
Like Phil1934 said!
I would drill it 90 degrees from your current location that is misaligned. I would then weld up the holes. Easy fix!
Brent
__________________
"OJO ROJO"
Old 07-08-2012, 07:03 AM   #20
oj
Alliance Member
oj's Avatar
Get a universal joint made for the double d shaft - they are not made to go together anyway esp if the holes are screwed.
The double d will come loose as there isn't anything for it to seat into and bite against. You could weld the universal to the shaft - as another has shown - only one side needs to be able to be disassembled.
__________________
'Molon Labe'
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
