Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 |
350/th350 combo need some advice on troubleshooting a bad idle . What happens is when the vehicle is put into drive the engine shakes and wants to die out imeadiatley? Changed out the plugs , wires, fuel filter, distrubuitor, and retimed everything but still seems to want to die out. Even changed out the th350 shift module. Maybe a a leak somewhere, wrong plugs(autolites 68)? Any suggestions would be helpful. The Carb is a 650 cfm eldebrock and this is a fenderless white truck in my avatar. I aint no stranger to the hamb and i would appreciate positive feedback please. And i know this subject has been brought up about a million on times on this forum, please just looking for help. Thanks.
__________________
don't tread on me |
#2 |
Old School HAMBer
You don't mention what cam you have. If it's a big en' you'll need a higher stall converter.
__________________
www.dickshotrodplace.com or www.dickshotrodcarbs.com Home of "spiral ribbed" engine eye candy & carbie central VERY PROUD TO HAVE KNOWN HAMB ANDY..................... |
#3 |
It's a regular stall as far as I know. But that is wanna my suspects that's it's going out?
__________________
don't tread on me |
#4 |
Old School HAMBer
Back-up. Has this combo been fine 'till now, or is this a recent build? Carb new, rebuilt or never tested 'till now?
__________________
Ryan supports small business and American values. Get's trolled. Awesome. -097 |
#5 |
Grenade Inspector
what is your idle set at
#6 |
Alliance Member
Sounds like you need a carb rebuild. Thats a best case scenario. Worst case is you have a burnt valve. Had that happen before. Has the same feel in a way. Hope this helps. Does it idle in park and neutral fine?
__________________
When in doubt, chop it |
#7 |
Grenade Inspector
When you set the timing did you disconnect the vacuum? If not, when you put it in gear vacuum drops, timing retards, and a stall.
#8 |
yes it does idle in park and neutral fine, but it has a slight pop/miss on the drivers side exhaust
__________________
don't tread on me |
#9 |
yes we did disconnect the vaccum when doing the timming, but it still has a drop in idle when shifting from park to drive
__________________
don't tread on me |
#10 |
#11 |
combo was fine 2months ago then recently took it to the machine shop for new seals due to some oil leaks, anyhow replaced the rear main oil seals and head gaskets and put a new double roller timing chain with and new oil pump , after we got it back to the shop we also got new plugs and wires but kept the same carb (elbrock 650 cfm) after getting all timed and ready to go the engine started running ruff with higher rpms and low idle or shutting off at stops. The machine shop did not notice any major signs of wear to anything upon or after replacing seals either. So could something have come loose like deposits? Bad rings? or Did we miss something?
__________________
don't tread on me |
#12 |
FNG
It sounds like mayb one of yr vaccume ports on yr carb is not plugged and should be. On my 302 same thing happen to me after steam washing it and ended up being I cracked a rubber plug on the carb that covers the port
#13 |
yea so far all signs point toward a leak, but we checked that one already thanks
__________________
don't tread on me |
#14 |
Senior Member
vacum leak..how did you check it...I had the same symptions once and found a leak under base of carb
#15 |
we sprayed carb cleaner at the base too and around the intake and heads to check for leaks and thus so far we did not see or hear any?
__________________
don't tread on me |
#16 |
Senior Member
Maybe this is where you have a vacuum leak.
__________________
"Who's your Unkledaddy?" |
#17 |
Senior Member
well since the heads were off id look at valve adj., vacuum leaks, timing off carb needs work or adjustment.and seems you already have most covered but id check it all again.and where unkledaddy said.
#18 |
Senior Member
Valves ajusted too tight?
__________________
Get the early ones, they are thicker, more material to work with, less flex and better handling. |
#19 |
Grenade Inspector
adjust the idles speed up in drive
__________________
Wanted:30-31 Ford Pickup.(rear fenders) |
#20 |
Alliance Member
Could the torque converter be engaged? I had a trans start to go out and the torque converter wouldn't shut off, causing the motor to idle too low in drive and coming to a stop
#21 |
Alliance Member
They almost all have a drop in idle from park to drive. No one else has mentioned it yet so you may look for a vacumm leak. They happen.
__________________
If it don't make ya dirty it ain't yours No man crosses a chasm in two jumps |
#22 |
Old School HAMBer
The same thing happened to me with a Pontiac Slim Jim. The fluid coupler wouldn't disengage when I came to a stop and it killed the motor.
#23 |
yea the valves and torque converter are also gonna be checked as well, gonna try to adjust the rocker arms first and go from there.
__________________
don't tread on me |
#24 |
Alliance Member
I agree w/ porknbeaner, sounds like a vacuum leak to me
__________________
A real woodie would make me happy
#25 |
Newbie
If your getting a pop out of exhaust . Valve adjustment sounds too tight.
Remember loose is always better than too tight. |
#26 |
Alliance Member
I'd go along with ajmopar. Start with the simple fixes. Make sure you have the dizzy in right. Could be off a tooth. Readjust the valves. Not the plugs.
#27 |
Old School HAMBer
If all the other advice dont work, take your air cleaner off and try again.
Sometimes when an air cleaner has not been changed out it can impede air flow so badly that exactly what you are describing can occur. Just a shot in the dark if you have run out of options...
__________________
THE MORE YOU LEARN, THE MORE YOUR REALISE YOU DONT KNOW!
#28 | |
Quote:
__________________
don't tread on me |
#29 |
Senior Member
Let us know what the fix was.
__________________
#30 |
you probably did it first thing, but has the carb been tuned since you got the car back from the shop? idle speed set high enough? i'd eliminate that before i even started hunting for vacuum leaks.
#31 |
Well guys bad news. Turned out to be a burnt valve
Back to the machine shop.
__________________
don't tread on me |
#32 |
Alliance Member
Dang sorry to hear that. I know the feeling though. Just think of it this way, all the bad luck is getting out of your system now and not later
__________________
#33 | |
Senior Member
Quote:
Thanks for getting back and good luck with it.
__________________
#34 |
Alliance Member
How did the machine shop miss a burnt valve when doing head gaskets ext:
How was it running fine 2 months ago with a burnt valve but not now. Or did you just burn it trying to dial it in ? Does not compute .....
__________________
Thank you, I will be installing a breathalyzer on my keyboard the hamb relay network http://www.jalopyjournal.com/forum/g...hp?groupid=214 |
#35 |
Newbie
Quick valve job and your down the road.The "SHAKE" will be gone!!!!
#36 |
bad machine shop, will not disclose the details cuz im better than that but will use a more trusted ,recomnded shop in the near future!
__________________
don't tread on me |
#37 |
weak. sorry to hear that. but it could always be worse, i guess.
#38 |
Alliance Vendor
Get yourself access to a smoke machine and smoke it. I'll bet you got a vacuum leak.
__________________
Joe Germann www.MotorheadExtraordinaire.com Follow us on Twitter, Like us on Facebook American-made Storage, Workspace, and Workshop Gear Alliance Vendor, Special Discounts for H.A.M.B. Alliance Members |
| Thread Tools | |
| Display Modes | |
