Reply
Thread Tools Display Modes
Old 06-22-2012, 09:34 AM   #1
BOSTONCAMARO
Alliance Member
BOSTONCAMARO's Avatar
Default Source for New or Used 15 X 8 Chevy Plain Steel Wheels
I have heard people taking little known or 'rare' 15 X 8 wheels, stock steel wheels, not a rally wheel of any type (do they exist) off of Chevy and other GM Station Wagons and using them for drag tires etc, but really I am not sure what is out there.
Anyone know if you can get a plain steel 5 X 4 3/4 with a standard factory back spacing? Cragar makes something but I really want a stock look.
Let me know, thanks.
offline   Reply With Quote
Old 06-22-2012, 09:38 AM   #2
Old School HAMBer
squirrel's Avatar
Default Re: Source for New or Used 15 X 8 Chevy Plain Steel Wheels
I seem to recall looking in the Chevy car parts book from that era and not finding any listed. There are non-rally 6 lug wheels, used on some Blazers in the 80s.
__________________
Jim Forbes
my shtuff
Old 06-22-2012, 09:39 AM   #3
Waddayacare
I have mine made by a local "circle jerk" race shop. I just give him a stock GM 15" wheel, he cuts the centers out and welds them into a new hoop (rim) to whatever width you want. Mine are 14" wide and cost me $120.00 for the pair.
Old 06-22-2012, 09:43 AM   #4
Limey Kid
The widest I could find was 15 x 7. I bought a set, only to find they weren't wide enough! I found the only way was to put the centers into 8" rims. If you can use 7" wides, give me a call!!
Cheers,
Stewart.
Old 06-22-2012, 09:58 AM   #5
Alliance Member
Mr48chev's Avatar
The widest regular Chevy car steelies I have come across were the 15x7 that came on station wagons. I think my wife's old 1979 Chevy ex Texas highway patrol car had some fairly wide rims on it as it had the full 1979 cop car chassis under it.
If you had someone who could cut the centers out and swap them 15x8 pickup steelies are easy to find and fairly inexpensive around here. I think I even have a couple in my tire pile.
I looked in my old Hollander interchange but it only goes from 55 to 67 and doesn't show the later wider rims. If you can find a later interchange manual it might make hunting easier.
__________________
Happiness is having a garage big enough to hold all ttools and projects and small enough to keep warm enough to work in the winter.
online   Reply With Quote
Old 06-22-2012, 10:09 AM   #6
Waddayacare
Most, if not all '73-'77 GM "G" body cars used a 15x7 steel wheel unless it was some kind of rally or styled wheel.
Old 06-22-2012, 10:16 AM   #7
BOSTONCAMARO
Alliance Member
I like the idea of having the centers dropped into other rims, or have rims widened etc.
Any leads on companies online that do this or the shop near you that did yours?
thanks!
Old 06-22-2012, 10:56 AM   #8
Waddayacare
PM me!
Old 06-22-2012, 02:01 PM   #9
MISCONSTUDE
Grenade Inspector
MISCONSTUDE's Avatar
Bought 15x8 steel stockers new from summit or Jegs, don't remember which but its worth a look.
Old 06-22-2012, 11:07 PM   #10
NMCarNut
Alliance Member
NMCarNut's Avatar
As stated the widest 15" non-rally wheels are 7". If you want 8" stock style, Summit has the best prices I've seen, PN#WVI-62-5834044.
Old 06-23-2012, 09:01 AM   #11
metalman
Alliance Member
metalman's Avatar
I'd give Jimmy (wheelkid on here) at Rally America a call, he could build what you need.
Old 06-23-2012, 09:59 AM   #12
Old School HAMBer
squirrel's Avatar
Quote:
thanks for the link. That would probably look right with some dog dish hub caps...but the center is not quite the same as a Chevy wheel. So it wouldn't work for what I want to do.
__________________
Jim Forbes
my shtuff
Old 06-23-2012, 12:05 PM   #13
NMCarNut
Alliance Member
NMCarNut's Avatar
Quote:
You are correct, depending on which Chevy wheel you are trying to match the discs will be different. Then again, I'm not aware of any 8" rim being "correct" either. If there is a particular style you are seeking then about your only bet is getting someone to weld 8" rims on to the discs you desire.
Click image for larger version
Name:	15x7 Wheels.jpg
Old 06-23-2012, 12:19 PM   #14
metlmunchr
Grenade Inspector
Some 69 Corvettes came with 8" wheels and full wheel covers. Don't know whether they used a standard rally wheel under that wheel cover or not, but that'd be the only possibility I can think of that could have a 15X8 non-rally wheel as a stock wheel.
Old 06-23-2012, 12:24 PM   #15
Old School HAMBer
squirrel's Avatar
Then again, maybe it would be close enough. Here's the one I'm playing with, stock 55. The Wheel Vintiques looks like a pretty good copy.
__________________
Jim Forbes
my shtuff
Old 06-23-2012, 12:43 PM   #16
NMCarNut
Alliance Member
NMCarNut's Avatar
If I remember correctly they used a rally wheel painted black.
Old 06-26-2012, 10:33 AM   #17
BOSTONCAMARO
Alliance Member
NMCarNut that is what I am thinking, the factory looking wheel, which seems to be the exact wheel by Summit, I want something like that..in 8 inch wide.
Old 11-16-2012, 04:37 PM   #18
pickengrass
FNG
pickengrass's Avatar
I have a pair of these 8" plain steels that I run on the back of my 63. They are very hard to find and I wish I had a few more. I was told they came out on some early wagons.
Old 11-16-2012, 05:26 PM   #19
32 hudson
32 hudson's Avatar
Just a thought on backspacing. Does the 8" wheel use the same offset as the 7" oem wheel? What is the normal factory back spacing ?
Old 11-16-2012, 05:43 PM   #20
Deuce Roadster
Deuce Roadster's Avatar
A lot of rodders THINK they have a 8 inch rim because it measures 8 inches across the widest point ... but it is really a 7 inch rim.
Rims are 1 inch wider across than the real size because the measurement should be meaasured inside the rimes 1/2 off a inch off the bead.
__________________
"Whether you think that you can, or that you can't,
you are usually right." Henry Ford
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
