Reply
Thread Tools Display Modes
Old 06-17-2012, 08:09 PM   #1
Chester
Newbie
Default Camel Back Heads?
In the classified section of my club magazine I frequently see ads that reference camel back heads.
What exactly is a camel back head?
offline   Reply With Quote
Old 06-17-2012, 08:10 PM   #2
Gizzy
Gizzy's Avatar
Default Re: Camel Back Heads?
327 dbl humps,need a set?i have an extra pair
__________________
Mendon Mafia CC
Old 06-17-2012, 08:14 PM   #3
tommyd
Alliance Member
tommyd's Avatar
The heads have a couple of little humps in the casting near the deck surface. One chevy's early efforts to be cool like the Ford guys....didn't work......easy fellas' just yanking your chain!
__________________
When I grow up, to beeee heee a man. Will I dig the same things that turned me on as a kid? Will I look back and say, I wish I hadn't done what I did? B. Wilson.
Old 06-17-2012, 08:16 PM   #4
carcrazyjohn
Alliance Member
carcrazyjohn's Avatar
202 valves and the rears are Also I think came in 194 and 1.50 It just means bigger valves
Old 06-17-2012, 08:17 PM   #5
F&J
Old School HAMBer
Google image search: They came in 2 sizes of intake valves 2.02 and 1.94". These are the early heads from most of the 60s, without accessory holes in the ends of the heads.
Old 06-17-2012, 08:19 PM   #6
biscaynes
Senior Member
biscaynes's Avatar
casting mark on the ends of the cyl head, bigger valves, 1.94 or 2.02 intakes.
__________________
this space for rent
Old 06-19-2012, 01:35 PM   #7
Chester
Newbie
Thanks for the info.
Old 06-19-2012, 01:50 PM   #8
hotroddon
Old School HAMBer
hotroddon's Avatar
They are generally referred to as Camel Hump Heads, not camel "Back".
__________________
As I hurtled through space, one thought kept crossing my mind
every part of this rocket was supplied by the lowest bidder. ~ John Glenn
Old 06-19-2012, 01:59 PM   #9
nutajunka
Senior Member
Quote:
And double hump, they were also made with the acc. holes.
Old 06-19-2012, 02:03 PM   #10
49ratfink
Old School HAMBer
49ratfink's Avatar
Camel Hump heads are so cool a frind of mine milled Camel Humps in his aftermarket aluminum heads.
Old 06-19-2012, 02:04 PM   #11
porknbeaner
Alliance Member
porknbeaner's Avatar
Quote:
Yes later heads did come with accessory holes and were the same head otherwise.
__________________
If it don't make ya dirty it ain't yours
No man crosses a chasm in two jumps
Old 06-19-2012, 02:06 PM   #12
AG F/C
Grenade Inspector
AG F/C's Avatar
To add to the above mentioned, Many versions of Camel Hump heads were made. they were used on the upper HP SBC's say 327-250 and up. The heads for the most part flow better then the LOPO versions of the day. The small valve versions are very common 1.94-1.50 but can be machined for 2.02-1.60 as GM made them both ways for a given casting number The casting number will make or break the value EG a 461 as opposed to e 461X. If you find a set of 461X heads for a good price I'd grab them. Use the online casting number listings to see what you might be buying.
For a period Hot Rod the early 327 heads without holed in the front are a good place to start with for a "Belly Button" (SBC).
__________________
32 Hi boy
65 IH Scout
Old 06-19-2012, 02:37 PM   #13
Sweepspear
Grenade Inspector
Sweepspear's Avatar
And here I always thought it referred to heads shaped like these.
But, what do I know. I'm a Buick guy.
Learn something everyday I guess.
Click image for larger version
__________________
Start every day off with a smile and get it over with.
Old 06-19-2012, 02:37 PM   #14
mrconcdid
Senior Member
mrconcdid's Avatar
bottem line, they were the preformance head for there day.
camaros and corvettes had them.
I think they also came in 58 and 64 cc sizes with 2.02/1.60 valves
the later versions did have accessory holes in both ends.
Godspeed
MrC.
__________________
Check out my Artwork!
http://www.etsy.com/shop/DesignsbyLA..._shop_redirect
Old 06-19-2012, 02:38 PM   #15
chaos10meter
Senior Member
chaos10meter's Avatar
The marks are actually what's left of the in gates used to feed the molten metal into the part when pouring at the foundry
__________________
I love walks on the beach, fine wine & poking dead things with a stick
"Silent City Stockers"
Old 06-19-2012, 02:39 PM   #16
porknbeaner
Alliance Member
Just remember anything without a belly button is an alien.
The smaller combustion donot like the 2.02 valves real well, they will have to be unshrouded if you go that route.
Those are actually W heads, but it is an honest mistake. That is whay we congregate here to help us realize what it is that we know and what it is that we don't. I am forever running onto things that I thought that I knew and then found out that I didn't.
I have found good information when I can't remember here:
http://www.fastnuf.com/Headguide.html
__________________
Old 06-19-2012, 02:40 PM   #17
model A hooligan
Senior Member
model A hooligan's Avatar
how do you mistake a W head for just a camel head? haha
and camel heads are the ones that hold more water..duh!
__________________
The best i can with what i have.
Old 06-19-2012, 02:43 PM   #18
Second Amendment
Alliance Member
Second Amendment's Avatar
Also, Mickey Mouse heads.
__________________
Participating in a gun buy back program because you believe that the criminals have to many guns is like having yourself castrated because your believe that your neighbors have too many kids.
Old 06-19-2012, 03:21 PM   #19
davidbistolas
Alliance Member
davidbistolas's Avatar
What about Cameltoe heads?
Old 06-19-2012, 04:05 PM   #20
luckyuhaul
Grenade Inspector
luckyuhaul's Avatar
Prone to cracks!
Comes in lightweight or heavyweight versions, some access holes.
Early models not permitted, remember, pre - 1964.
__________________
LOL...Awesome...LOL...Awesome...LOL...Awesome..LOL
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
