Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 |
Alliance Member
Been working on the engine area of my 29. Would really like to see some pics and suggestions on what you all have done in regard to heater hoses on your open engine cars. Seems like the heater hoses are unhidable and just plain ugly!! Input please.
__________________
It's Not Just The Cars! It's A Lifestyle |
#2 |
Grenade Inspector
you could always bend some metal tubing with short pieces of hose on the ends and polish or powder coat the tubing. or even some polished copper tubing.
__________________
organgrinder- reggie |
#3 |
Alliance Member
Local shop owner had some fittings made up that used 3/8 hose for the heat hose. The hoses are easier to route because they are so much smaller. Using to aftermarket a/c units the heater cores are small. He has had very good results .
#4 |
Alliance Member
Galvanized pipe????
#5 |
Alliance Member
__________________
#6 | |
Alliance Member
Quote:
This is interesting. any pics by chance?
__________________
#7 |
Old School HAMBer
On my Shoebox, I wrapped all the hoses and vacuum lines in black cloth tape and used stainless clamps.
![]() BTW...this is an early pic. It now has the stainless clamps.
__________________
'Armin Tamzarian's reign of terror is over!' -Superintendent Chalmers Last edited by flatheadpete; 06-08-2012 at 07:35 AM. |
#8 |
Alliance Member
#9 |
Senior Member
Here's an idea.
__________________
"Who's your Unkledaddy?" |
#10 |
Alliance Member
#11 |
Old School HAMBer
As long as the hoses are run neatly they are not a visual problem. Necessity is necessity.
#12 |
Alliance Member
If it helps Dayco offers heater hoses that have a 90deg bend on one end, like Dayco# 80407 is a 5/8hose X 60" with a formed 90deg bend.
Google dayco and have a looksee.
__________________
'Molon Labe' |
#13 |
Grenade Inspector
Here's what i used for my 29 roadster. The copper tube works easy. The hoses are molded hoses form something that I bought in a swap meet and cut to fit.
#14 |
Grenade Inspector
Move further south. Problem solved!
__________________
Wanted: Coffman engine starter. A.K.A. - shotgun starter |
#15 |
Senior Member
i dont have pics of it because my buddy no longer has the car but he run his heater hose thru chrome shower rods. sounds ratr-- but it really looked good and he bent it to fit.
#16 |
Grenade Inspector
I dont have pics but I just did a truck for a customer and used 5/8 aluminum fuel line for the long runs and just connected it at each end with short pieces of regular 5/8 heater hose and hose clamps. The fuel line is easy to form in curves and is smaller in overall diameter so it fits in tight spaces well.
#17 |
Old School HAMBer
If you are building an old time hotrod just run them as neatly as possible using period hardware. Real hotrods have the necessary parts run cleanly. If you are building a streetrod then I have no clue what is the "hot setup"
__________________
Quote...You are hereby Knighted...'Sir Asseth of Hole' Tommy... 3W Larry. Quote...It's called "HOT RODDING", not paint by numbers. ![]() ...Fab32
#18 |
I don`t mind heater hoses,they don`t look offensive. I don`t like accordion rad hoses,Just me I guess.
__________________
Keep your stick on the ice
#19 |
Alliance Member
Heater hoses are ugly? What's next - fan belts????
__________________
"The problem with Liberalism is that eventually you run out of other people's money" -Margaret Thatcher |
#20 |
Alliance Member
| Thread Tools | |
| Display Modes | |
