Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#41 |
Grenade Inspector
still wondering about toploader style 3 speed from truck anyone??
__________________
Pete's Ponies Mustang RUSToration & Performance |
#42 |
Grenade Inspector
OK . . how about this?? What you see is a 2.0 Pinto engine bellhousing and a Jeep T90. Its short and the shifter comes out of the top. True, it is made to have a transfer case on the rear of the trans . but maybe??? Perhaps there is a similar trans for the 2wd Jeeps?? Like the postal Jeeps and such? Anyone heard of these being used?
![]() ![]() Found this . . . . A T96. Some versions had a floor shift right out of the top and easy to convert one to that way of shifting. http://www.jalopyjournal.com/forum/s....php?p=7110490
__________________
#43 |
Alliance Member
I see what you're saying with that trans, but if I was going to sadle myself with a three speed, I'd stick with a '39 Ford type topshift. No need to make it any harder to do than it has to be. But in going with the S10 5speed from a four wheel drive and one of Crazydaddio's adaptors, you end up with the shifter in the same place as what you show, an aluminum cased trans that is a bunch lighter, a closed driveline, but more importantly a nicely spaced collection of gears that will let this engine use it's power most efficiantly.
#44 |
Grenade Inspector
some of the adapters are just to much money, IMO.
__________________
#45 |
Old School HAMBer
Great thread, I just picked up a '28 Tudor with a 2.0, C4 and a chevy luv rear. This set-up is pretty doggy off the line and up any hill on the freeway. I was planning on going back to the banjo rear and poss a manual trans. I did score a header and the edelbrock 1x1 intake/carb combo for it though.
subscribed.
__________________
#1 Post killer |
#46 |
Old School HAMBer
Pete. that is one cool tranny, how did they ever fit a reverse in that thing?
Here: take a walk on the wild side. I used an M5 trans, w/20% overdrive 5th. http://www.jalopyjournal.com/forum/a...?albumid=19989 |
#47 | |
Alliance Member
Quote:
__________________
http://www.westcoastmetalshapers.com/forum |
#48 | |
Old School HAMBer
Quote:
__________________
#1 Post killer |
#49 | |
Alliance Member
Quote:
__________________
#50 |
Grenade Inspector
Anyone have any thoughts on this??
I think I have a plan and would like to know if you see a short fall to this. I will be mounting a later flat head type bellhousing ( like this : http://www.ebay.com/itm/flywheel-clu...a35e8c&vxp=mtr ) to my 2.0 Pinto engine. I will be doing this with a custom 3/8" steel plate I will make. It will bolt to the 2.0 and the bell will bolt to it. Then I will bolt a '32-up 3 speed to this bell. I will use a flywheel which matches that bell ( '49-'53) and drill it for the 2.0 crank. I'll have the balance done on flywheel. I will have to make I shaft to hold the pedals, but I have seen many that are available or that people have made. I will shorten the enclosed driveshaft as needed, but keep it closed and bolted to the transmission.This seems like it will work and give me the things I find important. The 3/8" plate will also be used for the engine mount as I will fab up mounts that use this plate as well. Seem like it will work??
__________________
#51 | |
Alliance Member
Quote:
__________________
#52 |
Grenade Inspector
like this . . .
__________________
#53 |
Senior Member
there should be info out there as it was a common replacement yrs ago ........
__________________
V4F "HOT IRONS" CC |
#54 |
Grenade Inspector
Steve, its common to install a '34 transmission onto a 2.0 Pinto??
__________________
#55 |
Senior Member
im not sure , but ive seen the auto & 4 speed used . the open drive shaft is an ez set-up . the motor will lay on its side a little . im not real familiar as i did not like the conversion . just my opion . ....... steve
__________________
#56 |
Senior Member
http://ahooga-archives.com/messages1/467.shtml .. try this for a start .........
__________________
#57 |
Grenade Inspector
If you read above, I have a plan. I want to use the closed drive shaft with a custom plate to mount the trans to the engine. Engine will sit straight up. From flywheek housing back, everything will look stock.
__________________
#58 |
Senior Member
ok , try the "shay" relica . it uses what you want to do .......
http://www.carsforsale.com/used_cars...into_118952658
__________________
#59 |
Grenade Inspector
Steve, we are not communicating. The Shay is not at all what I want.
__________________
#60 |
Grenade Inspector
i always thought a 2.3 with associated 5 spd manual behind it would make for a nice power plant/long distance cruiser set up, especially in an a or pickup.
| Thread Tools | |
| Display Modes | |
