Reply
Thread Tools Display Modes
Old 06-01-2012, 04:50 PM   #1
kscarguy
Senior Member
kscarguy's Avatar
Default How to build a VERY low budget 400 sbc
I want to "assemble" a low buck 400 SBC engine. It is going into my car hauler and I want to see if I can keep the price low and the fuel MPG high.
Any ideas on how to build it cheaply...yet make it run good?
Here is what I have to work with...
To start with, I have a running, stock 1973 Impala, 400 SBC motor (block 3951511) with stock heads (3973493). I also have a 80-85, 350 4 bolt main engine that is probably worn out (judging by the loose valves in the heads).
In addition to the stock 1973, 400 SBC heads, I have a set of rebuilt heads (333882) that have been completely rebuilt and have screw in studs. I also have a pair of new head gaskets.
In the intake area, the 400 came with a stock cast GM 4bbl intake with an EGR valve blocked off, I have available a Weiand 8004 quadrajet intake and an Edelbrock performer manifold.
Carb wise, I have a decent rebuilt quadrajet and a new AFB (600 or 650) to choose from. I also have the complete TBI injection setup off a 350 truck.
The Ignition system I have is a stock HEI.
The truck already has full length headers and dual exhaust.
Overall truck vehicle weight is around 7000# (guessing), motor should turn 2200 rpm at 70 mph, 4:11 gears and 33" tall tires, Trans is a 700R4.
Any way to assemble this mess into a good street motor that gets good MPG and yet keep the price really low? Or should I just run the 400 as a stocker?
I's like to keep the price of additional parts under $300. Anyone up to the challenge???
offline   Reply With Quote
Old 06-01-2012, 05:00 PM   #2
Kerrynzl
Default Re: How to build a VERY low budget 400 sbc
Put some 305 heads on it to get the compression up , they have small ports to get good velocity at the RPM you'll be using.
And get a good RV towing cam [ high lift but short duration ]
Everything in the short block can be stock [ buy a rebuild kit ]
What you're trying to do is get it to behave like a diesel engine [ really crisp down low ]
Old 06-01-2012, 05:05 PM   #3
31Vicky with a hemi
Alliance Member
31Vicky with a hemi's Avatar
I want a nymphomaniac with an oral fixation that owns a tequila factory.
Be lucky to see 10mpg empty with that rig.
Performer (not rpm) and a truck or RV cam should help.
__________________
Thank you, I will be installing a breathalyzer on my keyboard
the hamb relay network
http://www.jalopyjournal.com/forum/g...hp?groupid=214
Old 06-02-2012, 03:32 PM   #4
kscarguy
Senior Member
kscarguy's Avatar
Really, only two responses? Perhaps there aren't any motor builders on the HAMB who know how to build inexpensive motors for a daily driver...?
Old 06-02-2012, 04:05 PM   #5
Diavolo
Diavolo's Avatar
At the risk of keeping this thread alive, I will have to chime in and say there is no realistic way you are going to do what you want to accomplish with the amount of funds you want to spend. There are lots of options, but each one will cost a certain bare minimum of cash if you intend on doing it right and having anything even resembling a reliable machine when you are done.
If I had a thinner skin, I would be offended by your comment...
If $300 was all I intended to spend, I would fold the stack of bills and stuff them in my pocket and consider a less expensive hobby.
Old 06-02-2012, 04:18 PM   #6
aaggie
Alliance Member
A good gasket set and rings would eat up $300.
Old 06-02-2012, 04:25 PM   #7
LWT
Grenade Inspector
LWT's Avatar
Don't forget the steam holes in the stock 400 heads, if you use other heads they would need to be drilled. I would use the performer, afb, 400 heads, performer cam & call it good. The 400 is a great engine for what you are doing, it doesn't need anything fancy to work well.
__________________
Nothing's more certain than the defeat of a man who gives up, & I'll add, the victory of 1 who won't
Old 06-02-2012, 04:30 PM   #8
dave lewis
Alliance Member
dave lewis's Avatar
A set of stock vortec heads is a better choice....
smaller chambers,tall,narrow ports and high swirl chambers.
the proper intake from speedway (edelbrock vortec performer clone ) is about $ 150.
Use the cam that came with the engine if its in good shape,,,replace the timing gear set with a true roller set..make sure you advance the cam 4 degrees..(they are WAY retarded from the factory)
It will run unbelievably well..If you dial it in it should see 15 to 18 mpg...
Dave
__________________
Still ! Need a trunk lid for my 30 dodge dd 3 window...
PM me
online   Reply With Quote
Old 06-02-2012, 04:36 PM   #9
Turbo26T
Turbo26T's Avatar
This is one of the best threads written on getting power/MPG out of a 305.
Lotsa info here.....but , it ain't magic..it still won't stretch $300 dollars far enough to get all you want
All engines are cubic money, some more, some less..
http://www.jalopyjournal.com/forum/a...hp/t-1494.html
__________________
..There's no such thing as a "normal" Life..there's just ...Life.
Old 06-02-2012, 05:11 PM   #10
fourspeedwagon
fourspeedwagon's Avatar
KS- Make sure your cooling system is in top shape too. Lots of cracked 400s out there from overheating and those steam jackets aren't the greatest. Careful with the timing too- put some of that cheap ass AMPM gas in there with too much timing it'll die in no time.
Old 06-02-2012, 05:57 PM   #11
Engine man
Senior Member
The only way to do it for $300 would be if you had your own machine shop. Even then it might not be possible. You probably need to bore the block, new pistons, turn the crankshaft, valve job and a roller cam and lifters, cam bearings, rod and main bearings, valve job, align bore and you should recondition the rods. $3,000 would be closer.
__________________
Anything dropped while working on a vehicle will roll underneath to the exact center.
Old 06-02-2012, 06:02 PM   #12
marxjunk
Newbie
Im in KC..if it where me, id take that 300 and keep an eye on craigslist..sell some of the stuff you have collected,take that money and go buy a motor you can hear run..ive bought 3 running 327s for less that 400 each, a 400 running for 450...ya just have to be diligent, get a plan...carbed motors are everywhere for cheap here...saw a 454 running and driving for 650...better ways to spend money than trying to save some...
__________________
Mark
Old 06-02-2012, 07:21 PM   #13
LWT
Grenade Inspector
LWT's Avatar
I'm taking it that the 400 runs decent now & has some life left in it. I think he is just wondering about a few bolt ons not a rebuild.
__________________
Old 06-02-2012, 07:48 PM   #14
biscaynes
Senior Member
biscaynes's Avatar
yep, 3 bills will get you rings, bearings and gaskets.
__________________
this space for rent
Old 06-02-2012, 08:10 PM   #15
HamD
Grenade Inspector
HamD's Avatar
The TBI with a xxxx747 service # ECM is beyond well documented. Everything you wanna know about it is out there. Using a vaccuum HEI gives up the ECM timing curve possibilities so if you go that route, get the right distributor. If you want it to run correctly and get mileage, make sure it has a VSS and is setup just like a 95 truck.
You can adapt it to the GM intake with a simple adapter; 454 TBI trucks had an adapter like that on a 4bbl intake.
EGR helps mileage if setup correctly and the only downside is 200k miles later, you might clog an EGR passage in an intake. If you really want mileage, add it. I just did an intake swap last year (clogged passage) and mileage is up a good bit plus it's running cooler.
Technology is your friend and the Vortec heads are the final in a series of head advancement that started with the aluminum head LT1, progressed to the iron head LT1 (better flowing,) then to the Vortecs. They're worth the expense of a new intake.
$300? Really? Why take the pinnacle of displacement in the good running but still budget engine of the century and then half-ass it?
I have an upcoming 400 EFI job. Gotta start doing some parts hunting.
Old 06-02-2012, 08:10 PM   #16
Rattle Trap
Grenade Inspector
Rattle Trap's Avatar
The last motor I built on the cheap cost me $600. And this was done with all the machine work done for FREE.
Old 06-02-2012, 08:37 PM   #17
zman
Alliance Member
zman's Avatar
Quote:
Perhaps those that build motors here live in reality. What you are asking is pretty much impossible on your budget.
__________________
I have gotten grief for pointing out that the white, speckled stuff on chicken shit is still chicken shit. I will continue to do so... Chili Phil
Old 06-02-2012, 08:52 PM   #18
Biscayner
Newbie
Doing a cheap 400 does not exist anymore. That being said it is just that the parts are more expensive than years ago. The 400 I just took out of my Son's Biscayne ran fine but it runs hotter and used more gas than the 350 Vortec engine it just got.
A Vortec head 400 like the other guy said is a good idea and with those heads you will be close to 10.5 if not 11. to 1 compression which is ok as long as the cam you use is on a 114 LCA. Guys are making 500 lbs tq. with the vortec heads on 400's and you just have to find good used parts cheap.
If you plan to use TBI the vortec intake is big bucks as I spent over $350 just for that and $200 just for the 454 throttle body. If you go that route let me know and I will give you a deal on both.
As for fuel mileage anyhting more than about 15 in town and maybe 20 on the hwy. may be possible but you would need the right gear to make it work or overdrive.
Old 06-02-2012, 10:13 PM   #19
kscarguy
Senior Member
kscarguy's Avatar
Thanks for all the replies, guess I had to shake things up a bit...sorry.
Some very interesting stuff. I do need to make a few corrections.. Tire height is 30" Weight is more like 6000#.
My 400 runs well as-is. Since we all messed with low dollar stuff in high school, I thought $300 would be sufficient to hop it up a bit especially since I have a bunch of parts already.
I think I can divy up the $300 goal as follows:
$100 - Summit Racing cam and Lifter kit (build low rpm torque)
$65 - Speedway motors head and intake gaskets
$35 - cloyes double roller set
$95 - eBay used 3.73 gears for my 14 bolt diff. (down from 4.10)
$5 - Chevy orange spray paint (always makes them run fast)
Drill steam holes in my rebuilt 76cc heads that have hardened seats
Install the performer manifold I have
Use the quadrajet I have (easy to try the AFB)
Swap the cam. lifters and timing chain to get more torque (???)
Swap the gears to reduce rpm (from 2250 to 2050 @70 mph)
I'd like to change the heads to smaller combustion chambers, but I read somewhere that vortec and 305 heads up the compression too much for the stock pistons. Will a 72cc head work with 87 octane and stock pistons?
Old 06-02-2012, 11:01 PM   #20
mike hohnstein
Years ago I built a 400 for towing, truck was a 78 3/4 t Chev. carried a 10' camper and pulled a 22' tag with a 3000# drag car. 3.73 gear, NP540 5 sp trans, 31" tires, performer, Q-jet, stock type heads but CR was 9:1, balanced assy. smooth runner, sounded great, ran like a watch got 3 mpg. Yes 3 mpg from WI to Idaho for a race @ Firebird, and back, then I took it all apart, put a 350 and granny gear 4 speed and sold it all. Next truck was a 79 single wheel crew cab with a 454 and a T-400, LEFT IT ALONE. I suspect the fact I left the stock length rods in there was probably part of the problem. Rat motor truck with same load got 6.5 all the time.
Old 06-02-2012, 11:06 PM   #21
kscarguy
Senior Member
kscarguy's Avatar
Seems I've upset some people here. That was definitely not my intent.
The fact is, I have a budget. End of story. I started this post to see what, if any, improvements could be accomplished on that budget and with the parts I already have, rather than just installing the motor bone stock.
Thanks to those who understand my goal. Sorry to those I've upset.
Old 06-03-2012, 05:35 AM   #22
zman
Alliance Member
zman's Avatar
Is that manifold squarebore or spreadbore? That'll make your decision.
__________________
Old 06-03-2012, 07:03 AM   #23
Bad Banana
Alliance Member
Bad Banana's Avatar
Facts are facts. Laws of physics says it takes X amount of fuel to do X amount of work. Production engines and fuel systems have had teams of engineers trying to wring every MPG and HP out of each combination. You can sometimes cheat the MPG a bit but you will suffer a power loss (lean). You can cheat the fuel a bit and gain some power with power enrichment but MPG will suffer (rich). If you increase the airflow through the engine (i.e. more cam, better heads, manifold headers, etc.) that increased airflow needs more fuel to support it. Period.
The 2 biggest things you can do to improve fuel economy is either slow down (under 60 mph for wind load on the front) or lighten the load (take out all that shit you don't need to haul and start swiss cheesing everything). Most braggarts who claim huge fuel economy gains over "stock" are liars and want to justify in their own minds the money and work invested in their "improvements".
Physics... it's the law.
Old 06-03-2012, 08:26 AM   #24
Engine man
Senior Member
I hear ya there. All of the ads for an air filter, exhaust system, computer chips etc that will boost power and save fuel make me laugh. Manufacturers these days are very conscious of fuel mileage and if there was anything they could do to bring their corporate average up, they would do it.
I recall Hot Rod Magazine in the 70s taking a Ford van and try all of the various mileage improving parts on it. I recall the only appreciable difference they were able to make was removing the outside mirrors.
EFI would be the best bet but it isn't cheap.
__________________
Old 06-03-2012, 08:27 AM   #25
mschiffel
I'm using a remanufactured 400 SBC in my 1948 Chrysler.....not finished yet, but it cost way more than $300.00....I spoke with the rebuilder and told him that I wanted a torque monster...not a high revving engine...I'm also using a modified TH350 with a stock converter and a 3:31 open rear diff....The 400 has an Edelbrock Performer w/Quadrajet, MSD HEI dizzy, ramhorn exhaust manifolds w/duals and Raptor Turbo mufflers....I'll be happy if this combo delivers 13-15 MPGs....If you think that 300 bucks is going to have you up and running...think again !!!...double that figure and even then it might not cut it for a budget build....these projects get real "spendy" real fast....I understand the concept of a budget too...spend money on the important things like a RV style cam and lifters, a good gasket kit, timing chain, and lap in your own valves...any farmed out machine work kills budgets quickly !...use what you already have on hand...its all the small stuff that adds up like fittings, hoses, wires, clamps, etc.good luck and keep us posted.
Old 06-03-2012, 11:11 AM   #26
kscarguy
Senior Member
kscarguy's Avatar
All of my my intakes are spreadbore. I like the idea of using the stock manifold with the EGR to gain MPG. It is just so hard to pass on the Edelbrock. It seems counter productive.
I think the TBI will cost too much to modify to run well on the 400, so I'll save it for a 350 bolt on swap in another project.
Swapping in the 400 is just a bolt in operation. I already have a crate 350 in my truck and it runs and drives as-is. Only extra costs might be some small gaskets, antifreeze and fresh oil. The reason for the swap is to gain the extra torque.
Any recommendations for the best size of cam running the stock pistons and the stock (rebuilt) heads that I already have? I am thinking of using the Summit Racing cam kits. I also am considering Northern Auto parts Kits. Both seem affordable.
Does advancing the cam timing by 4 degrees really work? Anything to watch out for in a stock type motor?
Old 06-03-2012, 11:13 AM   #27
kscarguy
Senior Member
kscarguy's Avatar
I also remeber that Ford van. They suggested not hauling your spare tires on the roof. Words to live by...harly ever see them on the roof of a camry.
Old 06-13-2012, 02:11 PM   #28
kscarguy
Senior Member
kscarguy's Avatar
So far on my build, I have spent:
$75 for a new Crane cam (pn 113901)
$47 for new Crane Energizer lifter set
$72 for new Fel Pro head gaskets, Summitt intake gaskets, Cloyes 3023x double roller chain and Comp cams break in lube (just in case).
I have a chance to buy a new set of steel 1.6 rocket from Jegs for $20. Not sure if it is worth it for a low RPM motor. Someone suggested it on the initake valves only
Keeping close to my budget so far...
Old 06-13-2012, 02:20 PM   #29
deto
Senior Member
deto's Avatar
58cc cast iron heads on a 400CI motor for hauling... no bueno
__________________
check out 4F Fabrication! 4ffab.com and find us on Instagram and Facebook
Old 06-13-2012, 09:42 PM   #30
raengines
Grenade Inspector
raengines's Avatar
don't forget the flywheel is special for the 400 too along with the damper
__________________
Lost in the 50's
Old 06-13-2012, 09:51 PM   #31
slammed
Old School HAMBer
slammed's Avatar
And a balanced motor will be better for longevity and smooth power. Mo' money! Honestly 300 Ben's? Could'a slid a 472 Caddy out of a rust bucket.
__________________
http://www.hotrod.com/featuredvehicl...k_show_friday/ WTF S'not Rod.
Old 06-13-2012, 10:04 PM   #32
Dakota
Senior Member
Dakota's Avatar
Those 882 Casting heads you have that re rebuilt are not bad heads, Use those, Drill the Steam Holes, RV cam, Performer intake, and the 650 carb, I am a fan of the Quadrajets when they are built correctly. Too many beople hate them cause they dont know what they are doing.
I would probably spring for a set of decent valvesprings, Z28 Spec ones at the LEAST.
__________________
www.suedescarclub.com
"besides, anything north of blaine is kanukistani territory" <--- FiddyFour
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
