Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 |
Senior Member
Anyone have a wiring diagram how you can make a 3 wire turn signal and brake light switch work? I have the Easy wire kit and everything works except the brake lights. Since the turn signal uses the same filament as the brake, how can I wire it up so the brakes work and the flasher works on the blinker at the same time?
#2 |
Old School HAMBer
Search came up with this:
http://www.jalopyjournal.com/forum/s...ad.php?t=90100 |
#3 |
Old School HAMBer
You need a a 6-7 wire switch or add seperate bulbs for either stop or turn.
__________________
Ya can't have toooo many tools or DOGS !! |
#4 | |
Old School HAMBer
Quote:
![]() These are mine that I believe are actually cowl lights with painted bulbs.
__________________
Quote...You are hereby Knighted...'Sir Asseth of Hole' Tommy... 3W Larry. Quote...It's called "HOT RODDING", not paint by numbers. ![]() ...Fab32
#5 |
Alliance Member
If you have a 3 wire turn signal switch then you will need separate turn signals and brake lights but it can be done with some relays.
__________________
Just what I need......Another Nailhead! Makin it Git with Old Shit |
#6 |
I wired both brake lights together and the third brake light on its own dedicated circuit....no problems whatsoever !
#7 |
Senior Member
If you're using a aftermarket switch it's easy. Just tap into the wire after the brake light and before your flasher relay:
#8 |
Old School HAMBer
cool diagram, but that is not a three wire switch.
__________________
my favorite color is rust! |
#9 |
Senior Member
I have a 7 wire but I can't stand the cheap chinese crap out there. I figured that the 3 wire with the auto cancelling wheel was cool. And I'm sure not going to run two extra lights on a 1936 Ford coupe. Looks like the cheap 7 wire chinese crap will do for now as I want to get cruising!!!!! The brake lights are the only thing holding me from driving my car.
And thanks for that diagram, it will help. |
#10 |
Old School HAMBer
there are cool old 7 wire switches out there. wire it with plug connectors so when you find an old one you can change it.
__________________
#11 |
Grenade Inspector
I run a 3 wire with single bulb taillights. Go to the auto parts store they make adapter you use for trailers works perfect about 20 bucks.
__________________
Yea Sure |
#12 | |
Old School HAMBer
Quote:
Yes, that's what I was thinking. They had made those years ago, back when only the foreign cars had a seperate T/S rear bulb,..... so USA owners could use a normal wired trailer. |
#13 | |
Alliance Member
Quote:
It is called a Tail light converter. Joins stop and tailights together like how a normal domestic old car would be. But when the turn is on and the brake lights are on, that side will flash and not be over ridden by the brake light. How does using a single filament bulb in this application work? I think the OP can use this converter with success but only with using the standard dual fillament bulb. Wire up your switch you have as instructed to do so. Wire your brake lights switch as instructed and the converter will have five inputs, L TURN, R TURN, BRAKE LIGHTS, TAIL LIGHTS, GROUND. Runs your wires into the converter and coming out of the converter will be four wires. L Turn/Brake , R Turn/Brake, Tail lights, Ground. At this point run your wires to the rear lights. At this point you can't run the wires to the front turn signals as they will light up when you brake. IF you want to run front turn signals, splice into the left and right turn outputs of your switch and wire forward to turn signals before you connect to the converter. You may or may not have to put in a diode after your splice to prevent back feeding from the converter. Does this make sense?
__________________
Joe My 1930 Ford Coupe build thread. http://jalopyjournal.com/forum/showthread.php?t=626730 My Tudor is for sale, http://www.jalopyjournal.com/forum/s...5680&showall=1 |
#14 |
Grenade Inspector
You can't use single filament bulbs. What are you running for taillights the other option would be to add a bulb to your taillight if you could fit it.
__________________
Yea Sure |
#15 |
Alliance Member
It is very simple to use your three wire signal switch to control four (5) pin Bosch type relays and achieve what you want. One pair to switch between turn signal and brake light function on the rear lights and the other pair to either operate the front signals if you have dual element bulbs, or to switch between park lights and signals if you have single element
front lights. It has been my experience that the "trailer converters" do not hold up in day-to-day service. We tried to use them when mounting U.S. wired bodies to foreign cab/chassis when they first started to show up in the market. |
#16 | |
Alliance Member
Quote:
Gotcha, I miss read and took single bulb, for single filament. I always measure twice, I should just read twice
__________________
#17 |
Alliance Member
I own a trailer hitch shop and have been doing it for years. Your statement holds water. I have had the best luck with the Drawtite 119130 part number the best. I pay about 17 dollars for them, while I can get some below ten dollars they just suck. As long as there are no shorts in the wiring after the converter the drawtite ones seem to last several years. But if you have any bare wires or shorts downstream of the converter it will fry it immediately and lose that circuit. I have often wondered how the "factory OEM" turn signal switches seem to last decades in cars and trucks, but the aftermarked converter, which basically does the same thing, is quite a bit more fragile.
__________________
#18 |
Grenade Inspector
I just put diodes in the brake light wires to stop backfeed thru the turn lights. Works fine.
Lee
__________________
It is better to loved and lost, than to have paid for it and not enjoyed it. |
#19 | |
Alliance Member
Quote:
I believe this will only work when your blinker is on or brake lights are on, but not at the same time. Your blinker wont blink if you step on the brake. The solid signal from the stoplight switch overrides the flash of the signal. Correct?
__________________
#20 |
Alliance Member
Drew up a couple of quick schematics for using 5 pin relays with an old time
three wire signal switch. One if you have double contact front park/signal lights and one for single contact front park lights. If you have a pilot light in your signal switch, you could use a 3 prong flasher or combine the the left and right front outputs through diodes to light it. |
| Thread Tools | |
| Display Modes | |
