Reply
Thread Tools Display Modes
Old 05-22-2012, 11:30 PM   #1
Frankie Bulldog
Grenade Inspector
Frankie Bulldog's Avatar
Default What is a good bolt on junk yard IFS for a 1954 chevy bel air
being on a low budget what would be a good IFS that would bolt on a 54 Chevy Belair? I know theres gotta be some thing sitting at the junk yard that would be perfect
__________________
V/r,
Frankie Bulldog
ILL-BRED UNDERGROUND
graffiti and pinstriping supply
www.illbredunderground.com
offline   Reply With Quote
Old 05-22-2012, 11:50 PM   #2
Leebo!
Alliance Member
Leebo!'s Avatar
Default Re: What is a good bolt on junk yard IFS for a 1954 chevy bel air
Bolt on ?? I think 49-54 would be a direct fit, but your already in that boat
Seriously though, I think there is weld/fab work not matter what other front end you use. If mine wasnt already subframed when I bought it, I would be rebuilding the original susp. I think you can do/rig almost anything you can with the newer years on these.
I think ANY front sub you find at a salvage yard would need gone through with new bearings and such. Soooo, my advice is to just update what you got.
__________________
The artist formerly known as "Jagerbomb"
Old 05-22-2012, 11:53 PM   #3
Leebo!
Alliance Member
Leebo!'s Avatar
Oh, and i forgot to mention, from the research I have done, most everything mid 70's and later borders on too wide, most things earlier than 74ish are drums, so there is not much extra value in using that, and most people talk that s10's are too involved to be practical. Let us know if you venture out and try though!!
__________________
Old 05-22-2012, 11:57 PM   #4
sanfordsotherson
sanfordsotherson's Avatar
Try doing a search for Jag XJ front end threads. The Jags are all one unit like the one on your Chevy. But it won't be a 'bolt-on' deal. A lot of guys use 'em in New Zealand, Australia, etc. with really good results.
I'm planning one for my '50 Chevy...someday.
__________________
"You know you've made it, when your photo winds up on somebody's refrigerator"
Old 05-23-2012, 12:00 AM   #5
deto
Senior Member
deto's Avatar
Default
??? There is nothing that bolts in from the yard. You already have ifs. What's the issue?
__________________
check out 4F Fabrication! 4ffab.com and find us on Instagram and Facebook
Old 05-23-2012, 12:07 AM   #6
Gotgas
Alliance Member
Gotgas's Avatar
Anything modern is too wide.
Anything old and narrow enough to work will need to be completely rebuilt.
I would just rebuild and upgrade the IFS you already have (it's lasted nearly 60 years already). Or just cut it all off and buy a dedicated aftermarket front subframe. It will be easier to mount a V8 and get it really low, if that's what you're after.
__________________
Good hands. BAD taste in cars.
Old 05-23-2012, 04:28 AM   #7
mgtstumpy
Senior Member
mgtstumpy's Avatar
Quote:
Originally Posted by sanfordsotherson View Post
..... A lot of guys use 'em in Australia, etc. with really good results....
Us Ozzies do use them all the time, GM (Chevy) bolt pattern, disc brakes and power steer. Out with old and in with the new, not a lot of fabrication, connection to the column, change the rear wheel cylinders, add a tandem master cylinder and booster. DONE. Does a 54 have spring pockets or is the OEM IFS easily removed by removing the rivets?
Old 05-23-2012, 05:39 AM   #8
OldBuzzard
OldBuzzard's Avatar
The front end you have in your '54 was good enough to be used for a number of years in the Corvette. Add a disc brake kit if you must, but it is a good one as is.
__________________
Mark Twain: I am not ruggedly well, but I am not ill enough to excite an undertaker.
Old 05-23-2012, 06:46 AM   #9
pbr40
Alliance Member
pbr40's Avatar
I've used a g-body front clip and mustang 2 they all have there ups and downs and require work to get them to work especially if you are trying to get the car low
Old 05-23-2012, 06:48 AM   #10
LIFESTYLZ
Old School HAMBer
LIFESTYLZ's Avatar
xj6 jag
Old 05-23-2012, 07:10 AM   #11
wbrw32
Old School HAMBer
wbrw32's Avatar
Quote:
Not a damn thing wrong with what you already have,,
upgrade to disc brakes if you just wanna screw with it
Old 05-23-2012, 07:42 AM   #12
dirt t
Senior Member
dirt t's Avatar
I think there are kits out there to put a jag under your car.
__________________
I spent most of my money on Hotrods,whiskey and women. The rest I just wasted.
online   Reply With Quote
Old 05-23-2012, 10:03 AM   #13
NONAME
Old School HAMBer
NONAME's Avatar
why not bolt in a 62 corvette independent front suspension. Oh yeah you all ready have it
I went with vette HD springs, getting a vette quick steer center link, heavy sway bar and disc brake conversion all for less than half the cost of a twitchy mustang ll weld in kit.
fix what you have it will work fine
__________________
BLUE SKIES AND SUNSHINE, NEVER HAD A BAD DAY IN MY LIFE
www.oldcarglassguy.com
Old 05-23-2012, 10:08 AM   #14
tlmartin84
tlmartin84's Avatar
Would a narrowed Crown Victoria front end work??? The are cheap and relatively easy to narrow....pretty much a bolt on for the older trucks.
__________________
1956 F100 Build
CV/Chopped/Sectioned
http://www.jalopyjournal.com/forum/s...d.php?t=683419
Old 05-23-2012, 10:36 AM   #15
vintageauto
Alliance Member
vintageauto's Avatar
Quote:
Frankie....IMHO..update what you have for a lot less $$ and spend that savings on something else...Engine, Interior....whatever.
Murph
__________________
If you always do what you always did....you will always get what you always got.
Old 05-23-2012, 10:46 AM   #16
Bruce Lancaster
Alliance Member
Most early GM IFS cars have a lot of roll in cornering (due to front roll center location, which is close to China), and too much camber change when there is a lot of movement.
After a thorough rebuild of all bushings, add a serious anti-roll bar (usually incorrecly called anti-sway) and if you want to kill off all of the GM mush wallowing heavier springs fore and aft. This treatment will radically improve most '50's and '60's barges.
__________________
Bruce
Old 05-23-2012, 11:06 AM   #17
yetiskustoms
Alliance Member
yetiskustoms's Avatar
There are tons of threads on here about this. Nothing is wrong with the stock suspension. Plenty of upgrades available. I have used s10, g body, camaro, and jag fronts on these cars. Non are bolt in. They made the 54 style front end for many years and continued into 63 i think on corvettes. That should say something....
__________________
It's not what you buy,it's what you build!
Vintage Rollers C.C.
Oregon~Idaho
Old 05-23-2012, 12:29 PM   #18
Frankie Bulldog
Grenade Inspector
I Aprreciate everyones input, I posted this, not to go run and buy an IFS to swap, but to kill my curiosity, to be honest i like the original IFS, plus less headaches to change I got other things to worry such as "body" but in rebuilding and upgrading what i have can u guys point me in the right direction, i'm just trying to build this car right and clean from the ground up and want it laying on the floor
__________________
V/r,
Frankie Bulldog
Old 05-23-2012, 03:39 PM   #19
yetiskustoms
Alliance Member
<<<<< on a highly modified g body chassis. In hind sight i would have used the original frame, but i had fun.
__________________
Oregon~Idaho
Old 05-23-2012, 03:58 PM   #20
Corn Fed
Senior Member
Corn Fed's Avatar
I've heard that a 55-57 frame will go under a 53-54 with very little effort. If you can do this, you'll get a little more modern type of front end, plus loose the torque tube.
__________________
A little slice of Hemi right here on earth.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
