Reply
Thread Tools Display Modes
Old 05-17-2012, 11:01 PM   #21
specsintexas
Grenade Inspector
specsintexas's Avatar
Default Re: 1937-38-39 Chevy Car's on S-10 Frames
Finally, I got a negative reply that make sense. Thank You tb33anda3rd . You are so right. The "front steer" steering box is a major problem if you want to maintain the stock look on the outside while going for a modern performance underneath. Food for thought.
Thank You
Specs
offline   Reply With Quote
Old 05-18-2012, 01:29 AM   #22
gimpyshotrods
Old School HAMBer
gimpyshotrods's Avatar
Quote:
Originally Posted by specsintexas View Post
Have you welded on a 1939 Chevy "top hat" frame lately?
1939 no (not yet), 1937 (and most other years) yes. We are building a 1937 in the shop, right now. MII front, triangulated 4-link in the rear. Power steering and power brakes are not on the list for this one, but they could easily be. We just finished a '41 and a '52.
There have been zero issued with the welds, so far. I doubt there will be any.
I have welded on over 40 "top hat" frames. Did not have any issues with those either.
What sort of problems are you having?
Oh, and the S-10 front suspension is of a designed penned in, and put into production in the early Sixty's, hardly modern, or performance. At least the MII is from the 70's.
__________________
Ala Kart had air bags in 1957. Traditional? Yes!
Old 05-18-2012, 05:14 AM   #23
Paint
Grenade Inspector
Paint's Avatar
This is mt 37 chassis, all Chassis Engineering stuff.
No need to weld anything, top quality stuff that fits.
Click image for larger version
ID:	1641494   Click image for larger version
ID:	1641495   Click image for larger version
__________________
Give me a shifting spanner, I'll fix it.
Old 05-18-2012, 06:48 AM   #24
Lobucrod
Alliance Member
Lobucrod's Avatar
If you do it I want to buy the original frame. Hey I'll find an s-10 frame and trade you even.
__________________
Makin it Git with Old Shit
Old 05-18-2012, 07:27 AM   #25
drptop70ss
drptop70ss's Avatar
I have an S10 chassis under my 37 buick, works great but turned out it was much more work than if I had updated the rear end and done a front clip swap. Use a manual steering box or a 605 PS box to gain room up front. This was my first chassis swap and it worked as intended, just was not the time saver I thought it would be. If your frame is solid I would clip it and update the rear axle, that is what I am in the process of doing with my 47 cadillac. Front clips from a G body can be had for $100-$200 and a good used rear axle about the same price. Do what you want, it is your car.
Old 05-18-2012, 07:41 AM   #26
I Drag
I Drag's Avatar
The S-10 frame swap costs hundreds, the aftermarket suspensions for stock frames cost thousands. For all of you that ask "why?", this is the reason people continue to want to do this.
__________________
John Kosakowski
http://hotrodsinthehudsonvalley.blogspot.com/
Old 05-18-2012, 09:23 AM   #27
lo c dan
lo c dan's Avatar
Location: "Sometimes people don't want to hear the truth because they don't want there illusions destroyed"
Are you saying everything is bolt-on? cross member, spring, control arm housing etc? Say it ain't so. Or am I just we-tod-did.
__________________
" You haven't lived until you've almost died.For those who have fought for it, life has a meaning the protected will never know. "
Old 05-18-2012, 09:29 AM   #28
Paint
Grenade Inspector
Paint's Avatar
I don't think you are retarded but yes everything is bolted on.
Had to weld a spacer and gusset to the crosmember for the tubular A arms but if you use stock Mustang arms you don't need to.
__________________
Old 05-18-2012, 12:46 PM   #29
RMR&C
Senior Member
RMR&C's Avatar
Personally, I don't really see what you gain by putting a car body on a truck frame. Better ride? Better handling? Not really.....
Save money? Maybe.....but it also lessens the value of the car to most people.
My biggest peeve is usually a decent buildable car gets all hacked up trying to fit it on the chassis, then the owner gives up on the project because it was more work than he planned. Leaving a hacked up car that nobody wants.....
__________________
it's kinda like watching paint dry
Old 05-18-2012, 01:26 PM   #30
mrconcdid
Senior Member
mrconcdid's Avatar
Why do people think the S-10 frame swap is a good idea 2 reasons there cheap and easy to find.
I considered it once, went as far to strip an s-10 to the frame ( that was fun ) looking at the 2 frames side by side, I just could not bring myself to do it, for the work involved and the fact I could very easily ruin my car, I could not do it, I found upgradeing my old frame was easier, cheaper and dosent hurt the value of my car in the long run.
What eats your lunch ( cost ) is the small things.
lets say you had a s-10 frame, what would you keep what would you change.
Change
brake pads
rotors
bearings
spindels ( drop spindels )
springs ( maybe airbags )
tie rods
centerlink
upper/lower bushings
ball joints
steering box (stock one is to big to clear )
brake lines
rear axle ( to narrow )
all body mounts
new front frame mounts/ core support
wheels and tires
fuel lines
motor mounts
trans mount
bumper mounts
bumpers
gas tank and filler location
shocks front and rear
So what are you really keeping
upper/lower control arms
frame
rear springs and hangers
See my point? now figure in all the custom cutting up of your body to make it fit.
This is just what I learned from my experiance. Im glad I didn't do it.
Godspeed
MrC.
__________________
Check out my Artwork!
http://www.etsy.com/shop/DesignsbyLA..._shop_redirect
Old 05-19-2012, 12:14 AM   #31
Vetteman61
Grenade Inspector
Vetteman61's Avatar
Here's a link to my '37 Chevy build. I'm using all Chassis Engineering bolt on stuff on it.
Warning O/T engine and transmission:
http://www.hotrodders.com/forum/jour...ge=1&reverse=1
Brandon
__________________
Youth is wasted on the young
Old 05-19-2012, 02:55 AM   #32
sierra rod shop
Grenade Inspector
sierra rod shop's Avatar
boy o boy
__________________
Afterburner
COCHES DE LA MUERTE C.C
Old 05-19-2012, 02:48 PM   #33
gimpyshotrods
Old School HAMBer
Quote:
False economy.
Is your labor free? I get paid for mine.
This affects a frame swap project, two-fold.
Time: I can install a MII front end in one day, a rear-spring kit in a half-day. Done-and-done.
A frame swap would take weeks-to-months of my time after work, and I am a pro car builder. Depending on your skill level, you could be at it for a LONG time.
Money: Over the frame-swap period of time, I would have earned enough extra cash to buy the MII stuff, anyway (and my family and friends would not have suffered).
__________________
Old 05-19-2012, 02:53 PM   #34
jcmarz
Old School HAMBer
jcmarz's Avatar
"Why does the sun go on shining, why does the sea rush to shore, don't they know it's the end of world, and hopefully it's the end of this thread!"
Old 05-22-2012, 07:48 PM   #35
mattcarlson
FNG
mattcarlson's Avatar
i cant wait to start my frame swap on my 52 buick!!! putting a s10 stub in! oh its going to be so wonderful, i vast market in aftermarket parts that are high quality and not expensive, replacement parts readily available at any parts store! s10 front frame stubs are the same as doing a mustang II but cheaper! huh who would have thunk it! so its not traditional parts, but it goes with traditional/custom hot rod theory, if you can find something that works well and improves the car and makes things easier on the wallet then why not, if you engineer everything right there is actually minimal cutting, honestly when doing this all you need is the stub from firewall forward to just a little front of where the control arms are connected to the frame, the rest can be fabricated. with all this bad mouthing the guy for thinking out side the box and trying to build a decent car with more modern stuff, don't scold him, question him but don't try and deter him away for doing that will make him abandon it because everyone said he shouldn't cant or wont. give him a kool man cant wait to see what it looks like. this forum is a shame, no wonder i dont come here much. best of luck with the build man, if ya want a lot of useful info and see some awesome s10 frames check out www.s10forum.com lots of useful info and some guys that will gladly help ya and give ya a lot of great knowledge
__________________
my 52 buick special deluxehttp://www.jalopyjournal.com/forum/s...d.php?t=578454
Old 05-23-2012, 12:56 AM   #36
gimpyshotrods
Old School HAMBer
You must be new here.
__________________
Old 05-23-2012, 01:11 AM   #37
deto
Senior Member
deto's Avatar
Default
If he isn't new he's a mini trucker In Sheeps clothing
__________________
check out 4F Fabrication! 4ffab.com and find us on Instagram and Facebook
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
