Reply
Thread Tools Display Modes
Old 05-12-2012, 12:09 AM   #1
old soul
Senior Member
old soul's Avatar
Default Generator to a Alternator on a 55 Chevy????
My Generator is knocken and maken noise on my v8 55 chevy like it has a bad bearing. I just want to be done with it and go with a one wire Gm alt. I did a 6 volt to 12 volt conversion on my 51 chev and put a one wire gm alt on that. I had to get rid of the voltage regulater and connect the two big wires that went to the voltage regulater togather.
My question is??? What do I have to do with the wires that go to the Generator To be able to use them with my alternator???? Instead of just running a wire off it to the battery??? Im sure you guys get my drift. Thats why im asking. Thanks ahead of time you guys are awsome!!!!!!
__________________
SORRY FOR THE SPELLING IM A GREASER NOT A JOCK!!!!!!!!
offline   Reply With Quote
Old 05-12-2012, 02:17 AM   #2
old soul
Senior Member
old soul's Avatar
Default Re: Generator to a Alternator on a 55 Chevy????
I cant baleave no one has a awnser yet. You guys are just messen with me.
__________________
Old 05-12-2012, 02:59 AM   #3
Rickybop
Old School HAMBer
Rickybop's Avatar
Good evening...wait...good morning, old soul. Kinda late, all good electrical gurus are in bed, I think. And I can't answer your question with confidence. Bump it up tomorrow after dinner time...you'll get some answers.
The only thing I would suggest is that in my experience, even a 6-volt charging system with a generator will work very well if all components and connections are up to snuff. A couple of years ago, I took my stock '47 Hudson to my favorite starter/generator guy. He told me that if everything worked as it should, there should not even be any headlight dimming at idle. Sure enough...after he rebuilt my generator, and checked a few things, then fine-tuned the regulator on the car as it was running, all issues were gone, and my headlights even stayed perfectly bright at idle. You might consider doing the same, and keep your '55 as is...traditional. Good luck. Goodnight.
__________________
We were in the produce aisle.
Me: "Are you my sweet potato?"
Her: "I yam...I yam."
Old 05-12-2012, 03:02 AM   #4
325w
Alliance Member
325w's Avatar
I have a diagram am Incould snail mail you. Don't know how to scan and email. Your dealing with the idiot light now instead of the amp gauge
Old 05-12-2012, 05:34 PM   #5
Rickybop
Old School HAMBer
Rickybop's Avatar
ttt
__________________
Old 05-12-2012, 06:00 PM   #6
choprods
Alliance Vendor
choprods's Avatar
Location: Elmer,Mo.USA All the COOL... people on the HAMB have already been here,why haven't you?
email me at choprods@usa.net and Ill send you a pic of the wire diagram.....
__________________
Running in place, will never get you the results that running from a Lion will.....
Old 05-12-2012, 08:59 PM   #7
Old School HAMBer
squirrel's Avatar
I'd suggest using a 3 wire internal regulator alternator, like was used originally on most 1973-86 GM cars and trucks. Then you can keep your idiot light working.
Unless you've changed the dash cluster and don't have the idiot light any more.
Anyways, just wire the 3 wire alternator like this. The wire to the idiot light just goes to the idiot light, it's pretty darn simple.
__________________
Jim Forbes
my shtuff
Old 05-13-2012, 01:59 AM   #8
old soul
Senior Member
old soul's Avatar
So the two wires going to my generator?? Ones for the bat and ones the the moron light???
__________________
Old 05-13-2012, 09:10 AM   #9
Old School HAMBer
squirrel's Avatar
You have to remove the generator and the regulator, and the wiring that goes between them. Then you'll see the two wires you need, ending where the regulator used to be. The big one is from the battery, the other is from the idiot light.
__________________
Jim Forbes
my shtuff
Old 05-13-2012, 09:20 AM   #10
Alliance Member
Mr48chev's Avatar
What car is the 55 engine in? Do you have a 55 Chevy or is it in the 50 Chevy in the Avatar?
When you tell us what year engine you have without saying what year car it's in it confuses the issue as an alternator/generator doesn't really care what engine it is on as long as it has the right brackets to hold it on.
I'm with Squirrel in that I would go with the standard three wire style alternator as apposed to the one wire. The three wires ones are all too easy to hook up and the main reason for running a one wire is so that you don't have wires showing everywhere.
If a bad bearing is the only thing wrong with the generator you can probably replace that for under 10 bucks and an hours time. They aren't hard to work on and bearings and a set of brushes should be well under 20.00 total at any Napa store.
__________________
Happiness is having a garage big enough to hold all ttools and projects and small enough to keep warm enough to work in the winter.
Old 05-13-2012, 04:20 PM   #11
old soul
Senior Member
old soul's Avatar
Its a 1955 chevy with a v8.
__________________
Old 05-13-2012, 04:54 PM   #12
stuart in mn
Senior Member
stuart in mn's Avatar
Quote:
This is what I'd do. Unless you have a big stereo or air conditioning or some other big electrical load, there's nothing wrong with a generator and it will save you a lot of work.
Old 05-13-2012, 05:00 PM   #13
Model T1
Senior Member
Model T1's Avatar
Use that above wiring diagram and use an alternator of the years mentioned. Been running this set up in all my cars six 1987. Eliminate the ballast resistor, regulator, and generator. Also switch to an HEI distributor.
__________________
Model T--Denny
Life is too serious to always be serious.
Old 05-13-2012, 08:32 PM   #14
old soul
Senior Member
old soul's Avatar
Im done messing with a generator. Alternator time.
__________________
Old 05-14-2012, 08:01 AM   #15
Model A Vette
I don't have a 55 diagram but have a 56 one.
On the 56 one the idiot light wire is the smaller 20 gauge brown wire on the generator.
That wire goes to the #1 terminal on the alternator.
Red 12 gauge from the stud on the alternator to the horn relay "B" terminal.
Install jumper per Squirrel's diagram.
__________________
Ed
Old 05-14-2012, 11:46 AM   #16
Charlie Stephens
Senior Member
Quote:
If you think you are tired of the generator just wait until you get the alternator, you will have a whole new set of problems. My advice would be to take it to a good generator repair shop and have them fix it right. The only reason generators have a bad rap is that most shops only fix what is broken and send it down the road for the next failure. You need a shop to completely rebuild the generator.
Charlie Stephens
Old 05-15-2012, 07:28 PM   #17
old soul
Senior Member
old soul's Avatar
If alternators are so bad. Why are they still using them????
__________________
Old 05-16-2012, 01:11 AM   #18
Commish
Grenade Inspector
Quote:
Charlie Stephens
And just what is it you think is a whole new set of problems, when I was a kid everything I ran had a generator, can't count the times I slung the solder out of the commutator turning high rpm's. Alternators cured all that, and the integral regulated GM alternator is easy to hook up, and as easy to rebuild as a generator. I just fail to see the negatives you are claiming.
Old 05-22-2012, 12:00 AM   #19
old soul
Senior Member
old soul's Avatar
Any other tips or tricks befor I go in for surgurey??????
__________________
Old 05-22-2012, 12:09 AM   #20
cactus1
Alliance Member
cactus1's Avatar
What else do you need to know? You said you don't want to use a generator and Squirrel told you how to wire the Alternator. Am I missing something?
__________________
Vagabonds C.C.
Check out my '34 Chevy truck build thread here: http://www.jalopyjournal.com/forum/s...d.php?t=371802
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
