Go Back   THE H.A.M.B. > The H.A.M.B. Marketplace > Classifieds > Parts For Sale
Closed Thread
Thread Tools Display Modes
Old 05-06-2012, 09:49 AM   #1
gassa-garage
Grenade Inspector
gassa-garage's Avatar
Default 426 Hemi blower manifold
This a Cragar 671 blower manifold for the 426 Hemi motor . I was told it was bolted to the motor and all set up but never run . It appears that is the case as I see no sign of any fuel running thru the manifold . Is it a cragar or another brand with a cragar pop off valve ? I am not certain as there are no numbers on the manifold that I can see . There were gaskets stuck on it when I got it and they were as hard as a rock from age , I carefully peeled them off and used a scotch brite wheel to clean the gasket surfaces off. The runners at the heads have had a little deburring done and I mean LITTLE , don't know why they even bothered it is so minimal . One corner (see pic) looks like a brainiac used a screw driver or something to pry it up and it put a little crack on the lip , This is not anywhere near the runners and will not effect the use of the manifold and you can barely see it but I wanted to point it out .
__________________
Some people take pride in what they do ,
others just take ?
offline
Old 05-10-2012, 07:41 AM   #2
gassa-garage
Grenade Inspector
Default Re: 426 Hemi blower manifold
bump
__________________
others just take ?
offline
Old 05-18-2012, 08:07 AM   #3
gassa-garage
Grenade Inspector
ttt
__________________
others just take ?
offline
Old 05-22-2012, 08:37 AM   #4
gassa-garage
Grenade Inspector
bump
__________________
others just take ?
offline
Closed Thread
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
