Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 05-23-2012, 05:15 PM   #101
Kume
Grenade Inspector
Kume's Avatar
Default Re: YES SIR May I have another.....The May 2012 Banger Meet
Quote:
Originally Posted by monkeybiker View Post
I did start this years ago but abandoned using the T chassis. Made it worse for myself by using RHD running gear...
I was trying to keep the crankline in the same place on a full fendered tourer.
Here's a couple of pictures someone sent me of an install they did.
Thanks Monkey Biker
That looks like a snug fit - is that the stock front cross member you have mounted the front engine mount to? why did the RHD make it more difficult.??
Kume
offline   Reply With Quote
Old 05-23-2012, 05:17 PM   #102
Kume
Grenade Inspector
Kume's Avatar
Quote:
Originally Posted by youngster View Post
Kume,
You could use the front mount from a '34 pick-up and fab something like a float-a-motor side mounts. An other option would be to fab a T type mount to "hang" the motor from the top of the rail.
The clutch pedal will need to be reshaped a bit to clear the frame rail.
On my '21 on a narrowed A frame, this is how I set up the mech. brakes;
I simply shortened each side of the bellcrank and added 1/4" plates and gussets.
Ron
Thanks Ron
Thats encouraging - I thought about the rear engine mounts hung off the rails like a T - seems like the simplest solution. Brakes dont seem to be too much of an issue.
Kume
Old 05-23-2012, 05:22 PM   #103
Kume
Grenade Inspector
Kume's Avatar
Quote:
Originally Posted by Bigcheese327 View Post
HAMBster GARY? has an A-engined, T-framed gow.
And -Brent- has a similar setup with his A-engined, TT-framed roadster.
Thanks BigCheese
Gary's roadster is one of my all time favorites - looks like he has front brakes so assume A axle?. Not familiar with the bottom T but love the exposed mechanical brake rods. There is no stopping me know!
Old 05-23-2012, 09:37 PM   #104
youngster
youngster's Avatar
Mind if I add mine to the lot?
__________________
Follow the rules and ya ain't gonna have any fun!
Old 05-24-2012, 12:25 AM   #105
Flat Ernie
Tech Editor
Flat Ernie's Avatar
Was there an April Banger meet? I've been out of town and trying to update the Tech links - got March & May, but no Apr with a quick search.....
__________________
Daddy always said, If yer gonna be dumb, ya gotta be tough! - And I'm one tough sumbitch!
T5 Tech
Old 05-24-2012, 12:49 AM   #106
97
Quote:
http://www.jalopyjournal.com/forum/s...d.php?t=685565
Old 05-24-2012, 12:59 AM   #107
Kume
Grenade Inspector
Kume's Avatar
After a day spent trawling the HAMB following leads from above I think I have found everything I need. I new it would all be in here somewhere.
Thanks to great info and build threads for Brent, Gary and Youngster's A/Ts - absolutely inspirational stuff.
cheers
Kume
Old 05-24-2012, 07:27 AM   #108
hotrodfil
Senior Member
hotrodfil's Avatar
I was looking at mounting a second crossmember to pick up the A front engine mount. There's the snout of a T sump mounted to the original front crossmember to help line things up.
The body has eventually made it's way onto this my "1927 Mercury" as christened by Mr. Big Cheese...
After messing around porting a B engine that turned out to be cracked I've been offered a hot diamond A engine which if funds allow will find it's way in there.
__________________
"Tradition is a guide and not a jailer." W. Somerset Maugham
My '27 Mercury..Monkeybiker no more..
Old 05-24-2012, 07:31 AM   #109
Hapydz
Alliance Member
Hapydz's Avatar
Anyone know what kind of psi the "B" fuel pump puts out ?
Ron
__________________
If it wasn't for Henry Ford and Ed Cole, I'd be a stamp collector
Old 05-24-2012, 07:45 AM   #110
Hapydz
Alliance Member
Hapydz's Avatar
Quote:
Ron
A little slow this morning, I found it 1 1/2 to 3 psi.
Ron
__________________
Old 05-24-2012, 07:50 AM   #111
Bigcheese327
Alliance Member
Bigcheese327's Avatar
Ah, you liked that, did you?
Such a great-looking car!
__________________
"Black-wall tires, they blend into the pavement, but these white-wall tires, they say look at me, here I am, love me."
Old 05-24-2012, 07:59 AM   #112
Bluto
Old School HAMBer
Bluto's Avatar
Smile Re: YES SIR May I have another.....The May 2012 Banger Meet
Ron please get a gauge..... vacuum/pressure
Your gonna need a Vacuum Gauge to adjust those carbs
Old 05-24-2012, 08:13 AM   #113
Hapydz
Alliance Member
Hapydz's Avatar
Thanks Jim, will do..
Ron
__________________
Old 05-24-2012, 09:37 AM   #114
Bluto
Old School HAMBer
Bluto's Avatar
Step one
http://www.tuningmadeeasy.com/tuning...e-wonder-tool/
Old 05-24-2012, 04:57 PM   #115
Kume
Grenade Inspector
Kume's Avatar
["I was looking at mounting a second crossmember to pick up the A front engine mount. There's the snout of a T sump mounted to the original front crossmember to help line things up."]
Thanks Monkey
It now makes sense. Riveting a second cross member in seems a good option for me. allows some flexibility in working out rear axle and torque tube position.
By the way - love your flathead T - there is something incongruous about seeing a bright shiny yellow or red Ford hotrod in the English landscape but your T fits in like some kind of renegade medieval knight. love it!
Kume
Old 05-24-2012, 05:13 PM   #116
denis4x4
Alliance Member
denis4x4's Avatar
Check out the coverage of the Speedster Reunion in the August issue of R&C.
__________________
"Traditional hot rodding is thinking outside the box, not a paint by numbers project".
Four Corners Chapter Goldchainer CC
Old 05-24-2012, 07:54 PM   #117
Flat Ernie
Tech Editor
Flat Ernie's Avatar
Thanks - didn't pop up on my search for 'banger' yesterday for some reason....
__________________
T5 Tech
Old 05-25-2012, 03:28 PM   #118
Hapydz
Alliance Member
Hapydz's Avatar
Jim; This is a great link even for the realativly simple banger motors. I feel smarter already . Well, maybe not smarter but I feel that I'm on the right track thanks to you. Really looking forward to knowing rather than guessing
Thanks Jim !
__________________
Old 05-25-2012, 03:37 PM   #119
Crazydaddyo
Alliance Member
Crazydaddyo's Avatar
Here is another tuning instructional the Jim turned us on to:
http://www.centuryperformance.com/tu...e-spg-148.html
__________________
" I've tried nothing ...and I'm all out of ideas."
T-5 5 speed in a Torque Tube:
http://www.jalopyjournal.com/forum/s...d.php?t=256226
Old 06-01-2012, 07:45 PM   #120
Bigcheese327
Alliance Member
June meet?
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
