Reply
Thread Tools Display Modes
Old 04-25-2012, 05:46 PM   #1
Zigged, should've Zagged
Newbie
Zigged, should've Zagged's Avatar
Default 400 cu. in.chevy engine inquiry
My son wants to put a manual transmission where his Automatic is now. Is that block machined for that? (early 70's 400 chevy).
offline   Reply With Quote
Old 04-25-2012, 05:51 PM   #2
beebing
beebing's Avatar
Default Re: 400 cu. in.chevy engine inquiry
400 chevy is externally balanced, so you need a flywheel specifically for the 400 and not a typical SBC flywheel.
__________________
When all is said than done, more will be said than done.
Old 04-25-2012, 05:52 PM   #3
budd
Old School HAMBer
budd's Avatar
400's did come standard, you need a flywheel made for the 400 as they are externally balanced, my friend and i had 400's with a standard trans in our pulling truck and i do not remember having to drill the crank for a pilot bearing, i'm guessing thats what your worried about.
Old 04-25-2012, 05:57 PM   #4
beebing
beebing's Avatar
Pilot bearing should go right in with no machining.
__________________
Old 04-25-2012, 06:04 PM   #5
Engine man
Senior Member
There is also a balance weight that is available so you can use a regular flywheel. There weren't a lot of 400s with stick transmissions so flywheels are scarce. Lots of racers used the balance weight.
__________________
Anything dropped while working on a vehicle will roll underneath to the exact center.
Old 04-25-2012, 06:08 PM   #6
davidbistolas
Alliance Member
davidbistolas's Avatar
If that's a good 400 block, tell him to sell it, get a 350 and stroke it out to 383 (now or later). Thars good money in good 400s.
Old 04-25-2012, 06:10 PM   #7
Lobucrod
Alliance Member
Lobucrod's Avatar
You need one of these. Goes between any non balanced v-8 flywheel and the crank. Only 30 bucks and you can buy it here. http://www.cylinderheadsupply.com/chflbapl.html
__________________
Makin it Git with Old Shit
Old 04-25-2012, 06:11 PM   #8
Newbie
Thanks! That's good info. I guess we'll proceed. I like your Avatar by the way.
Old 04-25-2012, 06:15 PM   #9
Hanson
FNG
Hanson's Avatar
Ran a m22 (rockcrusher) with a sb400 in my 60 gmc knee knocker. With the parts these guys listed its an easy install. Good luck and have fun.
Old 04-25-2012, 06:19 PM   #10
Newbie
I was just talking to my son about a rockcrusher, and there it showed up on the post. You know ,sometimes Dad makes a suggestion , but when someone else says it ,it flys higher.
Old 04-25-2012, 06:30 PM   #11
Newbie
Thanks again
Old 04-25-2012, 06:33 PM   #12
40StudeDude
Old School HAMBer
40StudeDude's Avatar
I run a 400" in my Studey...behind it is a T-400...the flex plate got chewed up badly by the starter way back in 1980...so I purchased another flex plate, not knowing of the external balancing and put it all back together. At thirty-five MPH, the car shook violently...had no idea what was wrong.
I checked with a few mechanic friends and found out the problem...not wanting to spend weeks tearing the car down andputting it back together again, I took a hammer and chisel to the flex plate and whacked off a small 1 inch square piece of metal spot welded to the flex plate.... Took it down off the jack stands and took it out for another drive...solved the shaking problem...and I've been driving the car ever since...it's now got nearly 140,000 miles on it since then and not one vibration since then...
FWIW, the engine still in it -the 400" SBC was overhauled in early 1980...the guy that overhauled it told me it wouldn't last 80,000 miles cuz it was "so loose"...I'm almost twice that now and the car burns no oil and gets a constant 20-21 mpg...
Problem is, the lacquer paint is checking and needs redoing, the interior is worn from all the seat time and the carpet has massive wear spots...and I'm looking at a year or more to re-do it all...it runs so good yet I don't want to tear it down...
R-
Old 04-25-2012, 06:35 PM   #13
1oldrat
Alliance Member
1oldrat's Avatar
You can also buy a new flywheel for the 400,I'd much rather use a good flywheel than a $30.00 counter weight.That's just my opinion.
Old 04-25-2012, 06:39 PM   #14
richie rebel
Senior Member
richie rebel's Avatar
don't get rid of the 400 they good engines,do not sell it....richie
Old 04-25-2012, 06:43 PM   #15
BISHOP
Old School HAMBer
BISHOP's Avatar
Quote:
Best of the small blocks for sure.
Old 04-25-2012, 06:49 PM   #16
johnod
Zig Like your coupe,37-8 one of fav cars, like the colour too.
Old 04-25-2012, 06:58 PM   #17
Newbie
The Guitar keeps rolling off though!
Old 04-25-2012, 07:06 PM   #18
themoose
Old School HAMBer
themoose's Avatar
You can take a look for the new part number of a new flywheel for your 400
http://www.gmpartsdirect.com/perform...CATID=913.html
__________________
Custom Tees With your ride
Too soon we get old too late we get smart.
One out of two ainít bad
Old 04-25-2012, 07:08 PM   #19
speedfreek155
Grenade Inspector
speedfreek155's Avatar
Look for this threaded boss over oil filter . it is where the clutch pivot ball mounts on small block chevys . I just happen to be tearing down a 350 for an overhaul presently .
Click image for larger version
__________________
Do not speak , unless it improves on silence .
Old 04-25-2012, 07:25 PM   #20
aaggie
Alliance Member
Just making sure you know but the 400SBC also needs a different harmonic balancer since it is externally balanced.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
