Reply
Thread Tools Display Modes
Old 04-25-2012, 01:30 PM   #1
Stevie Nash
Alliance Member
Stevie Nash's Avatar
Default Which way does a SBC distributor turn?
Clockwise or counter clockwise? I would assume clockwise.
The reason I ask is that I took the distributor out and had it marked so I could just drop it back in. While rewiring the Nash, I accidentally hit the starter and the engine turned for a brief second, so I'm going to try and compensate by moving off the mark a little bit. Just need to know which direction.
__________________
Outsiders C.C.
Wanted: 1937 Nash Coupe
offline   Reply With Quote
Old 04-25-2012, 01:34 PM   #2
ThompsonSpeed
Newbie
ThompsonSpeed's Avatar
Default Re: Which way does a SBC distributor turn?
Clockwise. Good luck!
Old 04-25-2012, 01:34 PM   #3
Larry T
Old School HAMBer
Larry T's Avatar
All distributors turn the opposite direction the vacuum advance points. In the case of Chevy, it is clockwise.
You'll save yourself some trouble and grief by setting the engine on TDC/compression stroke and installing the distributor.
__________________
Goldchainers CC
Old 04-25-2012, 01:38 PM   #4
OL 55
Old School HAMBer
OL 55's Avatar
What Larry said. I just did the same thing on my 40 when we had to turn the motor over with the distributer out.
__________________
Bucket list are rubbish. Stop writting list and get on with it!
Old 04-25-2012, 01:39 PM   #5
hopped up
hopped up's Avatar
Good advise from Larry T.
online   Reply With Quote
Old 04-25-2012, 01:45 PM   #6
Alliance Member
Mr48chev's Avatar
Larry nailed it. If you wrap your thumb around the vacuum advance and your index finger around the distributor your index finger will be pointing in the direction of rotation.
Don't be surprised if you have to bring the engine up on compression and drop the distributor in more than once to get it right and in the right spot. Anyone who says he gets it perfect the first time every time is lying to himself if no one else.
__________________
Happiness is having a garage big enough to hold all ttools and projects and small enough to keep warm enough to work in the winter.
Old 04-25-2012, 01:56 PM   #7
Don's Hot Rods
Old School HAMBer
Don's Hot Rods's Avatar
Everyone is giving you good advise, you have no way of knowing how far it moved when you hit the starter so the only way to get it right is to start from scratch. Bring number one up on compression stroke (put your thumb over the number one spark plug hole while someone bumps the starter (or better yet, use a breaker bar to turn the crank) and when you start feeling compression look at the timing mark on the damper and bring it around until the marks line up. Now you can drop the distributor back in and pointing to number one.
If you do it the way you are thinking about you risk being way off on your timing.
Don
Old 04-25-2012, 02:00 PM   #8
Stevie Nash
Alliance Member
Yah, I know.... But I thought I would give it a shot and see if I could get lucky. If that doesn't work I'll start from scratch.
__________________
Outsiders C.C.
Old 04-25-2012, 02:14 PM   #9
Ebbsspeed
Alliance Member
Ebbsspeed's Avatar
If you're going to try the "get lucky" deal, make sure you have an air cleaner on the carb to arrest the fire that may well belch out. Whatever you do, don' have anyone, including yourself, hanging your upper body into the engine compartment where the fireball can get to your hair.
Don't ask me how I know this........
Old 04-25-2012, 02:25 PM   #10
Rex_A_Lott
Alliance Member
Next time, look at the way the plug wires are on the cap..18436....
Start over, like the ohters said. Its a good thing to know how to do.
Good Luck
Old 04-25-2012, 02:31 PM   #11
bobss396
Old School HAMBer
bobss396's Avatar
Don
Actually good practice to do one up from scratch.. and a discipline as well. Nothing worse than being one stinkin' tooth off and have it drive you nuts for a while.
Bob
__________________
Proud member of the "they closed my thread" HAMB crew. -- BobSS396
Old 04-25-2012, 02:43 PM   #12
porknbeaner
Alliance Member
porknbeaner's Avatar
Not to be an ass or rain on your parade or whatever the proper things to say about what I am going to ask is but, how ya going to guess how many degrees the engine turned?
__________________
If it don't make ya dirty it ain't yours
No man crosses a chasm in two jumps
Old 04-25-2012, 02:59 PM   #13
aaggie
Alliance Member
If it wasn't on TDC when you pulled the distributor and you turn the crank to get it to TDC, remember that the oil pump drive may need to be turned with a long screwdriver to get it lined up. Then the distributor will drop right in place.
Old 04-27-2012, 09:04 AM   #14
porknbeaner
Alliance Member
Quote:
That works but it is actually the hard way. Drop the distributer where you want it then bump the motor over. When the oil pump drive lines up the distributer will drop into place.
__________________
Old 04-27-2012, 09:27 AM   #15
unkledaddy
Senior Member
unkledaddy's Avatar
Quote:
The easy way.
__________________
"Who's your Unkledaddy?"
Old 04-27-2012, 09:42 AM   #16
derbydad276
Senior Member
derbydad276's Avatar
what side of the boat is it mounted?
__________________
your kids can have their own race car...
www.aasbd.org
Old 04-27-2012, 11:29 AM   #17
36DodgeRam
Grenade Inspector
36DodgeRam's Avatar
Better do it the right way, otherwise it will backfire so hard it pulls rocker studs right out of the head! Ask me how I know...
__________________
'40 Plymouth Roadking Coupe, '36 Dodge Pickup, '46 Case VAC
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
