Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 |
Grenade Inspector
I am new to rods of the age on the Hamb but not new to muscule cars, drag cars etc. I have done a bunch of searches on each piece of the setup I am looking for on here but am only confusing myself in the end. My question seems kind of convaluted but here goes.
I picked up an Essex coupe body and various parts. In with the parts were 2 Model A frames, 1 excellent, 1 rusty. I do plan on a 4" channel (or about the width of the frame). My qestion is this: when you are setting up a Model A for a more traditional highboy look (IE: not slammed) how much drop is used and where is it dropped? And how much drop is gained with each mod? 3 1/2" at the axle (dropped stock A axle) = self explanitory I have seen a pie cut at the firewall to bend the frame up (not a fan of the look) Z the front and back (width of the frame in front. Double in the rear?) = Good to do on an A frame? I have heard a T spring with 2 leaves out in the rear? Reversed spring eye in the front? dropped front spring or raised crossmember? I understand alot of what I asked is subject to how it is done, personal preferance etc. I also know I could do a spring behind, suicide style, heavy Z front or back, build a whole new frame, heavy / deep channel etc. I guess I am just looking for some pointers on how it used to be done and how the out come was. Thanks in advance. __________________ The pic is about the height I would like to acheive. Maybe a slightly smaller rear tire and 1" lower in the back but other than that just about right on.
__________________
Semper Fi |
#2 |
Alliance Member
Outside with reverse eye main leafs front and back.
![]() Outside after the rear frame height step: ![]() outside after rear step and drop axle: ![]() I also have yet to remove the leaf springs in the rear pack I think it has 8 leafs in it now. I'm going to remove a few and the new front 5.50 tires for it are shorter as well. Last edited by Hitchhiker; 04-20-2012 at 08:08 PM. |
#3 |
Grenade Inspector
Thanks hitchiker! Couldn't ask for a better photo line up and explaination. The last pic with the channel to the bottom of the frame would just about do it.
__________________
Semper Fi |
#4 | |
Alliance Member
Quote:
the rear is still a little high for my taste. I think the car you pictured has a spring behind rear end. this is what I am going for. Last edited by Hitchhiker; 04-20-2012 at 08:17 PM. |
| Thread Tools | |
| Display Modes | |
