Reply
Thread Tools Display Modes
Old 04-04-2012, 04:55 PM   #1
Rpmrex
Rpmrex's Avatar
Default How much pressure does a stock mechanical fuel pump have?
I have a 350 with a stock fuel pump and just bought 2 rodchester carbs set on a vintage speed 4 to 2 adapter. Will I need a regulator or does the stock chevy fuel pump not pump enough to wory about it?
How much does a stock pump, pump?
Whats the best pressure for the rodchester 2G's?
offline   Reply With Quote
Old 04-04-2012, 05:03 PM   #2
Stroker McGurk
Grenade Inspector
Default Re: How much pressure does a stock mechanical fuel pump have?
Stock pump is usually under 6 lbs, which should be fine for those carbs
Old 04-04-2012, 06:30 PM   #3
Mat Thrasher
Alliance Member
Mat Thrasher's Avatar
I don't know about the pressure of a mechanical pump. But I run my 2GC's at 3 PSI. It seems to work good on my set-up.
Old 04-04-2012, 06:31 PM   #4
1971BB427
Old School HAMBer
1971BB427's Avatar
I'd put a pressure gauge inline after the pump. I've seen stock SBC mechanical pumps put out as high as 9 lbs., and when they do they always cause carb problems. Been there, done that.
Old 04-04-2012, 06:34 PM   #5
XXL__
XXL__'s Avatar
3-4# is good for those carbs. Mechanical pumps are all over the place, depending on manufacturer, model, batch, condition, etc. Stick a gauge on it, at least... so you know what's going on, and possibly a regulator so you don't feed the carbs too much.
Edit: What the post before me said.
Old 04-04-2012, 06:41 PM   #6
n847
Old School HAMBer
n847's Avatar
I would expect 3-5 lbs if its a bone stocker but we put one on a stroker motor that ran 7-9 and it "looked" like a bone stocker!
online   Reply With Quote
Old 04-04-2012, 07:13 PM   #7
Saxman
Alliance Member
Saxman's Avatar
Location: Fallbrook, California - Home of Don Montgomery & Dode Martin
My stock pump runs about 5-6 lbs. I also run about 3 lbs on my 2gs. You will probably need a regulator but you could try it without first and see how it goes.
Old 04-04-2012, 07:25 PM   #8
31Vicky with a hemi
Alliance Member
31Vicky with a hemi's Avatar
Just a thought,,,,,
Every pump is going to be a little different, so far on this thread we've heard from 3 to 9 psi.
It's imperative that you know the pressure going into the carb in order to properly tune, diagnose, and troubleshoot any fuel delivery problem.
,,,,, after you get it mounted put a gauge on it. Make your call on a regulator then.
record the pressure someplace as " fuel pressure new psi X " that way in a few months when you want to post a " car acting funny, why ?" Thread, you'll be able to tell what was and is the fuel pressure. That will save you so much tail chasing.
__________________
Thank you, I will be installing a breathalyzer on my keyboard
the hamb relay network
http://www.jalopyjournal.com/forum/g...hp?groupid=214
Old 04-04-2012, 07:27 PM   #9
putz
Grenade Inspector
3 pounds...............
Old 04-05-2012, 07:50 AM   #10
carbking
Senior Member
carbking's Avatar
How much does a stock pump pump? Depends on the design and quality control of the pump. Even some name brand pumps produced today (made in a different country) have been measured above 15 psi!!! A fuel pressure gauge is going to be your only definative answer.
What is the best pressure for the Rochester 2G? Depends on fuel valve orifice, float height, and the bouyancy of the float used (several different were used in various 2G series carbs). With a STOCK tripower on a 1964 GTO I ran 5 1/2 to 6 psi with zero issues. Carbs were originals, with original floats, and the correct fuel orifices.
Edit - the phone hasn't started yet, so checked two common 2G fuel valves used by Chevrolet: one was a 0.082 orifice, the other 0.120. I suspect if one checked some other brands (maybe the 2G used on the Pontiac 455 and the 2G used on the Mercury marine small six) the range would be even greater. Now which valve is in that universal kit you buy at the FLAPS that services 792 different carburetors?
Jon.
__________________
Good carburetion is fuelish hot air!
The Carburetor Shop of Missouri 573-392-7378 (9-4 M-Tues CT)
Old 04-05-2012, 08:08 AM   #11
Truckedup
Old School HAMBer
Truckedup's Avatar
Got a large base brass float 2G being fed with an electric pump at 5 psi.No flooding or rich idle problems even after a hot restart.
Old 04-05-2012, 10:54 AM   #12
tommy
Old School HAMBer
tommy's Avatar
I've never had a problem with the Rochester carbs. I ran a Rochester on my old Chevy with an electric pump and no regulator. The Rochester carbs came stock from the factory on Chevys on a stock mechanical pump and no regulator. It's the 97s and 94s that seem to be more pressure sensitive.
That being said I have 2 97s running on my stock Studebaker mechanical pump with no regulator at all. I bought it that way and the need never came up. I bought a kit and rebuilt the stock pump. I don't look for problems so I just go with the flow if it wants to flood then by all means add a regulator but I don't assume that there will be a problem before it occurs.
Electric pumps with 97s are different animals of course. IMHO.
__________________
Quote...You are hereby Knighted...'Sir Asseth of Hole' Tommy... 3W Larry.
Quote...It's called "HOT RODDING", not paint by numbers....Fab32
Old 04-05-2012, 07:01 PM   #13
brokenspoke
Alliance Member
brokenspoke's Avatar
GMC Bubba has a great tech on testing fuel pressure W/O a guage
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
