Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 04-03-2012, 07:00 AM   #41
striper
Alliance Member
striper's Avatar
Default Re: KIWI MADE 1927 T Lakes modified - Journey to the end of the road!
Holy shit man! Some of us can build cars but others take it to a new level altogether.
Between you and Surf City with his '36, I'm all set for entertainment for the next few weeks I'd say.
__________________
VULTURES
Australia
Your concerns about whether what you are about to do is going to end well, are well founded.
online   Reply With Quote
Old 04-05-2012, 01:39 AM   #42
woodbox
woodbox's Avatar
Quote:
Originally Posted by ForEverFour View Post
Looking really good Wade - cant wait to see it all finished!
Quote:
Originally Posted by kiwijeff View Post
Great stuff. Im looking forward to seeing it completed.
Thanks Guys....no one more so than me too!!! It has been a long haul, but it won't be long.....soon!
I found some real early shots of the mock up, on my work computor. Note the wooden chassis and grill suround!
I also found some pictures of the steering wheel I mentioned earlier. I couldn't up load the version of this from home, but it seems to have worked from here.....go figure!!
Tomorrow I should get some more panels prepped for the painter, and might even get some new pictures to post.
Click image for larger version
Name:	wade and karena 021.jpg
ID:	1606961   Click image for larger version
Name:	wade and karena 020.jpg
ID:	1606962   Click image for larger version
__________________
There is only one sure thing in this life.....and that's doubt.....I think!
offline   Reply With Quote
Old 04-05-2012, 02:01 AM   #43
Beau
Senior Member
Beau's Avatar
Is that a 215?
Old 04-05-2012, 03:27 AM   #44
woodbox
woodbox's Avatar
Quote:
Originally Posted by Beau View Post
Is that a 215?
Yes it is! Well spotted! I am waiting for it to be assembled at the moment
It has had a 40thou over bore, new cam, balanced spinning bits, and some porting and modern seals.
I am looking forward to firing it up soon too!
__________________
Old 04-05-2012, 11:33 PM   #45
Beau
Senior Member
Beau's Avatar
I'm doing the same thing in my modified!
Old 04-06-2012, 02:53 AM   #46
woodbox
woodbox's Avatar
Don't be holding out on us.....let's see it!
__________________
Old 04-07-2012, 05:13 AM   #47
woodbox
woodbox's Avatar
Foundations maketh the house! A little insight into the chassis.
Right from the outset I wanted to build this car around a tube frame chassis. The inspiration for this was from a number of places, including a 1927 T built by Ken Robesky that I saw in a magazine. His was a more contemporary looking car, but I thought that there was no reason it couldn't be done using some more traditional parts.
The tube is 38mm OD seamless boiler tube with 3.6mm wall thickness, any amount strong enough, but I was not too worried about weight because of the plans to use the Aluminium Buick 215 cu in V8. I did a lot of the cutting with 38mm hole saws carefully in the drill press. Plenty of cutting fluid and a little dressing with a file or grinder. I used some sand filled and compacted method for hot bending of various parts.
When I was happy with the majority of the frame a friend of mine helped out with the welding (his tickets were current, mine weren't). After the bulk of the welding was complete, I found that there had been some movement of the main bottom rails and they had developed a 'Sag'. So I had to make good use of the heavy duty bench, on which the chassis was made, and a gas torch and some pressure aplication in the appropriate places. Long story short....it is straight again!
I think that this should make a fairly stiff sort of a platform for this project and eagerly await the day I get to take it for a blast through some of the hills and corners in this part of the country.
Take a look at the pictures any way.
ID:	1608220   Click image for larger version
ID:	1608221   Click image for larger version
ID:	1608223   Click image for larger version
ID:	1608224   Click image for larger version
Name:	lakester july 05 008.jpg
__________________
Old 04-07-2012, 05:32 PM   #48
fleet-master
Senior Member
fleet-master's Avatar
shit yes...its gona be fun scootin through the Brynderwyns or the infamous Mangamuka Gorge in your wee car Wade!! Should still corner good with a 120" wheelbase?
__________________
My track roadster build : http://www.jalopyjournal.com/forum/s...d.php?t=542829
Old 04-08-2012, 04:40 AM   #49
woodbox
woodbox's Avatar
Quote:
Maungamuka's was the one I was thinking of too! can't wait!
__________________
Old 04-10-2012, 03:25 AM   #50
woodbox
woodbox's Avatar
Spent this afternoon sanding and prepping some more panels. I dropped them off to the painters today. He has the other panels all undercoated and ready for a sand then some color!! Woohoo!
Any way here are the panels I took over today.....lookin all shiney!
__________________
Old 04-10-2012, 03:38 AM   #51
RussTee
Now your cooking love that chassis!
Old 04-11-2012, 04:29 AM   #52
woodbox
woodbox's Avatar
Rod (the painter) is screaming out for more panels to paint, so I spent today tearing the last of the panels off the chassis. I had to roll the axles out from under it too. Now there is just a bare frame sitting in the middle of the shop on stands! I guess that some time you have to go backwards to go forwards. I will prep the remaining panels on my next days off (shift work) and get them away to paint. It will be a busy week! I had to shoot into town and get some more sand paper and brushes for my grinder this afternoon. While I was in town I dropped the intake manifold and Carb off to Trevor (Mechanic assembling engine).
__________________
Old 04-15-2012, 12:27 AM   #53
woodbox
woodbox's Avatar
Last night I managed to get a whole bunch of parts into the bead blaster and tidy them up ready to go to the painter this week. Work again to night and meetings for the show tomorrow so I can't see much happening on the car for the day. Four days between shifts is not enough to get everything done!!! I need to take some leave to spend some more time on it but I have nearly run out for the year! Roll on July when we get our new allocation of leave!!
__________________
Old 04-15-2012, 01:32 AM   #54
SamIyam
Old School HAMBer
SamIyam's Avatar
Great work... I really like the design of the tube chassis.
What I like most is that I could go for a ride it in and feel like I am driving.
You should put another steering wheel on your passenger's side there...
Sam
__________________
SBC's rule... all others drool.
Old 04-15-2012, 03:02 AM   #55
woodbox
woodbox's Avatar
Sam
I could just whip the quick release wheel off and hand it to you while we driving!!!
__________________
Old 04-18-2012, 05:46 AM   #56
woodbox
woodbox's Avatar
I was able to spend a few hours today on some more prepping panels for the paint shop. Tomorrow I hope to finish up on the last of them and deliver to paint. I will post pictures of the last batch to go. Next week I will finish weld the chassis and put together a rotissery for the guy doing the blasting and painting.
__________________
Old 04-19-2012, 03:16 AM   #57
woodbox
woodbox's Avatar
Another batch of panels off to the paint booth. Only the dash and glove compartment lid left to do next week.
Name:	P1030445 (1024x768).jpg
ID:	1618489   Click image for larger version
Name:	P1030446 (1024x768).jpg
__________________
Old 04-19-2012, 03:36 AM   #58
LIFESTYLZ
Old School HAMBer
LIFESTYLZ's Avatar
Looking good.
You are doing a great job there mate.
Old 04-19-2012, 03:52 AM   #59
woodbox
woodbox's Avatar
Quote:
Originally Posted by LIFESTYLZ View Post
Looking good.
Cheers Mate! This is the exciting end of the job. Time to get fussy!
__________________
Old 04-19-2012, 05:00 AM   #60
Kiwi Helrod
Grenade Inspector
Kiwi Helrod's Avatar
Why haven't we seen this else where.
Looks bloody awesome.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
