Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#21 |
Senior Member
#22 |
Grenade Inspector
hey thanks every one.I will use a relay on the pump and fan.I found some more wire diagrahms wich one of these is correct or is the87 and 30 terminal in or out?
#23 |
Newbie
Here you go, read this:
http://www.how-to-build-hotrods.com/...fuel-pump.html It has all the info on how to do your electric fuel pump the right way, what kills electric fuel pumps, and diagrams on wiring it up...
__________________
www.how-to-build-hotrods.com |
#24 |
Grenade Inspector
i like the oil pressure switch cutoff idea with a primer button. never would have thought of this. thanks to everyone...jack
__________________
Proud FNG |
#25 |
Senior Member
I hate inertia switches. I hate complicated things as well.
Relays are a great idea. The relay simply is an electric switch. So you have the power wire going to the relay then out to the pump. You have a thinner wire that activates the relay. The purpose of this, is to reduce switch failure, on longer runs of wire. My biggest reason is, its a pain the a$$ having thicker wire connected to a switch, Thinner is neater, and out of the way, this also adds to safety. So its a win win. |
#26 | |
Grenade Inspector
Quote:
#27 |
Alliance Member
30 is power in
85 is ground 86 is switched power in The 87 pins are power out I also believe 85 and 86 can be swapped with no effects.
__________________
Joe My 1930 Ford Coupe build thread. http://jalopyjournal.com/forum/showthread.php?t=626730 |
#28 |
Alliance Member
Remember to put your fuse as close to the battery as possible.
__________________
#29 |
Senior Member
my rule of thumb is to put anything of somewhat heavy amp draw on a relay.. it takes the amperage off the switch, which is a good thing. and seeing relays are about 7 bucks it should be a no brainer...
__________________
No trees were killed to send this note but a large number of electrons were terribly inconvenienced |
#30 |
Old School HAMBer
The first 55 years of my hotrod life we never used a relay. The last ten there has been a big change on the internet anyway. To me a relay is just something else that can break and leave you on the side of the road. Of course I'm talking about the old Dupree/ SW style and other electric pumps for carbs. I always wire it through the key switch so I don't forget to flip the switch. I just turn the key to "on" and listen until clicking slows down, pump the gas twice and start it up. I believe in the KISS system. The less parts to break....the better. JMO
__________________
Quote...You are hereby Knighted...'Sir Asseth of Hole' Tommy... 3W Larry. Quote...It's called "HOT RODDING", not paint by numbers. ![]() ...Fab32
#31 |
Senior Member
yea tommy I did it the same way as you but now I run relays on everything and think it is better. That could by oldtimers though!!!!!!!!
__________________
your old when everything reminds you of a story,,,I have a lot of stories |
#32 |
Grenade Inspector
why is it I see diagrahms with 30 out and 87in?
#33 |
Senior Member
Relays, Always !!
#34 | |
Senior Member
Quote:
P.S. i still don't fully understand relays, because there is still small gauge wire running to and from the relay---i thought the reasons for relays is to be able to handle high amp loads without overtaxing switches and smaller gauge wiring? |
#35 |
Grenade Inspector
The point is to avoid voltage drops across the switch, and the arcing that occurs on a switch when its "switched". The smaller guage wire is to actuate the relay/switch and complete the circuit on the larger guage wire. The relay is only breaking one side of the feed voltage.
#36 |
Old School HAMBer
Think of your starter solenoid as a relay, you wouldn't want a huge switch on the dash.
It's basically just a remote switch with heavy duty terminals to pass large current a small switch couldn't handle. Most quality relays have the circuit diagram on them so it's easy to understand. Sent from my iPhone using TJJ app
__________________
Steve Checkout my Willys project here http://jalopyjournal.com/forum/showthread.php?t=572303 |
#37 | |
Alliance Member
Quote:
Because the relay is also protected. The light gauge wires control the relay. A relay is an electromagnetic contactor (electric switch) that can be controlled with very little amps and a very light duty switch. The relay can control very high amperage load.
__________________
Thank you, I will be installing a breathalyzer on my keyboard the hamb relay network http://www.jalopyjournal.com/forum/g...hp?groupid=214 |
#38 |
Senior Member
What size wires would go to 30 and 78 in the fuel pump diagram?
b) What about for an electric fan? |
#39 | |
Senior Member
Quote:
#40 |
Grenade Inspector
Go to salvage yard,roll over switch in big fords is located in trunk lft side behind card board. they work great>
| Thread Tools | |
| Display Modes | |
