Go Back   THE H.A.M.B. > Archives > Tech Archive
Reply
Thread Tools Display Modes
Old 03-05-2012, 09:23 AM   #21
flatheadpete
Old School HAMBer
flatheadpete's Avatar
Default Re: Tech Week !!! Hot Rod Suspension Simplified!
So basic yet it works everytime! Thanks.
__________________
'Armin Tamzarian's reign of terror is over!'
-Superintendent Chalmers
offline   Reply With Quote
Old 03-05-2012, 09:52 AM   #22
Rich Wright
Rich Wright's Avatar
Beautiful, Sam...
__________________
I'm too old to be cool...and pretty happy about it, too.
online   Reply With Quote
Old 03-05-2012, 09:58 AM   #23
pasadenahotrod
Old School HAMBer
Great post, well illustrated and explained BUT I believe you left out one important measurement.
At least 1" should be added to the dimension for eye to eye measurement for the rear spring mounts, or front spring mount as well, to spread the spring and put the spring under tension as Ford designed it to avoid having to install a Panhard bar to limit sway. You probably did this but just left it out in error.
Using your dimensions would mount the spring like the stock 42-48 Ford design to make a softer ride which do NOT have the spring installed under tension when mounted so Panhard bars are required front and rear.
Old 03-05-2012, 11:56 AM   #24
COOTER
Senior Member
COOTER's Avatar
Exactly what I had planned on for my A build. Now I could use this for reference. Great tech! Thanks.
Old 03-05-2012, 12:00 PM   #25
3wLarry
Old School HAMBer
3wLarry's Avatar
cool thread...
Old 03-05-2012, 01:23 PM   #26
Southfork
Senior Member
Yes, Henry did have it right. He used those wishbones for about 40 years!
Thanks for the reminder as to why he did that.
Old 03-05-2012, 01:30 PM   #27
SamIyam
Old School HAMBer
SamIyam's Avatar
I probably need to clarify what I was saying... because when it's all said and done, I think we'll be on the same page.
I used a '40 Ford spring... and used the '40 Ford rear end that the spring came off of to get my measurements from "eye to eye" on the rear end.
When the body is off of the chassis, and all of the springs are in the spring pack, the spring is definately under tension, in fact... it's under the same tension as it was stock, because the mounting points on the rear end for the shackles, are the same.
If you use the stock measurements, especially on a light car, there is no need for a panhard bar.
I removed a couple of springs to make it right... as the stock '40 spring pack is a bit stiff for a Model A.
The real test will come when I get my first drive.
Sam
__________________
SBC's rule... all others drool.
Old 03-05-2012, 02:43 PM   #28
Beau
Senior Member
Beau's Avatar
EXACTLY what I'm working on building now. The other threads on here have sparse info. This is a WINNER IMO.
Great job!
Old 03-05-2012, 02:48 PM   #29
39cent
Senior Member
39cent's Avatar
I did this baknthday but welded some metal along the top and bottom of the rear wishbones, to add strength for open drive. Fords wishbone setups were used on many 200 mph lakes cars.
__________________
"If you think you can do
a thing or think you can't do a thing, you're right".- Henry Ford,
Old 03-05-2012, 02:55 PM   #30
Max Gearhead
Alliance Member
Max Gearhead's Avatar
Thumbs up Re: Tech Week !!! Hot Rod Suspension Simplified!
Excellent thread!
__________________
Join the 348-409 Chevy group.
http://www.jalopyjournal.com/forum/g...hp?groupid=125
http://www.rumblefest.net/
RUMBLE FEST, be there or be square.
Primates CC
Old 03-05-2012, 02:55 PM   #31
40FordGuy
Senior Member
Nice !!!!!!!!!!!!!!!
4ttruk
Old 03-05-2012, 03:37 PM   #32
barrnone50
Grenade Inspector
barrnone50's Avatar
Real super clean Fab job..Great Tech very informative and helpful for future builds for my next ride. Is the frame your handy work also?
Old 03-05-2012, 03:49 PM   #33
Cali4niaCruiser
Grenade Inspector
Cali4niaCruiser's Avatar
You get my vote so far!
Old 03-05-2012, 04:52 PM   #34
striper
Alliance Member
striper's Avatar
Quote:
Originally Posted by SamIyam View Post
One thing I wish I had known before I did mine was the affordability and availability of these. Would have save me cutting the ball cup out of an otherwise perfect '48 frame.
__________________
VULTURES
Australia
Your concerns about whether what you are about to do is going to end well, are well founded.
Old 03-05-2012, 05:49 PM   #35
SamIyam
Old School HAMBer
SamIyam's Avatar
Quote:
The frame is actually a new raised and narrowed perimeter frame from these guys:
http://www.classicstreetrodmfg.com/model_a.html
I called them up and had them deliver it to the Turlock Swap Meet in January of 2011.
The basic frame was $700...
I should also bring up the idea of a "Torque Arm".
A good friend of mine is using this system in the rear of a roadster. He wanted a little extra insurance... and added a torque arm from the top of the rear end to the yoke.
I personally do not think it is needed... especially if you gusset all of your joints.
If you think about it... it is common practice to run wishbones, albeit split, on the front of our hot rods.
Cars stop much faster than they accelerate. So, the forces exerted on the front wishbones are greater than can be exerted on the rear 'bones.
In addition, with tires that spin... the force is even less on the rear 'bones.
I have a theory that the reason people have cracked or even broken rear wishbones is because they are split, therefore may be experiencing torsional stress... and depending on how they are anchored to the frame... results can be disasterous.
Sam
__________________
Old 03-05-2012, 06:55 PM   #36
HarryT
Alliance Member
HarryT's Avatar
Great thread Sam. Beautiful workmanship.
Old 03-05-2012, 07:23 PM   #37
reece
Grenade Inspector
reece's Avatar
My vote is for this thread. Nice work and good pics.
Old 03-05-2012, 07:42 PM   #38
VoodooTwin
Senior Member
VoodooTwin's Avatar
Great tech thread! Glad to see this method (unsplit bones rear suspension design) is gaining traction. I did the exact same thing on my '33 frame, but not nearly as nicely as yours. Great workmanship!!
__________________
Concrete Jungle where dreams are made of
Old 03-05-2012, 07:42 PM   #39
Firepower71
Alliance Member
Firepower71's Avatar
Great explanation, awesome work. Thanks!
Old 03-05-2012, 08:05 PM   #40
64ONEOFF
Alliance Member
64ONEOFF's Avatar
I have always been interested in building a Tradtional car. I have been doing research and just talking to people. I REALLY ENJOYED YOUR POST. Thanks for the info.... And your right most cars and sedans usually DONT have a rear seat. Just a huge hump... I like your way much better
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
