Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 |
Grenade Inspector
i am getting ready to put in my 354 hemi crank in the block, i plan on using a adapter plat for a chevy trans. can i tap the rear treads on the crank flange 1/2-20 or leave it like it is, i remember the %$%#@#$ i had to take the old bolt out, if i can tap them and make it easier to work on later i would like that, i don't have the adapter kit now, so i don't see how the new automatic flywheel will attache, has anyone been there?
#2 | |
Alliance Member
Run a tap in them that is the same size as they already are. Your old flywheel bolts may have had locktite or the equivalent there of on them, that was a common practice in the 50s.
Quote:
__________________
If it don't make ya dirty it ain't yours No man crosses a chasm in two jumps |
#3 |
Grenade Inspector
the hole have no tread from the factory, you have to get inbetween the block and crank flange with a wrench to hold the nut and unscrew the bolt on flywheel side, not fun when the engine is seized. i heard that people tap the holes and put bolt that tread directly in flange.
#4 | |
Alliance Member
Quote:
__________________
#5 |
Grenade Inspector
the engine was seized when i bought it, i am rebuiling it now, i want to find out now if i can tap the holes, i would like to install the crank tonight
#6 |
Newbie
If the engine is siezed you will remove it from the car & tear it down so it dosent make any differance how the flywheel is attached to the crank.
#7 |
Alliance Member
You can tap the holes for bolts. I've done a few Studebaker cranks this way. Good sharp taps and lots-a-lube.
#8 |
Old School HAMBer
The usual is to run the 1/2-20 tap through it & use whatever modern flywheel/flex plate bolts you'd use on a newer engine. Beats the nuts & bolts OEM set up.
__________________
Confucious say Tennis elbow better than Tennis balls |
#9 |
Grenade Inspector
thanks, George do you kno if adapter kits come with nut and bolt or bolt to srew into flange, and if i tap them anyway and end up using the nut and bolt option the treads in the flange should not affect anythings?
#10 |
Old School HAMBer
The most common fasteners will be ½-20 cap screws so you will need to tap the holes in the flange, HOWEVER, you should verify this with whomever makes the adapter.
For manual trans, some adapter packages can actually use the original style flywheel and the clipped head bolts...but only some...verify. Word of caution at this point. Be damned sure that the tap runs perfectly parallel with the crank centerline. Bolts running on some bastard angle will not be able to provide the necessary clamping force and you could have the flywheel/converter in your lap. I have pics of a simple tapping fixture on my web site. .
__________________
www.qualityengineeredcomponents.com Early Hemi Parts, Pieces, Tech Trans adapters for EarlyHEMI, Flat 6&8 and pre-62 A series http://www.discoverthenetworks.org/Articles/Hansen.pdf |
#11 | |
Old School HAMBer
Quote:
Actually if you needed to run the OEM bolt n nut set up you could still install 1/2-20 bolts & nuts if you could find the right head thickness.
__________________
#12 |
Senior Member
The bolts come with my adapter kits. They are Grade 8+ and 1/2-20 thread.
__________________
TR Waters Early Hemi Parts Early Hemi to SB Mopar Trans Adapters www.trwaters.com |
#13 | |
Old School HAMBer
Quote:
Tom, are you making a shiverlay adapter? If so, I'll send those stray calls to you instead of ignoring them... ![]() .
__________________
#14 |
Grenade Inspector
thanks guy's, i will tap them 1/2-20 for now and when it comes time to get an adapter kit will check with you's.
#15 |
Senior Member
The 1/2-20 Tap trick is the most common modification. Run the Tap and don't look back.
Tim |
#16 |
Grenade Inspector
I taped mine1/2 -20 using a hot heads flywheel
#17 |
Old School HAMBer
Never used a flywheel for that before!
__________________
#18 |
Alliance Member
^^^^ Now that is funny!
#19 | |
Senior Member
Quote:
__________________
#20 |
FNG
Late reply! Had to tap my 331 crank. Couldn't get a wrench behind the flywheel with the Hemi to Ford man adapter plate on
| Thread Tools | |
| Display Modes | |
