Reply
Thread Tools Display Modes
Old 03-10-2012, 06:38 PM   #1
firstgear
Newbie
Default Anyone run two 6 volt batteries in series for 12 volts?
Trying to find the best way to package 12 volt battery in the Model A. One thought was two 6 volt batteries in series. The batteries are narrow and can be run along the frame without getting into the exhaust.
Anyone use dual 6 volt batteries?
offline   Reply With Quote
Old 03-10-2012, 06:42 PM   #2
Iron Dog
Alliance Member
Iron Dog's Avatar
Default Re: Anyone run two 6 volt batteries in series for 12 volts?
Did on a 1948 Jeep CJ2A. Just to start, but it worked really good.
__________________
Some mistakes in life are just too much fun to make only once.
Old 03-10-2012, 06:42 PM   #3
GREASER815
Alliance Member
GREASER815's Avatar
Some older IH tractors do. Works fine.
Old 03-10-2012, 06:45 PM   #4
ThunderRocket
Senior Member
ThunderRocket's Avatar
MGB's were like that until 1974, but the batteries are bigger than a 12v Miata AGM battery.
__________________
1962 Thunderbird
1941 Chevrolet coupe
1959 Edsel Villager
1963 Skylark
1964 Chevrolet Pickup
Old 03-10-2012, 06:47 PM   #5
Hot Rod Grampa
Newbie
Hot Rod Grampa's Avatar
Running them is series is very common. Has been done on all types of equipment. Not sure you need to go to that effort. Many new batteries are available in a compact package eliminating the extra weight, wiring and work to build a second battery box, holdown braacket etc. you get the idea. Secondly, both batteries must be maintained and if one weakens, it will pull the second one down also. Good luck.
__________________
No Billet, No Bytes, No Bull!!
Old 03-10-2012, 06:54 PM   #6
XXL__
XXL__'s Avatar
If space is your concern, take a look at Braille batteries. Decent amperage, tiny, and already 12v.
Old 03-10-2012, 07:31 PM   #7
1oldtimer
Old School HAMBer
1oldtimer's Avatar
done on hd trucks to get high amp 12v (3 12v batteries), you could look into commercial batteries. I found a 12v bus battery that would fit into a '50 buick 6v battery tray (long and skinny).
__________________
#1 Post killer
Old 03-10-2012, 08:32 PM   #8
woodypecker
Grenade Inspector
woodypecker's Avatar
If size matters get a coupon from most any car magazine and go to Harbor freight and buy their jump start battery and remove the outer case and you will have a battery like a Mazda Miata for about $35. It also has a built in battery charger,
Old 03-10-2012, 08:45 PM   #9
haychrishay
haychrishay's Avatar
Default
I did it in my track roadster
Old 03-10-2012, 08:55 PM   #10
CapeCodBob
CapeCodBob's Avatar
Stacy David did that on his green roadster. Put them behind the seat.
__________________
BUY AMERICAN MADE
KEEP AMERICANS WORKING
Old 03-10-2012, 08:57 PM   #11
pasadenahotrod
Old School HAMBer
Many of the British sports cars had a pair of 6V batteries in series mounted one on each side of the car: Jag XK120, 140, 150, MGA, MGB and others. Very common in Euro cars back when.
Old 03-10-2012, 08:58 PM   #12
cosmo
Old School HAMBer
Almost everything British in the 60's did that. Seems like there was a surplus of 6 volt batteries or something.
Anyway, cars, bikes, and probably mopeds had two 6 volts in series in England during the 60's
Cosmo
__________________
Life is too important to be taken seriously
Old 03-10-2012, 09:12 PM   #13
ktc31coupe
FNG
ktc31coupe's Avatar
I run two Optima 6 volt batteries in my coupe. One on each side of the gas tank in the trunk. There wasn't room for one 12 volt and it works great.
Old 03-10-2012, 09:42 PM   #14
gnichols
Alliance Member
gnichols's Avatar
Quote:
My vote, too. Why add the weight of a second battery when there are newer versions that will work in your old location. Gary
__________________
Nostalgia isn't what it used to be.
http://www.jalopyjournal.com/forum/a...p?albumid=2874
http://public.fotki.com/kitbashr/
Old 03-11-2012, 10:01 AM   #15
firstgear
Newbie
Quote:
The old location is behind the passenger seat. I want to get the battery out of the car and under the car. There is a nice gap between the body and the frame rails.....if I can fit a Braille battery in there, I will be good. They have some interesting sizes. I figure I will cut up some cardboard in the battery plus holder size, and see where it can fit....the interior was just redone and without the battery behind the passenger seat, the rumble seat area has more area for legs and storage.
Old 03-11-2012, 11:56 AM   #16
davedeltadog
Grenade Inspector
davedeltadog's Avatar
Quote:
The way to go, why mess with two when one little jellcell will do. My car has very limited space so I use a jellcell 7"X6 3/4"X3 1/2". It can be mounted in any position and will hold a charge for years. Cranks a 300hp SBC all day long.
Old 03-11-2012, 12:56 PM   #17
Alliance Member
Mr48chev's Avatar
There is a series of batteries made to go inside cars that has a vent hose that leads out though the floorboards built in. Almost every VW, Mercedes, Audi and other German car uses one under the back seat. At least up though the late 80's. They are pretty low profile too and the one for a 85 Audi 5000S has a pretty good amp and cold start rating. That's going by the one I had a few years ago.
I've had batteries on somewhat hard to reach locations before and it isn't fun to have to take the car half way apart or crawl under it in the mud (they never seem to crap out on dry clean pavement) to reach the battery.
__________________
Happiness is having a garage big enough to hold all ttools and projects and small enough to keep warm enough to work in the winter.
Old 03-11-2012, 01:38 PM   #18
rainhater1
Talking Re: Anyone run two 6 volt batteries in series for 12 volts?
I have the battery under the right front fender, have to remove the wheel to get to it. I just ran a battery cable from the pos side up into the motor area so I can jump or charge it. put a piece of hose over the end so it wont short out.
Old 03-11-2012, 01:59 PM   #19
40FordGuy
Old School HAMBer
GM did that with early 50's Cadillac "Fleetwood Limo" series,...Used two of the long, narrow 6 volt units, one one each side, in fenderwells. It worked,......As did the aforementioned Euro cars.
4TTRUK
Old 03-11-2012, 04:22 PM   #20
XXL__
XXL__'s Avatar
Quote:
I use these mounted to the frame rail, within easy reach, either from the hood opening or the wheel (if I turn it to the left). They are self-insulating, so you just drill a hole in the frame and mount them.
Old 03-11-2012, 05:57 PM   #21
gnichols
Alliance Member
gnichols's Avatar
A few more thoughts... multiple batteries add more wiring and therefore more connectors. Just a few more tid-bits to run / clamp, come loose or corrode in the overall system. I've only built two cars, but learning from both I'd say easy access / easy charging or jumping is far more important than location (or a well placed remote cut-off switch / charging plug) but placement is still a big consideration.
My first ride had a Moroso drag racing style battery box in the trunk and it was hidden by an interior panel. Trick I thought. Turns out... not so cool. It took about 8 screws to get the cosmetic panel and the box top off to reach the battery. A PITA for charging /jumps, and even more so with a load of crap in the trunk. I also had a set of those big red / black charging posts in the rear pan. I never had to use them, but if you do be sure to mount them far enough apart that you can't accidentally short them out when attaching the jumper cable clamps or if the clamps happen to rotate around the posts and touch.
The 27's battery is under the bed and has fairly easy access. I do have a weatherpack pig tail for trickle charging, but the jumper plug is still in the box. Unlike the big posts, I'll be using one of the smaller jumper plug sets sold for the trailer / RV guys this time. The only draw back is that I'll have to fab up a special set of jumper cables with one end to match the female plug in the truck.
The next build will have a quick release cover over the battery box (no fasteners) and unobstructed, quick access from above (while the cut-off / charge plug may still be mounted some place else). Having to crawl under the car or use a lift to reach / replace the battery makes no sense at all, IMHO, but at least a trap door of some sort in the floor improves that arrangement. Gary
__________________
Old 03-11-2012, 06:00 PM   #22
BJR
Senior Member
BJR's Avatar
53 Olds & 54 Buick used a long skinny 12 volt battery, why not use one skinny 12 volt instead of 2 skinny 6 volts?
Old 03-11-2012, 07:44 PM   #23
firstgear
Newbie
Those are nice to have!
Old 03-11-2012, 08:22 PM   #24
DJCruiser
Grenade Inspector
DJCruiser's Avatar
Quote:
I had a Studebaker with the long skinny battery and got replacements from Caterpillar.
Old 03-11-2012, 09:10 PM   #25
Faus
Grenade Inspector
Faus's Avatar
Default
I go to Autozone, the guys there are good guys... Well the ones I live near. Most of them are car guys themselves; and they hook a guy up and help out if asked. Awesome dudes.
Old 03-12-2012, 07:19 AM   #26
sunfighter
Grenade Inspector
sunfighter's Avatar
Quote:
Cosmo
when my aunt came from England to live with us, she brought her metropolitan. had jumbo twin batteries in it.(didn't see the need for that kind of power to start a 4 cyl austin motor)so I asked her why, she said at the time it was law that any disabled vehicle had to have the capacity to leave parking lights on at all times.
Old 03-13-2012, 11:51 AM   #27
XXL__
XXL__'s Avatar
Quote:
We DEFINITELY have different Autozone staff than you.
Old 03-13-2012, 09:19 PM   #28
firstgear
Newbie
Thanks everyone. The Braille battery while only about 460ccamps will fit and they make a decent battery holder for it (seriously over priced). Thanks for pointing me in that direction. Herb
Old 12-30-2012, 02:50 PM   #29
groundpounder
Alliance Member
groundpounder's Avatar
Hey guys ..was reading on the battery situation here......notice them heavy expensive battery charging lugs. I've made my own charging lug posts.....using the smaller rubber valve stems,....making a mounting plate,...pulling the stem thru......removing the valve core and soldering a 10 Gage wire to the end where the core installs. The other end to battery. Screw the cap back on and it's covered.....
__________________
Some people pay for this comedy act!....I get it for free!....
Old 12-30-2012, 03:30 PM   #30
MeanGene427
Senior Member
The long skinny ones like the IH tractors (and my little 6V Clark Trukloader forklift) used are also available in 12V- Tractor Supply has them in stock
__________________
A car with a Poser cam is like a girl with a stuffed bra, it's fake, and not much fun to play with
Old 12-30-2012, 05:15 PM   #31
alphabet soup
Alliance Member
'63 caddy used a long thin 12 volt.
Old 12-30-2012, 06:51 PM   #32
japar
Grenade Inspector
japar's Avatar
I have been known to put 2 12s together in a series in the winter to start my diesel. 24v makes that sucker crank! Just don't use the cigarette lighter
Old 12-30-2012, 08:58 PM   #33
MeanGene427
Senior Member
Here ya go
http://www.tractorsupply.com/exide-h...y-f3ee-0470556
__________________
Old 12-30-2012, 09:27 PM   #34
pasadenahotrod
Old School HAMBer
The group size of the long skinny 12V battery is 3EE most commonly used in forklifts. My old T roadster had one in it standing on the rear frame rail inside the abbreviated pickup bed between the "tailgate and the 28 Chevrolet gas tank. Easy to reach, easy to service, easy to remove.
Old 12-30-2012, 09:45 PM   #35
hd4unm
Grenade Inspector
Quote:
No challenge to pasadenahotrod, but just a point...that may help the OP.
I'm not a Euro guy but a friend had a '70 Porche 911 with two batts. They were well place in the nose (as many know) on opposite sides. I expect it was engineered that way as ballast/balance and not to add voltage but accommodate what they needed and enhance the car.
If I had to consider your options... I'd look at all the options and impact; maint. (number of connections, etc.), cost, weight, appearance, what else?
Personally, one batt is enough for me if it does the job.
Old 12-30-2012, 10:34 PM   #36
Dads426
FNG
Your 12-volt battery is really six 2-volt batteries (or cells) wired in series internally. Using two 6-volt batteries is acceptable as long as they are the same type. Very common in solar power systems. I've run 60 2-volt batteries in series for 120 VDC systems.
Old 07-25-2013, 11:45 PM   #37
dan c
Alliance Member
dan c's Avatar
i've heard that the theory behind two 6v batteries is that they provide more cranking power. a buddy had a 59 mga with that setup and the biggest bummer was that the batteries sometimes fell over!
Old 07-25-2013, 11:58 PM   #38
big daddy Raleigh
Grenade Inspector
big daddy Raleigh's Avatar
You could run two 12v motorcycle batteries in parallel. Wiring batteries in parallel batteries adds the amps- wiring in series adds the voltage.
__________________
Just because you can put tap shoes on an Elephant doesn't mean it can dance!
Old 07-26-2013, 01:59 PM   #39
40FordGuy
Old School HAMBer
GM did that with the 53 Cadillac Fleetwood "limo" body cars; Worked great.
4TTRUK
Old 07-26-2013, 02:16 PM   #40
mike in tucson
Grenade Inspector
mike in tucson's Avatar
How many flashlight batteries placed end to end in a round tube would it take to start a SBC?
Old 07-26-2013, 02:36 PM   #41
Bill Wright
FNG
I have two 6 volt optima's in my '37 Fordor.
12 volt's to start and run the electronic ignition on the '39 Merc Flathead.
This way I can take 6 volts off to run the rest of the accessories.
Old 07-26-2013, 02:53 PM   #42
EZ Cool
Alliance Vendor
EZ Cool's Avatar
My '49 John Deere A model tractor came from the factory like than. It had a 12 volt system before 12 volt batteries were available.
__________________
Alliance Vendor of
EZ Cool Insulation
Facebook Page
Old 07-26-2013, 03:09 PM   #43
TheTumbleweeds
Grenade Inspector
TheTumbleweeds's Avatar
koenigsegg uses two 6 volts, to keep weight balance perfect in the chassie
optima batteries, gel, you can place them any where, even on side and upside down,
pretty nice to hide
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
