Reply
Thread Tools Display Modes
Old 03-11-2012, 05:57 PM   #21
gnichols
Alliance Member
gnichols's Avatar
Default Re: Anyone run two 6 volt batteries in series for 12 volts?
A few more thoughts... multiple batteries add more wiring and therefore more connectors. Just a few more tid-bits to run / clamp, come loose or corrode in the overall system. I've only built two cars, but learning from both I'd say easy access / easy charging or jumping is far more important than location (or a well placed remote cut-off switch / charging plug) but placement is still a big consideration.
My first ride had a Moroso drag racing style battery box in the trunk and it was hidden by an interior panel. Trick I thought. Turns out... not so cool. It took about 8 screws to get the cosmetic panel and the box top off to reach the battery. A PITA for charging /jumps, and even more so with a load of crap in the trunk. I also had a set of those big red / black charging posts in the rear pan. I never had to use them, but if you do be sure to mount them far enough apart that you can't accidentally short them out when attaching the jumper cable clamps or if the clamps happen to rotate around the posts and touch.
The 27's battery is under the bed and has fairly easy access. I do have a weatherpack pig tail for trickle charging, but the jumper plug is still in the box. Unlike the big posts, I'll be using one of the smaller jumper plug sets sold for the trailer / RV guys this time. The only draw back is that I'll have to fab up a special set of jumper cables with one end to match the female plug in the truck.
The next build will have a quick release cover over the battery box (no fasteners) and unobstructed, quick access from above (while the cut-off / charge plug may still be mounted some place else). Having to crawl under the car or use a lift to reach / replace the battery makes no sense at all, IMHO, but at least a trap door of some sort in the floor improves that arrangement. Gary
__________________
Nostalgia isn't what it used to be.
http://www.jalopyjournal.com/forum/a...p?albumid=2874
http://public.fotki.com/kitbashr/
offline   Reply With Quote
Old 03-11-2012, 06:00 PM   #22
BJR
Senior Member
BJR's Avatar
53 Olds & 54 Buick used a long skinny 12 volt battery, why not use one skinny 12 volt instead of 2 skinny 6 volts?
Old 03-11-2012, 07:44 PM   #23
firstgear
Newbie
Quote:
Originally Posted by XXL__ View Post
I use these mounted to the frame rail, within easy reach, either from the hood opening or the wheel (if I turn it to the left). They are self-insulating, so you just drill a hole in the frame and mount them.
Those are nice to have!
Old 03-11-2012, 08:22 PM   #24
DJCruiser
Grenade Inspector
DJCruiser's Avatar
Quote:
I had a Studebaker with the long skinny battery and got replacements from Caterpillar.
Old 03-11-2012, 09:10 PM   #25
Faus
Grenade Inspector
Faus's Avatar
Default
I go to Autozone, the guys there are good guys... Well the ones I live near. Most of them are car guys themselves; and they hook a guy up and help out if asked. Awesome dudes.
Old 03-12-2012, 07:19 AM   #26
sunfighter
Grenade Inspector
sunfighter's Avatar
Quote:
Originally Posted by cosmo View Post
Almost everything British in the 60's did that. Seems like there was a surplus of 6 volt batteries or something.
Cosmo
when my aunt came from England to live with us, she brought her metropolitan. had jumbo twin batteries in it.(didn't see the need for that kind of power to start a 4 cyl austin motor)so I asked her why, she said at the time it was law that any disabled vehicle had to have the capacity to leave parking lights on at all times.
Old 03-13-2012, 11:51 AM   #27
XXL__
XXL__'s Avatar
Quote:
We DEFINITELY have different Autozone staff than you.
Old 03-13-2012, 09:19 PM   #28
firstgear
Newbie
Thanks everyone. The Braille battery while only about 460ccamps will fit and they make a decent battery holder for it (seriously over priced). Thanks for pointing me in that direction. Herb
Old 12-30-2012, 02:50 PM   #29
groundpounder
Alliance Member
groundpounder's Avatar
Hey guys ..was reading on the battery situation here......notice them heavy expensive battery charging lugs. I've made my own charging lug posts.....using the smaller rubber valve stems,....making a mounting plate,...pulling the stem thru......removing the valve core and soldering a 10 Gage wire to the end where the core installs. The other end to battery. Screw the cap back on and it's covered.....
__________________
Some people pay for this comedy act!....I get it for free!....
Old 12-30-2012, 03:30 PM   #30
MeanGene427
Senior Member
The long skinny ones like the IH tractors (and my little 6V Clark Trukloader forklift) used are also available in 12V- Tractor Supply has them in stock
__________________
A car with a Poser cam is like a girl with a stuffed bra, it's fake, and not much fun to play with
Old 12-30-2012, 05:15 PM   #31
alphabet soup
Alliance Member
'63 caddy used a long thin 12 volt.
online   Reply With Quote
Old 12-30-2012, 06:51 PM   #32
japar
Grenade Inspector
japar's Avatar
I have been known to put 2 12s together in a series in the winter to start my diesel. 24v makes that sucker crank! Just don't use the cigarette lighter
Old 12-30-2012, 08:58 PM   #33
MeanGene427
Senior Member
Here ya go
http://www.tractorsupply.com/exide-h...y-f3ee-0470556
__________________
Old 12-30-2012, 09:27 PM   #34
pasadenahotrod
Old School HAMBer
The group size of the long skinny 12V battery is 3EE most commonly used in forklifts. My old T roadster had one in it standing on the rear frame rail inside the abbreviated pickup bed between the "tailgate and the 28 Chevrolet gas tank. Easy to reach, easy to service, easy to remove.
Old 12-30-2012, 09:45 PM   #35
hd4unm
Grenade Inspector
Quote:
Originally Posted by pasadenahotrod View Post
Many of the British sports cars had a pair of 6V batteries in series mounted one on each side of the car: Jag XK120, 140, 150, MGA, MGB and others. Very common in Euro cars back when.
No challenge to pasadenahotrod, but just a point...that may help the OP.
I'm not a Euro guy but a friend had a '70 Porche 911 with two batts. They were well place in the nose (as many know) on opposite sides. I expect it was engineered that way as ballast/balance and not to add voltage but accommodate what they needed and enhance the car.
If I had to consider your options... I'd look at all the options and impact; maint. (number of connections, etc.), cost, weight, appearance, what else?
Personally, one batt is enough for me if it does the job.
Old 12-30-2012, 10:34 PM   #36
Dads426
FNG
Your 12-volt battery is really six 2-volt batteries (or cells) wired in series internally. Using two 6-volt batteries is acceptable as long as they are the same type. Very common in solar power systems. I've run 60 2-volt batteries in series for 120 VDC systems.
Old 07-25-2013, 11:45 PM   #37
dan c
Alliance Member
dan c's Avatar
i've heard that the theory behind two 6v batteries is that they provide more cranking power. a buddy had a 59 mga with that setup and the biggest bummer was that the batteries sometimes fell over!
Old 07-25-2013, 11:58 PM   #38
big daddy Raleigh
Grenade Inspector
big daddy Raleigh's Avatar
You could run two 12v motorcycle batteries in parallel. Wiring batteries in parallel batteries adds the amps- wiring in series adds the voltage.
__________________
Just because you can put tap shoes on an Elephant doesn't mean it can dance!
Old 07-26-2013, 01:59 PM   #39
40FordGuy
Old School HAMBer
GM did that with the 53 Cadillac Fleetwood "limo" body cars; Worked great.
4TTRUK
Old 07-26-2013, 02:16 PM   #40
mike in tucson
Grenade Inspector
mike in tucson's Avatar
How many flashlight batteries placed end to end in a round tube would it take to start a SBC?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
