Reply
Thread Tools Display Modes
Old 08-25-2005, 11:08 AM   #1
coupe33
Alliance Member
Question 1957 y-block info needed
A mechanic I work with bought a 57 Ford 1/2 ton for the cab roof and I have the chassis and box at my place. This is a running motor with a three speed on the column runs good and doesn't smoke. am looking to find out which motor it is. The only listings I have found are 272 or 292 for the two barrel? I am trying to set a value to buy it off him and don't have a clue what it is worth. I have a good rep and don't want to cheat him. I don't really need this but I think it was going to be scrapped. I just mentioned that I would be interested in the rear and he dropped it all off when I wasn't home.
Any ideas?
Is it worth using?
Whats it worth?
offline   Reply With Quote
Old 08-25-2005, 11:22 AM   #2
general gow
Moderator
general gow's Avatar
Default Re: 1957 y-block info needed
I think it probably is a 292 if it came from a pick up of that vintage. You can tell what it is from the casting numbers on the heads. If you tell me what they are, I can probably tell you what engine it is. If I can't, I know my dad (model40) can. List some numbers here and we'll see what we can do.
If it is a 292, in good running order, it's worth what you are willing to pay. Meaning, it's not a highly sought after motor, although I am using one in my A coupe build. It would probably be fair to offer him $200-300 for the running engine. What you establish for a value on the rest is up to you. I paid $50 for mine out of a wrecked COE. It looks freshly rebuilt, we'll soon see as the day to try to fire it is coming...
__________________
Alter Boys CC
Old 08-25-2005, 11:26 AM   #3
du$ty
Senior Member
du$ty's Avatar
i agree with gow....its a 292 id bet...and i am also using one in my coupe...i love them..my first old car had one in it...ive been hooked ever since.its cool because now they are making alot of cool stuff for them again.
__________________
im no longer kartbreaker...but still a heartbreaker
Old 08-25-2005, 12:19 PM   #4
general gow
Moderator
Good stuff is easy to find for them, you're right. Offy makes killer manifolds and valve covers. All the Y block stuff is compatible, so you can dress it up like a T-Bird engine very easily. They run great, have a good track record, at least in my experience.
And nothing sounds like a Y block with Smithy's or Brockman's...
And if you can scare up a pair of rams horn manifolds, ooh baby.
__________________
Alter Boys CC
Old 08-25-2005, 03:53 PM   #5
Fidget
Senior Member
Fidget's Avatar
Go here http://www.ford-y-block.com/Block%20identification.htm This should help you out with identifying the block and head.
__________________
~Scott
You never really learn to swear until you learn to drive
Old 08-25-2005, 04:10 PM   #6
Shiftymutt
Senior Member
Shiftymutt's Avatar
Y blocks are great. the only problem with them was oiling in the rockers however that is a pretty easy fix. most of the old time racers ran a couple of lines to the vavlve covers and tappit a couple of line in it.
I had a y block in my 55 and it ran like a drean. they are solid motors.
as far a svalue I just sold a 272 motor and ford-o-matic trans to a guy out of a running driving truck for 250.00. I could have got more but I am trying to help out a "youngster". I would say that if you got a running motor that sounds solid and is strong 200-300 is good.
If you need parts they are eveywhere and are still pretty cheap. 4 bbl manifold are out there ( the b code fits newer base carbs the A code is for the "teapot nightmare"). stay away from t-bird sights and stuff...that shit is expensive for a funny looking bird stamped into it.
I have a set of finned valve covers and a b code mnaifold if you want are looking to dress it up.
__________________
The pain of discipline is much easier to endure than the pain of regret.
"Fuck the Mickey Mouse Club"....Scorpio FFF
www.losboulevardos.com
Old 08-25-2005, 04:14 PM   #7
coupe33
Alliance Member
the heads are 6090. Does this narrow it down? This is all stock including the exhaust with the cross over pipe.
Old 08-25-2005, 04:14 PM   #8
Shiftymutt
Senior Member
Shiftymutt's Avatar
292
__________________
Old 08-25-2005, 04:30 PM   #9
Goober
Senior Member
Goober's Avatar
Quote:
6090 only means it's a Ford head. Check out this page to identify your heads.
http://www.ford-y-block.com/cylinderheadchart.htm
Old 08-25-2005, 04:30 PM   #10
coupe33
Alliance Member
Thanks to all I just found the serial number and the web site identifies this as a dearborn 57 block 292. I have a 32 pickup with a 327 Chevy (stock) would it be worthwhile to swap and how many mods would be needed? Winter is coming.
Old 08-25-2005, 04:33 PM   #11
Fidget
Senior Member
Fidget's Avatar
6090 is Ford's number for cylinder heads. If you're looking at the heads, there should be a 3 or 4 letter designation on it that tells you what engine head it is.
Example: ECZ-G is for a 57 Ford. However, it was used on all the engines in 57 so you will need to get the block number. I'll agree with Shiftymutt, and say it's most likely a 292.
__________________
~Scott
Old 08-25-2005, 10:23 PM   #12
Paul2748
Senior Member
Paul2748's Avatar
You really have to get the numbers off the block to determine size (and in the case of 292's and 312's the block numbers are the same). Heads don't really do it because they may have been changed somewhere along the way. Look for the number above the oil filter. Should be three letters, a number and then another letter if an original motor. The later blocks - 59 and up- have different sequence of letters and numbers.
__________________
flathead or ovhd- fords only
Old 08-26-2005, 12:22 AM   #13
57JoeFoMoPar
Alliance Member
57JoeFoMoPar's Avatar
If it's a '57 Y block with a 2 barrell, it could either be a 272 or 292. Mine was a 272. It could be either. The only heads that are worth anything are the ECZ-G castings, which were off of 312, and had larger valves. The ECZ-G castings would be the way to go on a 292, which is commonly believed to be the strongest of all the Y Blocks.
All Y Blocks are generally worthless motors in the grand scheme of things. A perfectly good, complete running engine usually goes for between $100 and $300. The '57 will have the more desireable style of adjustable rockers though, which will bring a few bucks on eBay because guys with '54-'56 Y blocks will want them. They do look good, and they sound great (when they run)
Check out my 272.
Click image for larger version
Name:	000_0306 (Small).JPG
__________________
-'57 Joe
Street Aces CC - New Jersey
"When life knocks you down from first class to coach, fart a whole lot and really stink up the place...that'll show 'em."
Old 08-26-2005, 12:41 AM   #14
kustom72
Grenade Inspector
kustom72's Avatar
That y-block link listed above shoud get you where you need, they do make speed parts for the Y but I found it pretty spendy stuff, thank God theres adapter kits to mate them up to C4 and 6s, cause that old 3 speed tranny aint worth the pot steel its cast out of. But the 292 I think is a cool old engine, good luck with it, but dont pay over a couple hundred bucks.
Old 08-26-2005, 01:12 AM   #15
chopndrop
Just as a price reference, I recently paid $150 for engine/trans/rearend from a 56 Ford truck.
__________________
how come common sense isn't that common?
Old 08-26-2005, 01:53 AM   #16
Spook
FNG
Spook's Avatar
Go for it. Nothing wrong with those Y-blocks. Valve train oiling problem was pretty much taken care of by cam redesign with groove instead of hole for oil to go through. Also better oil than 50 years ago with less sludge build up to clog passage ways. Rear main seal was a problem, however they have better seals today. And as someone else said "Nothing sounds like a Y-block"
Old 08-26-2005, 07:52 AM   #17
tommy
Old School HAMBer
tommy's Avatar
They are a little long. Note the firewall, but they are a cool looking motor. The valve covers are chromed Mercurys...not seen everyday. The truck ram horn exhaust manifolds are pricey but most of the hot rod parts are really pretty cheap by comparison. (this is not mine)
80 bucks for this intake.
A bath, a shave and a haircut...
This is mine. 292 3 spd w/OD. A fun car to drive. I'm impressed with the little Y block....4.11 gears make it fun!
__________________
Quote...You are hereby Knighted...'Sir Asseth of Hole' Tommy... 3W Larry.
Quote...It's called "HOT RODDING", not paint by numbers....Fab32
Old 08-26-2005, 07:04 PM   #18
Fifty5C-Gas
Senior Member
Fifty5C-Gas's Avatar
Check out my 272.
well, that'll happen to any motor if you run em with no oil, or antifreeze, even a mopar motor.
__________________
Mike
Kustom Knights N.J.
1955 Chevy 210 Gasser
1951 Ford Convertible Kustom
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
