View Poll Results: Granada or CC850's?
Granada Spindles/Brakes 13 61.90%
Aerostar Coils 8 38.10%
Voters: 21. You may not vote on this poll
Reply
Thread Tools Display Modes
Old 03-03-2012, 05:04 PM   #1
Mitchell de Moor
Alliance Member
Mitchell de Moor's Avatar
Default 1956 Ford: Granada dropped spindles...
Okay,
I have the chance to get the front brakes and spindles from a Granada. Is it a direct bolt in setup? What else would I need? Should I take this rout or just run some Aerostar (CC850) springs?
Thanks!
__________________
Looking for 1956 Oldsmobile Roof, Rockers, Fenders, Quarters, etc.
offline   Reply With Quote
Old 03-03-2012, 06:19 PM   #2
Mitchell de Moor
Alliance Member
Default Re: 1956 Ford: Granada dropped spindles...
I should have probably added I just want my car lower. Has all stock brakes now.
__________________
Old 03-03-2012, 07:11 PM   #3
Frankenstein57
Newbie
Frankenstein57's Avatar
If all you are after is ride height, the springs are the easy way out. If you go to discs you need a proportioning valve, dual master cylinder,disc brake wheels. Might have to ream the spindles to accept your ball joint, I think the versales bolt up without reaming. I used the torino spindles, they changed the camber/caster quite a bit. Your call, Mark
Old 03-03-2012, 07:15 PM   #4
Mitchell de Moor
Alliance Member
Quote:
Thanks! I can get my hands on everything pretty easily without spending much although I had no idea about the wheels. Thanks for that! I'll probably just go with the springs then. I was doing a parts trade with someone and they offered the Granada parts which is why I asked.
__________________
Old 03-03-2012, 08:36 PM   #5
damagedduck
Senior Member
damagedduck's Avatar
Both.
__________________
my 30 year love affair-
http://s946.photobucket.com/albums/a...1949%20hudson/
Old 03-03-2012, 08:48 PM   #6
Mitchell de Moor
Alliance Member
Quote:
Originally Posted by damagedduck View Post
Both.
I want the ass to be a little lower. Both in the front would be around a 6" drop right? I don't know if I can go that low in the rear without serious modifications.
__________________
Old 03-04-2012, 06:21 PM   #7
parklane
Grenade Inspector
parklane's Avatar
If you go with the Granada/Monarch spindles, and Aerostar springs, it should drop the front about 3-3 1/2"
__________________
some are so dumb, they couldn't pass their blood test
Old 03-04-2012, 06:34 PM   #8
Edelbroke
Edelbroke's Avatar
Granada spindles and bags. Or better yet Shockwaves. Oops that wasnt one of the choices
Old 03-05-2012, 04:05 PM   #9
Mitchell de Moor
Alliance Member
Quote:
Thanks! Not sure I want the front that low as I want the back to sit about .5-1" lower. I only have 3" blocks. Would you maybe take a leaf or two out as well? Thanks!
Quote:
You know what Germ said... "Bags are for weed" I'm not in the financial means to bag my car. If I was I would rather do hydraulics anyways.
__________________
Old 03-05-2012, 04:56 PM   #10
56 ford custom
Old School HAMBer
56 ford custom's Avatar
Mitchelldemoor, before I did all the work on my frame. My car had I believe 2 or 2 1/2 coil cut from the front and 2 leafs taken out of each side of the rear with 3 inch blocks and flipped shackles. The car was damn low and still handled pretty well. Now it lays frame on air ride. I didnt pay not even near half as what others would pay and its done right with a powder coated frame. I do kind of regret not doing hydros due to the way im building my car...but that can always be changed.
__________________
FOMOCO LOW LIFE
online   Reply With Quote
Old 03-05-2012, 05:22 PM   #11
DdoubleD
FNG
Check your wheels, some wheels may not fit the brake rotor at the hub hole. If it has'nt been mentioned Ackerman angles.
For new Granada parts......
http://www.discbrakeswap.com/
Old 03-05-2012, 05:30 PM   #12
Mark T
Mark T's Avatar
Granada spindles can be machined to lower a car approximately 1" to 2 1/2" depending on how much material you remove from the lower ball joint hole. if you want to lower your car 1" you have to machine the lower ball joint hole large enough so the spindle sits all the way down on the ball joint stud like the factory spindle. if you want the 2 1/2" drop you will only have to machine out enough material so the spindle will sit high up on the tapered part of the ball joint stud, a rubber spacer will be needed between the spindle and the grease boot, approx. 3/4". You will also need a hardened spacer or washers to take up the space under the castle nut because the Granada spindles are thinner in this area. This is what DropNStop has been selling for many years. http://www.dropnstop.com/
Granada rotors have been successfully machined in a brake lathe to fit wheels with a smaller center hole. I didn't have to do this on my car but if I had to I think I would check this area before I removed any material to make sure they are thick enough, you never know with aftermarket rotors.
Old 03-05-2012, 07:45 PM   #13
Mitchell de Moor
Alliance Member
Quote:
I loved that photo of your car of how it was originally lowered. Thanks man! I really DON'T want my car to lay frame. No offence, it just ain't my thang.
Thanks!
Thanks!
__________________
Old 03-05-2012, 07:56 PM   #14
56 ford custom
Old School HAMBer
No worries I didnt get offended. If you want it low and a bit lower in the back like my car was....that is the way to go. The only thing I had to do was cut the floor alittle where the drive shaft would have rubbed.
__________________
FOMOCO LOW LIFE
Old 03-05-2012, 09:05 PM   #15
38Chevy454
Alliance Member
38Chevy454's Avatar
I say use the Granada spindles and get the improved disc brakes for cheap. It never hurts to have a bit more braking to deal with cell-phone yacking idiots that are not paying attention. Some free drop is a nice benefit. You can adjust the spring height after the spindle swap.
__________________
High Quality USA-made bear claw style latches CHEAP! Now have install kits also!
http://www.jalopyjournal.com/forum/s...d.php?t=620485
Purchase directly here: www.hotrodlatches.com
Old 03-06-2012, 08:14 AM   #16
Mitchell de Moor
Alliance Member
Your car is my inspiration for lowering. If you ever find any pictures let me know. I love it man! Did you fab a hump to go over the place you cut out? Would love to see a picture or two if possible... Thanks!
Quote:
I am quit pleased with my factory brakes. They work well, when adjusted right. The one thing I will do though is swap in a '67 Mustang dual master cylinder.
Also this is directed to 56 ford custom; I was going to do what you did to yours only I was thinking about adding air shocks in the back. What are your thoughts on this? Thanks!
__________________
Old 03-06-2012, 08:43 AM   #17
56 ford custom
Old School HAMBer
I think I might have a couple more pics...That isnt a promise though since I have moved a few times since I had that car going. So has the car haha.
I ran air shocks on the rear of mine too at the time. The only thing is that mine was soo low that the angle of he shock kind of made them worthless. Are you planning to notch the rear? Or relocate the shock angle?
__________________
FOMOCO LOW LIFE
Old 03-06-2012, 12:02 PM   #18
easyissy
Grenade Inspector
easyissy's Avatar
If you have no problems with the brakes I would just replace the coils. Thats what I did.
I also used the air shocks (not bags) in the rear for when my buddies jump in the back seat I don't tail drag.
Here's how it sits with the above modifications:
Old 03-06-2012, 10:00 PM   #19
Mitchell de Moor
Alliance Member
Thanks, maybe long term I will notch it someday, but not right now. Just getting the car ready for Santa Maria. I also wasn't planning on relocating the shock angle, but at the same time I am not really sure I know what that entails.
Thanks! What else did you do to lower the rear? I am for sure going to have blocks and there is a slight possibility I may take a leaf or two out and maybe even reverse the shackles like 56 ford custom did.
__________________
Old 03-06-2012, 10:22 PM   #20
mastergun1980
Alliance Member
mastergun1980's Avatar
I have been thinking about doing the same to my wife's 56. Just the granada spindles, but her car is already pretty low, so maybe there has been a change of the springs already, It does have the aluminum blocks in the control arms to.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
