Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#21 |
FNG
Be carefull using 55-57 rear ends. Could break easy and cause you to invest too much money into them...even if you are not drag racing. Not many replacement pumpkins around like ford 9". I would use all new hardware and spring perches. You will probably break the U-bolts and cut away too much of your perches trying to get them off the housing and out of your car anyways...trailer supply stores have perches around $4 each that will work with 3" housings and for the width of your leafs...good luck.
#22 |
Alliance Vendor
what ever you do use make sure its 60 inchs from drum face (or wheel mounting serface ) to drum face im running a posi nova rear thats 58'' it was free so i used it and worked out realy bgood when i desided to run skirts we always use stock 50's chevy wheels or wheels made to same offset and width
![]() first gen camero 4x4 s10 alot of nova rear ends are 58" ( what im running ) tri 5 chevys is an easy fix also with stock springs the locating pin is in the wrong place its about 2'' forward
__________________
ALIANCE VENDER FOR: ALL YOUR HOT ROD & KUSTOM CAR NEEDS GAMBINO KUSTOMS NOTCHS & TAIL DRAGERS KITS FOR ALL 40'S & 50'S CARS call: 408-561-5744 made a million dollars off my first record deal |
#23 | |
Alliance Member
Quote:
__________________
High Quality USA-made bear claw style latches CHEAP! Now have install kits also! http://www.jalopyjournal.com/forum/s...d.php?t=620485 I used to have a handle on life......... then it broke |
#24 |
Grenade Inspector
A 79 Camaro axle worked great in mine (perfect width), just weld in new perches from Jamco to fit the offset locator pins.
#25 | |
Grenade Inspector
Quote:
| Thread Tools | |
| Display Modes | |
