Reply
Thread Tools Display Modes
Old 08-19-2005, 02:01 PM   #1
Levis Classic
Old School HAMBer
Levis Classic's Avatar
Default Model A Vin number question!!
I got two numbers on this old original 1929 Model A title
engine number - the letter A and seven digits
and a title number with seven digits
Which is the Vin number?
THANKS
offline   Reply With Quote
Old 08-19-2005, 02:06 PM   #2
old beet
Old School HAMBer
Default Re: Model A Vin number question!!
All of the above...
Old 08-19-2005, 02:07 PM   #3
general gow
Moderator
general gow's Avatar
Most likely the engine number is what they used for the VIN. Not at all uncommon. The title number is probably just that, a number used to identify the title document itself.
__________________
Alter Boys CC
Old 08-19-2005, 02:30 PM   #4
5window
Old School HAMBer
5window's Avatar
When I titled my '31 as a street rod, Pennsylvania voided my original title and issued me a whole new VIN plate for the firewall and a new title with matching numbers. I wonder what would happen if I wanted to restore it as a Model A?
My original title used the A+number as the VIN number.
Old 08-19-2005, 07:22 PM   #5
toledobill
Grenade Inspector
All I can add is that I bought a '29 A roadster from a guy in California back in 1967. The California title listed the VIN as the serial number off the Y-block that was swapped into the A. The title listed the car as a "Self-assembled 1929 Ford". When I swapped out the Y-block, I made a new "VIN plate" with the Y-block's serial number and put it discretely on the firewall.
Old 08-19-2005, 09:14 PM   #6
Boones
Alliance Member
Boones's Avatar
If you can find any number that matches something on your car use it. My frame (as with most) have a serial number that starts with an A. but it can not be seen with the body on the frame. so the motor number is used alot of times because if you have the original motor it can be verified.
__________________
wanted - 1953 or 54 chevy wagon tailgate......
www.fotki.com/boones
Old 08-19-2005, 09:34 PM   #7
G V Gordon
Old School HAMBer
G V Gordon's Avatar
The engine number on an A is the same as the one stamped in the frame. Model A's shared running gear on a lot of models. The frames came down the assembly line, The engines were put in and the engine number stamped in the frame. Had to prove that to my DMV when I titled my tudor.
__________________
Vagabonds / Oklahoma
www.vagabonds.cc
http://www.pinheadlounge.com/gvgordon
Are fake bull scrotums on Chrysler produced pickup trucks considered "Dodge Balls"
Old 08-19-2005, 09:35 PM   #8
BELLM
Alliance Member
BELLM's Avatar
Use the engine number, the title number is just that, the number on the title assigned to that title by the state, not a number assigned to the car.
__________________
Thunderbolts-Central Texas
Old 08-19-2005, 09:41 PM   #9
Sam F.
Old School HAMBer
yup.,,use the engine number on your title...
i went to the local trophy place and had a plaque made that said
"Body No. XXXXXXX" for $5.30 ,took it home rivited it on ,,scuffed it up with a scotch brite pad and then went for the sherrifs inspection and had no problem,,,
results may very,use as directed,batterys not included
Old 02-11-2008, 11:09 AM   #10
BigDaddyP
FNG
Anyone know where the Vin# is on a '29 Ford??
Old 02-11-2008, 11:30 AM   #11
36-3window
Old School HAMBer
36-3window's Avatar
Quote:
on the engine if it is the original one and on the frame, drivers side right behind the first body mount hole. you can not see it with the body on
Old 02-11-2008, 11:35 AM   #12
manacoem
Alliance Member
manacoem's Avatar
Vin on a 29 is usually located on the drivers side frame rail , very near where the 2 bolts that secure the cowl post to the frame bracket are ( area between the cowl post with hinges and the firewall) All of mine have been preceeded with a ''star" then an ''A", then the number , and then another star after the number. Also I have seen them near where the battery is located on top of the center crossmember. If you find the number and can't quite make it out, you can look just above the split flange of the firewall on the drivers side, there should should be a total date of manufacturing (month, day and year ) stamped in the top section very near the split flange. then go to the model A collectors website and see what range of numbers were applicable ,pick one that looks the closest, and hope that nobody else is using it (slim Chance)! You should also have that number on your bill of sale I would think.. Our DMV in michigan always asks. Then at least you can ask for a Lost Title app. Hope it helps Later manacoem
__________________
If they can build the PYRAMIDS then this ought to be a breeze
Old 02-11-2008, 11:50 AM   #13
Von Rigg Fink
Old School HAMBer
Von Rigg Fink's Avatar
just my 2 cents
the engine number may not be the original vin.# because it could have been replaced..and replaced many times thru the vehicles life..(ask me how i know)
the REAL number you want is on the frame like said above..
just to shine a light on what im saying..my 79 year old model A had a 1931 engine in it..did the numbers on the frame match the engine...F$%k NO!
im in Michigan they want the Vehicle Number (hence VIN#) not the engine number..trust me..get the Frame number and use it.
__________________
Goldchainers CC S.E. Michigan Chapter
Charter Member
Some guys could fuck up free lunch.
Old 02-11-2008, 12:05 PM   #14
MIKE-3137
Senior Member
MIKE-3137's Avatar
Glad you asked this, I have been wondering also on my model A roadster on a 1932 frame, should I register it as 31 using the body # or a 32 with the frame #?
__________________
It is what it is...
Old 02-11-2008, 12:39 PM   #15
rustynewyorker
Old School HAMBer
rustynewyorker's Avatar
Location: Upstate New York, watching my New Yorker Rust
If you don't have paperwork, use whatever number is stamped into the car. If you have paperwork, and your state does not inspect the vehicle, use that.
__________________
"That was a time when America was great.. when the chrome was thick and the women were straight" - Michael Savage
I have old cars for sale. PM me or check the classified.
Old 02-11-2008, 01:06 PM   #16
56Sedan
Grenade Inspector
Some Model A's have a body number stamped on the first cross brace on the body(right in front of the seat) All this number does is tells where it was built and the sequential number.
The frame number is the best bet for determining the orig. VIN as motors got changed often and not much effort was made to restamp the block back in the day.
Old 02-17-2008, 07:11 AM   #17
Mullda
Grenade Inspector
Mullda's Avatar
Thanks 56Sedan. I just moved to NC a few months ago and they have really tightened up on the antique car registration process. I don't know how may previous owners my 1930 A has had, but the last one had the car for over 15 years. I've had it for five. It has a new chassis with no number on it and the only number on the body is the one on the first cross brace. So it looks like its going to be a real interesting trip to the DMV here next month.......................
Old 03-05-2008, 01:28 PM   #18
kookee
kookee's Avatar
Not to drudge up an old topic, but it is very current for me. It was all I could find searching the topic.
I have an opportunity to buy a 30 Model A. However, it is just the sheet metal. No frame, motor, etc. Seller wants to keep the frame and title for another project. I had considered purchasing, or attempt building, a frame.
In this scenario there are no numbers. What kind of trouble is it going to be to get a title registered in Michigan? I researched the Secretary of State site and found that they will award one with clear documentation, VIN, etc. Screwed without it?
Many thanks!
Old 03-05-2008, 02:40 PM   #19
Aman
Old School HAMBer
Aman's Avatar
A lot of correct answers here. The VIN is stamped on top the frame under the body and can't be seen without removing the body, how convenient, right? When I bought my A the VIN on the frame didn't match the title but did match the motor number so I guess back then the motor was the important part plus it could be verified easier. I'm going with the plate idea mentioned above. Mount it at the bottom on the firewall on the driver's side, should be good to go. If you want something to do in your spare time call the DMV and ask them. Call back in about 3-4 days and get another person on the phone and see if you get the same answer. Good luck.
__________________
Happiness is not having what you want, but wanting what you have.
Old 03-05-2008, 03:34 PM   #20
rustynewyorker
Old School HAMBer
Model A frames are a dime a dozen. Just buy another one, the body doesn't care what the frame number is. I have a similar problem in that I have a nice A frame but the coupe it used to be someone used a 1-800-street-rod frame on, so I'm sure they used the existing registration. Which means that car has a serial number with no proof on the car that it's that car, unless they were smart enough to stamp the new frame with it.
So to use this frame I'd have to do what they did - use an existing registration - or register the finished vehicle using the number of another frame I have here.
Which if you build a frame for your body, just stamp a number in in the correct place, and slip an extra digit into it beyond the range of A serial numbers, so it's sure to not come back as in use.
By the way, we're all asking about Serial numbers. It didn't become a "VIN" until 1968. Just a minor nitpick -
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
