Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 02-11-2012, 03:58 PM   #1
28RPU6
Alliance Member
28RPU6's Avatar
Default y-block oil problem, need advise
My brothers girlfriend drives a 58 Ford 300 with a 292. It has started pushing oil out of the lower breather tube in large quantities at odd times. It can go for days with relativly nothing and then back it up 10 feet and it pukes a 1/2 quart. Any advise would be appreciated.
offline   Reply With Quote
Old 02-11-2012, 04:03 PM   #2
MrHavard
MrHavard's Avatar
Default Re: y-block oil problem, need advise
Is the breather filter on the top tube clogged?
Old 02-11-2012, 04:05 PM   #3
28RPU6
Alliance Member
28RPU6's Avatar
It's clean.
Old 02-11-2012, 04:14 PM   #4
302GMC
Senior Member
Drain holes in cyl. heads open?
Old 02-11-2012, 04:42 PM   #5
sunbeam
Alliance Member
sunbeam's Avatar
Check the filter and the drain back hole. Or block it off and use a 60s road draft that comes out of the valley cover.
Old 02-11-2012, 06:49 PM   #6
56don
Old School HAMBer
56don's Avatar
You probably are building up pressure in the crankcase so make sure the engine is ventilated well.Take that block breather off and make sure it has the metal mesh and baffles in it. Do all the above and consider adding a pcv valve.
__________________
I'm just an analog guy trying to make it in a digital world.
Old 03-10-2012, 10:43 PM   #7
RT Classics
FNG
I agree with 56don, good advice. If you google Concours Parts for 1955-1957 Thunderbird you'll see a PCV conversions setup that includes a carb spacer with tube outlet that faces to rear of engine, pcv valve and pcv hose. Then you'll need to remove the intake and replace the lifter valley cover with TBird style that has a roaddraft hole in rear of this cover (close to firewall). TBirds came with above mentioned roaddraft tube. On the 'Birds you simply remove the metal tube that attaches to this special valley cover, put the kit's rubber grommet in and install the spacer and attaching tube. FYI Y-blocks with a lot of miles puke a lot of oil as standard since they don't have PCV system. As 56don mentions passenger cars come with block breather on driver side lower block. By the way, your oil will stay cleaner longer with a pcv system because it gets all that moisture and crap out of the oil pan. Best regards. www.rtclassics.net
RT
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
