Go Back   THE H.A.M.B. > Archives > Tech Archive
Reply
Thread Tools Display Modes
Old 01-19-2004, 08:47 PM   #1
Rocket88
Rocket88's Avatar
Default Tech: $1.98 6 volt gas gauge fix.
Thought I'd post this one since we get a lot of questions on it, here's a cheap 6 volt reducer.
I don't like those resistors (they get too hot) and I've tried those expensive voltage drops (fried em')
How about a cell phone charger! I found this at an electronics surplus store. It takes 12 volt DC and reduces it to 6 volt DC at 2 amps.
Cut off the cigarette lighter end and hook it to 12 volts. At the other end is a jack, open up the charger and solder on a couple output wires. Hook up the output side to your gas guage and that's it! We've beeen running them for a couple of years now with no problems.
And it was only $1.98!!
MOD EDIT:
Original Thread here: http://www.jalopyjournal.com/forum/s...ead.php?t=8274
Click image for larger version
offline   Reply With Quote
Old 01-19-2004, 09:00 PM   #2
Mike Paul
Mike Paul's Avatar
Default Re: Tech: $1.98 6 volt gas gauge fix.
did this on a couple of cars and it does work good....Mike
Old 01-19-2004, 11:59 PM   #3
burndup
Senior Member
burndup's Avatar
its a shame this is on page 2...
Also, if ya ever run across a device called a 7806.... its a 6v regulator, looks like a big transistor... 3 pins, one takes up to 35v in, center is ground, and the third is regulated 6v out... there more common bretheren are 7805 and 7812... 5v and 12 v respectively.... Radio shack carries those, so you can go in and at least see whatthey look like.... but they are not 6v... There are tricks to making the 5v one do closer to 6v, but its beyond the scope here... the cell phone charger is much easier!
THEN, if you are ever tossing something electronic, check it out for one of those regulators, they are common... you can unsolder it, and use it again...
Old 01-20-2004, 12:07 AM   #4
cadlights
cadlights's Avatar
After ya get done with hooking up the gage. Take the cigerette lighter end and put some alligator clips on
the wires and use it for a tester. Just plug into the lighter outlet and you can test componants like power windows, radios and such with out running a wire clear to the battery. Thrift stores are a great source, just use your imagination.
Old 01-20-2004, 12:46 AM   #5
JSM56
Grenade Inspector
JSM56's Avatar
great post. the cellular charger is an easy way to go. burndup is right on the money, easy to find 6v regulator at some larger electronics stores, but radio shack carries only 5v and 12v because its common for computers. i got a 6v at FRY's electronics for under a dollar. 3 wires, ground, 12v in, 6v out. and much smaller than the charger.
Old 01-29-2012, 06:29 PM   #6
d2_willys
Old School HAMBer
d2_willys's Avatar
Quote:
Originally Posted by badpat View Post
great idea- how many ams does a heater fan need???
You mean amps? Try 6-10 amps for 6V fan motors. And they are inductive loads, so unless you have a voltage regulator in the 20-40 amp range, you will be looking at smokey joe for a regulator!
BTW: I doubt that these phone chargers are any good above 250ma or 1/4 amperes. They are meant to charge lithium ion and ni-cad batteries which require a very small amount of current for charging. Most fuel gauges will draw more current when reading full as to reading empty, as the sending unit decrease in resistance when full.
__________________
Dual range hydros rule!
Wise man say to 53 Olds with Dynaflow owner: SHIFT TO LO & GO!
Old 01-29-2012, 11:51 PM   #7
nali
nali's Avatar
Quote:
78xx and 79xx have a thermal protection. They can provide up to 1 or 1.5 amp with a dissipator, but they won t burn.
__________________
ˇNo pasarán!
Old 01-30-2012, 08:53 AM   #8
Road Runner
Senior Member
Road Runner's Avatar
I use a zener diode NTE 5118A and resistor to get 6V for the fuel gauge.
Cheapest and simplest method.
__________________
On the road every day...
1948 Chevy Coupe - 261
1952 Chevy Truck - 235
Old 01-30-2012, 09:12 AM   #9
Truckedup
Old School HAMBer
Truckedup's Avatar
Wired in series or what?
Old 01-30-2012, 09:25 AM   #10
Road Runner
Senior Member
Quote:
I don't remember the resistor value.
It depends on your battery voltage and fuel gauge current draw, but 1/2W rating is fine.
The zener is 6V and rated for 5W and will last forever.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
