Reply
Thread Tools Display Modes
Old 01-20-2012, 03:29 PM   #1
dadz34
Grenade Inspector
dadz34's Avatar
Default Transmission Bellhousing Dimensions
Request to all of you guys who are more organized than I am. I am building an engine run stand and figured a simple way to create the rear mount for multiple engines would be to have a solid plate with holes drilled to match different engines. This way I dont have to have multiple bellhousings laying around taking up space. If I had a clear diagram which detailed the dimensions of various tranny/bellhousings...I could then drill the holes for all of the transmissions and no matter which engine I lower into the stand, it would accept them all. Make sense? For my home shop, I can imagine only needing SBC, BBC, LSX, SBF, BBF, and possibly a flatty. I have attached a diagram which is what I am looking for. Unfortunately, it is very low resolution and thus I cant use it. Anyone know where I can locate a better diagram?
Thanks in advance!
Troy
Click image for larger version
__________________
Best regards,
Troy
offline   Reply With Quote
Old 01-23-2012, 07:50 PM   #2
dadz34
Grenade Inspector
dadz34's Avatar
Default
Bumpity...bump...need help if you can. Hopefully somebody knows where I can find these measurements. Thanks again!
__________________
Best regards,
Troy
Old 01-23-2012, 08:47 PM   #3
Hnstray
Alliance Member
Hnstray's Avatar
Default Re: Transmission Bellhousing Dimensions
Do you have a salvage yard in your area? If you can get access to that, you should be able to make patterns on poster board of all the popular trannies you want.
Ray
__________________
"In any conflict between Physics and Style, Physics always wins"
Old 01-23-2012, 10:02 PM   #4
Old School HAMBer
squirrel's Avatar
how you gonna get the starter mounting holes to work for the different ford engines?
(btw took me 20 seconds to find these with google)
__________________
Jim Forbes
my shtuff
Old 01-23-2012, 11:18 PM   #5
von Dyck
von Dyck's Avatar
On a running test stand we did for our school shop, I built a hoop over the bell housing area. This hoop was straight across on top so as to incorporate 2 horizontal sliders that could be locked into place at any position. From these sliders were suspended two adjustable vertical straps that were attached to two of the upper bell housing bolts. Full adjustability for almost any automotive engine......ran many dyno tests over two decades on this test stand. As well, the front attachments to the motor mounts were fully adjustable, but came up from the bottom.
Old 01-24-2012, 06:21 AM   #6
dadz34
Grenade Inspector
dadz34's Avatar
Thanks guys for the help. Squirrel is better at Google than I am. I searched for a lot longer than 20 seconds and never found anything that clear. As for the starters on the fords, I haven't figured that one out yet. I like the sound of the hoop Von Dyck. Any pics from school shop left around to illustrate it?
__________________
Best regards,
Troy
Old 01-24-2012, 08:16 AM   #7
Old School HAMBer
squirrel's Avatar
https://www.google.com/search?hl=en&...isch&source=og
I think the hoop idea sounds good too, it's hard to say what you're going to be getting into in the future.
__________________
Jim Forbes
my shtuff
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
