Shop Press Tooling
Discussion in 'The Hokey Ass Message Board' started by lawman, Jan 3, 2012.
  1. lawman
    lawman
    Hey Guys and Gals, Anyboby have any good pictures of home made shop
    press tooling.I know that everbody uses sockets and pipes but I've searched the "Garage Journal" and our very own "Home made Tools and Equipment" and found very little home made stuff.This old man would love to see what you have made. Thanks so much for your time and talent.
  2. Bcap55
    Bcap55
    from PA, USA
    Here is a press brake I made for a 20 ton press. The upper and lower dies are made from 4140 bar stock. The upper die is 1"x 3" and the lower is 1 1/2"x 1 1/2". It bends 1/4" flatstock for brackets with ease. I also made a die set to bend sheet metal with.
    lothiandon1940 likes this.
  3. bct
    bct
    how did you cut the v notch and male die?
  4. lawman
    lawman
    Bcap,Very nice work.
  5. Bcap55
    Bcap55
    from PA, USA
    I made both pieces on my milling machine.
    Here is a test bend I made with 1/4" x 2" flatstock
  6. Bcap55
    Bcap55
    from PA, USA
    I made this male and female die set to form a beaded detail in a piece of aluminum.
    Which eventually became this.
  7. A Rodder
    A Rodder
    GREAT start to this thread!
  8. river1
    river1
    i agree let's keep it going
    later jim
  9. carsluTT
    carsluTT
    nice work, i need something along these lines
  10. striper
    striper
  11. bct
    bct
    thanks . very nice workmanship. i've looked for the bottom/top press brake die on ebay and such but they are very costly for a hobby shop.i'll ask at the machine shop.
  12. Dave_D
    Dave_D
    from NY
    You may want to check out this press brake kit from Swag Off-Road. It gets great reviews from the 4x4 crowd, and at $150 it seems to be reasonably priced. I plan on ordering one soon.
    http://www.swagoffroad.com/20_Ton_Press_Brake.html
  13. Rem
    Rem
    As a cheap alternative, you can easily fabricate something along those lines using round bar, box section, or angle iron. It may not last as long, or give as nicely defined or repeatable bends, but for the occasional bracket it can work (that's not to take anything away from Bcap55's tooling).
  14. lawman
    lawman
  15. b-body-bob
    b-body-bob
  16. need louvers ?
    need louvers ?
    Hopefully ElPolacko will jump in on this. The guy has got to be some sort of press tooling king! Next to his press is a six foot tall shelf full of dies to do damn near anything you can think of, and even several things you or I never thought of with a shop press!
  17. lawman
    lawman
    Found this on the net.May be crude,but I think it might work.
  18. lawman
    lawman
    Sorry I think this is the picture
  19. Dyce
    Dyce
    I made this die to bevel the exhaust openings in my x member for my model a.
    It works well either self centering or with guide studs.
  20. Meyer
    Meyer
    You might check in at practical machinist
  21. NJRATRODER
    NJRATRODER
    from NJ
    I have a 250 ton press at the shop. A lot of pipe sockets wired stuff you have to make to o the job i will take some pics. like the thread.
  22. MikesIron
    MikesIron
    from Union, OR
  23. bobj49f2
    bobj49f2
    I'm subscribed to both, all good ideas.
  24. 201
    201
    When making the male and female dies, how critical is taking in the thickness of the material to be worked. I know alot of the stuff would be short runs( 1 or 2 pieces), but always wonder'd about that. Also does it have any affect on the overall dimentions of the piece being worked???
  25. CRH
    CRH
    from Utah
    More please!
  26. chevy3755
    chevy3755
    love this thread........more please
  27. mlagusis
    mlagusis
  28. MikesIron
    MikesIron
    from Union, OR
    I think you're asking about punch-type dies, as in hole punches, etc. In that case, the ID of the hole should match very closely the OD of the punch, in order to get the required shearing action. If the male end is too small, it'll simply press the material down into the hole, get stuck, and not cut it cleanly, if at all.
  29. Bcap55
    Bcap55
    from PA, USA
    I like that. Seems like it does a nice job. I made a set of round dimple dies, never thought about making ones for oval holes. Nice job.
  30. lawman
    lawman
