Reply
Thread Tools Display Modes
Old 12-11-2011, 01:58 PM   #1
TABLAY
Newbie
Default Question turbo 350 shift arm seal
Got a transmission fluid leak. It's coming out the shifter arm thru the seal. Now the question...Is the seal installed from the inside of the transmission? It isn't like the rear yoke seal with a flange, it looks to be radiused from the outside. I don't know how I would remove it from the outside.
offline   Reply With Quote
Old 12-11-2011, 02:03 PM   #2
Old School HAMBer
squirrel's Avatar
Default Re: Question turbo 350 shift arm seal
from the outside. And there's a tool (K-D) that will pull it and install it without taking the pan off.
__________________
Jim Forbes
my shtuff
Old 12-11-2011, 02:05 PM   #3
TABLAY
Newbie
what's K-D? and where can I find one?
Old 12-11-2011, 02:08 PM   #4
Old School HAMBer
squirrel's Avatar
K-D is a tool company, they are distributed by auto parts stores like Car Quest.
Or you can take the pan off, take off the clip and remove the nut, and pull the shaft out, then pry the seal out with a screwdriver, and use a hammer and the right size socket to drive the new one in. then put it all back together, new pan gasket, fluid, etc.
__________________
Jim Forbes
my shtuff
Old 12-11-2011, 02:08 PM   #5
silversink
silversink's Avatar
K D is a brand name and you can find them at you NAPA parts store. They are usally on a turn table typ display with all kinds of off the wall tools that we need now and then
__________________
If it's worth doing---it's worth doing right---the first time
Old 12-11-2011, 03:36 PM   #6
olscrounger
Alliance Member
olscrounger's Avatar
what Squirrel said--get the KD tool and some seals--be careful when installing as not to damage the new seal-common issue on 350 trans--have replaced many with this tool
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
