Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 |
I have a 54 Chevy drum brakes. I want to know if anyone knows part #'s for a ball to Roller conversion?
Thanks Tyler
__________________
If you have time to lean....You have time to clean. http://panchodrinkthewine.blogspot.com/ |
#2 |
Grenade Inspector
Do you have the ball bearing part numbers? I can cross-reference them in the Timken database...
__________________
To every good project, a little blood must be donated. |
#3 |
Probably not exactly what you're looking for, but ECI provides the upgrade as a part of their disc brake conversion kits. It required an adaptor on the spindle and swapping the races out of the rotor. The kit provides both.
__________________
#4 |
I can't read some of the part # but this is what I got.
Inner Bearing 909702 Inner Race 989552 Outer Race 909501 Can't read the number on the outer bearing though.
__________________
#5 |
Senior Member
i heard 70s full size chevy
__________________
If the only thing you have is a hammer, treat everything like it's a nail. |
#6 |
Old School HAMBer
the 55-57 ball bearing hubs can be replaced with the early-mid 60s full size car roller hubs.
I don't think you'll find a "normal" roller bearing to replace the B52 inner bearing on the old car hubs. At least I couldn't find any when I was looking for them for my trucks. But on the bright side the ball bearings work fine, I have several original New Departure bearings in my 50s trucks, so they've been going strong for 50 yrs. I know it's nice to upgrade, but lately I'm getting the hamb mentality of only upgrading stuff that really needs it. wheel bearings are not in that category. |
#7 |
Alliance Member
Chevy Duty ( www.chevyduty.com ) lists replacement roller bearings for 55 - 59 trucks, both the inner and outer. However, my catalog is a few years old, so they may not sell them anymore. More importantly, I'm not sure if 54 and older passenger cars used the same front wheel bearings as 55 - 59 1/2 ton pickups.
If they did use the same bearings, then these should work. I've bought a set of these bearings for my 55 1/2 ton. They work with the original front hubs and drums, so I didn't have to replace anything else but the bearings.
#8 | |
Old School HAMBer
Quote:
xxx Brandy If you take that COMPLETE bearing (inner and outters) to your local auto parts store (no NOT kragens) or a bearing place like Kanter, they can cross ref it for you and find the numbers if a few of them are missing.
__________________
Did your mother not hold you enough as a child? Last edited by Brandy; 08-02-2005 at 02:32 AM. Reason: afterthought |
#9 | |
Alliance Member
Quote:
#10 |
Grenade Inspector
I believe Brothers truck has a kit for this change over. Ed ke6bnl
don't have the catalog here at work E d
__________________
1950 F1 street rod 1949 F1 stock v8 flatty 1948 F3 parts truck 1953 Chevy 3100 AD project 2B on 85 S10 chevy frame 1972 El Camino chopped 4" 1968 Mustang coupe 1953 Mercury wagon project Ed ke6bnl@juno.com Agua Dulce, So. Calif. 70 Miles N.E. of Los Angeles |
#11 | |
Old School HAMBer
Quote:
Anyone? Beuler? BTTT
__________________
www.vagabonds.cc "Don't stop fighting until the blood on your sword is the Kings" |
#12 | |
Old School HAMBer
Quote:
#13 | |
Quote:
#14 | |
Alliance Member
Quote:
I took the wheel bearings from Slide Jr's pedal car to a bearing place here in Dallas, and matched them up with some sealed berings rated for up to 14,000 RPMs! If you hit them at a time when they're not swamped, they'll usually work with you. If you have the spindles and/or hubs off the car anyways, bring them with you as well.
__________________
Just because you can doesn't mean you should. My blog about cars, art, and other stuff: http://mikeshoaf.blogspot.com/ |
#15 | |
Old School HAMBer
Quote:
__________________
THEM TX "Nomad" |
#16 |
Alliance Member
He's only had it up to just shy of 9 grand, but that was all they had in stock!
__________________
#17 |
UPDATE.... I have gone to ever web site and all the places in town that deal with bearings and they all say that there is no roller bearing replacement to that size ball bearing. Guy at the last place said he has a 50 chevy and was pretty bummed when he researched it 6 months ago.
So everyone don't waste your time looking.
__________________
#18 |
Senior Member
Here's another one...I tried to adapt the '61 hubs to the original spindles, but no bearing was available for the inner due to the odd size of the spindle...I guess on could have the spindle machined down to a standard size...
Brian
__________________
Wisdom has two parts. Having a lot to say, and not saying it.... |
#19 |
Alliance Member
49 to 54 Chevy car and 53 to 62 Corvette use the same front end. I looked all over for a conversion--but no luck. I carry an extra set of bearings just like I did in my 55 chevy when I was a kid. When I made a left turn and heard that "crack-pop" sound I would just pull over and put in a fresh one, usually the left outer.
overspray
__________________
A professional painter DOES NOT get "RUNS"--They are called "FLOW CHECKS." |
#20 |
Senior Member
I dont mean to steal your thread ,but since everyone is on the subject of bearings, is there any advantage to switching to the '61 -'64 rearend in my '60 Chevy car ?I have already done the front bearing / hub thing.I have heard that the axle bearings in the '60 and under GM's are expensive and the seal and bearing are one assembly.Is this true with '61 - '64 also?
__________________
SB 1963 DART:11.48 @ 113.2 ,1.63 60' ,8.5 slicks and no traction bars with a 2600 launch |
| Thread Tools | |
| Display Modes | |
