Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 01-22-2012, 06:29 PM   #61
JeffreyJames
Old School HAMBer
JeffreyJames's Avatar
Default Re: "RUSTY" Hemi Model A on 32 frame build
Busted!!!
Rear spring brackets are nice looking. Steady progress...keep it coming.
__________________
I PLAY WITH TIGERS
WWW.SUGARCITYSPEEDSHOP.COM
offline   Reply With Quote
Old 01-23-2012, 08:01 AM   #62
Noland
Senior Member
Noland's Avatar
Quote:
Originally Posted by thunderbirdesq View Post
Keep it up, ginger.
Looks killer Noland!
Thanks everyone for the kind words, thunderbirdesq thats one awesome thread you got going aswell.
__________________
RUSTY hemi Model A Coupe build
http://www.jalopyjournal.com/forum/s...d.php?t=647364
Old 01-23-2012, 08:03 AM   #63
Noland
Senior Member
Noland's Avatar
Quote:
Originally Posted by JeffreyJames View Post
Busted!!!
thanks, yea steady progress is how you get these things done. alittle bit at a time, cant become overwelmed with the task at hand.
__________________
Old 01-23-2012, 10:09 AM   #64
laidout53
laidout53's Avatar
Frame works looking awesome dude!
__________________
~HARBOR KUSTOMS~
"Where everything is....Kustom!"
1953 Dodge pickup-Full kustom build
Old 01-23-2012, 10:43 AM   #65
Noland
Senior Member
Noland's Avatar
Quote:
Thanks Man, not too bad for a punk kid. I just put some thought into it, and alot of time too.
__________________
Old 01-24-2012, 03:48 PM   #66
Noland
Senior Member
Noland's Avatar
I did change the ladder bar crossmember like I said I was going to. I thought it was just to plain and I couldnt figure out a way to make the drive shaft loop look good. I was thinking about an I beam look like I used on many other parts but I decided against it. I did flip the plate the ladder bars mount to so the tie rods could come in from the bottom. I decided to give the car a more radical rake so this actually worked to my benefit setting my pinion angle right were it needs to be at 4 degrees. Well heres what I came up with.
and installed
__________________
Old 01-29-2012, 03:43 PM   #67
Noland
Senior Member
Noland's Avatar
I managed to get some new subrails fabricated for the car, using 2x1 rectangle tubing and a bunch of cutting and welding. I didnt take a picture of them but theyre pretty simple. But I did manage to start getting the body mocked up. I still have to add all the bracing to keep it square while I attach it to the new subrails.
I also received my rear wheels from summit, they are the pulsar series. the rears are 15x10 and the fronts are 15x4 which Im waiting for they were backordered. Im happy with the way they look really didnt like the 15x8 because the offset makes it look funny. now I just need tires.
__________________
Old 01-30-2012, 05:57 PM   #68
Noland
Senior Member
Noland's Avatar
managed today to start building/rebuilding the door posts of the car to attach them to the new subrails.
__________________
Old 02-02-2012, 07:30 AM   #69
Noland
Senior Member
Noland's Avatar
I got the body secured and braced enough that I could start to chop the coupe. I didnt want a super big chop so I chopped it 2 1/2" in the rear and 3 1/4 in front to give it alittle more raked effect. I also moved the top of the roof ahead 7/8" to give the back of the roof a slanted forward look instead of being straight up and down. this makes for alot more work in the chop but I thing it will be worth it in the end.
Then I started fitting a 32 header and windsheild post to the model A cowl and roof. I think its going to look pretty cool when its all back together.
__________________
Old 02-05-2012, 04:55 PM   #70
Noland
Senior Member
Noland's Avatar
Still working on the same car, I managed to get the 32 front header and windsheild post all tacked in where I like it. Im leaving all the final welding go till I get the chop near complete in case I have to tweak or do something different. I still have to make a million little pieces to make everything fit right.
I started on fitting the quarter window. I cut the top part of the window out and moved it back 1/2" and leaned the bottom foward to meet up with it. this gave it the same angle as the back of the roof. Then I cut the raingutter of to fix the rust underneath of it. I will eventually make a new rain gutter.
I made the patch fairly simply. I just used my HF bead roller to put the step in it for the raingutter. It worked out nice. Then I tiged it in place.
I also made the patch for the quarter window were it was rotted out. I use the beadroller to make the step in it as well. I didnt get a chance to fit and weld it in yet but Im pleased with the outcome of the patch.
__________________
Old 02-05-2012, 06:46 PM   #71
Rocket's Hot Rod Garage
Grenade Inspector
Rocket's Hot Rod Garage's Avatar
You've got some neat ideas. Looking forward to seeing how it all turns out.
Old 02-06-2012, 07:47 AM   #72
Noland
Senior Member
Noland's Avatar
Quote:
Thanks Riley, yea I wanted to do something different with this car because I already have a Model A and I didnt really want two of the same car.
__________________
Old 02-06-2012, 06:59 PM   #73
I SMELL SMOKE
Senior Member
I SMELL SMOKE's Avatar
this thing is going to look killer!!!!!
__________________
CHECK OUT MY COUPE BUILD THREAD http://www.jalopyjournal.com/forum/s...d.php?t=283505
Old 02-07-2012, 07:44 AM   #74
Noland
Senior Member
Noland's Avatar
Quote:
Thanks thats the plan. I hope anyways. Your car is looking awesome too.
__________________
Old 02-08-2012, 02:50 AM   #75
jimbo121
Newbie
jimbo121's Avatar
Cool build. I like your ideas.
Old 02-08-2012, 08:49 AM   #76
Noland
Senior Member
Noland's Avatar
Quote:
Thanks Jimbo
__________________
Old 02-09-2012, 04:18 PM   #77
Noland
Senior Member
Noland's Avatar
I got the door top sheetmetal made and tacked on. I still need to make/modify the inner so I have something to attach the tin to. I used the same process as I did with the quarter window. That bead roller is really paying for itself on this project. The reason I made a whole new top was because the old top was full of holes. I hope on the right side I will be able to use more of the top.
__________________
Old 02-09-2012, 04:37 PM   #78
Grenade Inspector
Nice profile.
Old 02-09-2012, 06:26 PM   #79
robber grin
Grenade Inspector
robber grin's Avatar
Daaggumm... get down with your bad-self.
I'm enjoying watching it come together and it does have a sweet profile too.
__________________
John 14:6
Old 02-09-2012, 06:33 PM   #80
thunderbirdesq
Old School HAMBer
thunderbirdesq's Avatar
cool!
__________________
Lost Kustoms~TWICE PIPES~
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
