Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 |
Senior Member
Just rebuilt a Holly 600. This is my first rebuild on a carb so I'm sure I've done something wrong. What is happening is the carb seems like its DUMPING fuel in. Its all comming out the back of the car in a cloud of gas. I changed the power valve to see if that would help. Seemed like it helped for about 5 sec then it was running too rich again. I can screw the idle screws in all the way and still runs like that.
Did I miss something obvious? |
#2 |
Old School HAMBer
Start with your float level adjustment, and also check to be sure that the needle and seat is not sticking.
#3 |
Sounds like you've got some crap in the needle and seat.
#4 |
Did the engine backfire (even once) after you changed the power valve? If you did not add the checkvalve kit the power valve could be blown again. The kit is a ball and maybe a spring that is added to prevent the power valve from blowing every time the engine backfires. Years ago my Camaro had some downtime because I didn't know about the power valve blowing due to backfires.
#5 |
Old School HAMBer
If you have your idle speed set to high you will be running off of the MAIN circuit, not the idle circuit... the screws wont do anything if that's the case...
#6 |
Senior Member
No back fires, and the idle is not too high. I've done a few diffrent settings to play with it.
I'll, now, play with the needle and see what I can find. Thanks all for the info! |
#7 |
Senior Member
OCP look on the passenger side of the carb at the float bowls.You will see a flat head screw one for the front, one for the back.
Remove the screws. Look for fuel to come out. If fuel is gushing out your float level is too high. On the top of the bowl is another screw and 5/8" jam nut. Loosen the jam turn the screw clockwise 2 full turns. Now you have lowered the float. Do this to the front and rear. Leave the side screws out -start the car Let it idle only. Now no fuel should be coming out either bowl. If so. Shut it off and lower the float some more-1 turn Restart and slowly raise the float,untill you see fuel just start to dribble out the side hole. tighten up the float screw and jam nut. Screw in the side screws.(sight plugs) and repeat on the rear bowl. WALAA you have just set yer float bowls so give it a try. FEDER |
#8 |
Senior Member
Tried reseting the float. Biggest problem is I can't keep it idling long enough to set the float when its running. The car isn't "running rich" it is puffing fuel out the back in big grey clouds. Feels like a cylinder is not firing or something, but that is unlikely to be the case as the car was running fine with a (much newer) Holley 750 on it. I went though and checked all the plugs and cleaned them all up. Checked the needle and found no dirt or anything in there. Its like something is staying open spraying fuel down the carb. I can idle it long enough to let it run and look down the carb either. I have to keep my foot on the accelerator to keep it running. Bring the rpms up to about 1500, but it doesn't feel good. And then I just make a huge cloud of gassy smoke that I'm sure my neigbors love.
I don't know what the deal with it is. |
#9 |
Old School HAMBer
Possible vacuum leak somewhere?
Discharge nozzles loose/leaking? Bowl vent plugged or damaged? Too much fuel pressure? Just a few quick ideas, without being there to see it in person! |
#10 |
Old School HAMBer
Did this carb work on the car before you rebuilt it?
If it came from another car, did that one run? I'd take it apart again if you don't know the carb and see if everything is what it's supposed to be. You'd be surprised what people do to modify Holley carbs. I bought one used years ago and had to change jets, springs, choke and about everything else. Found out later it was a carb off a gasser. You probably have a stuck float as the first guess. The overflow is running the car instead of your idle circuit. |
#11 |
Old School HAMBer
Hey Hack... a vacuum leak would make it run lean...
I would give a good shot of carb cleaner or brake cleaner through the air bleeds (use the little red straw)and see what that does. As far as the float level, pull the sight plugs as soon as it dies and check it. If fuel comes gushing out, it's way too high... stuck float or something... if it doesn't, that's not your problem. |
#12 |
Tech Editor
I'll second the air bleeds (little brass plugs w/small hole in top of carb facing up) - blast 'em with carb cleaner. I had one that was only partially plugged & it gave me fits for weeks until I found it. Not difficult to drop a piece of gasket scraping down the metering block or main body portion while cleaning the carb with it apart either!
To adjust floats, remember the screw on top just unlocks the adjustment - it's NOT the adjuster. The nut is the adjuster - clockwise lowers float level. Now that you've monkeyed around with it & may not have a good idea where you're at with the float level to begin with, I'd pull the bowls & adjust the floats visually. ith the bowl off, turn it upside-down & adjust the float level until the top of the float is level with the top (now bottom) of the bowl. Set your idle screws 1.5-2 turns out & that should get you running. This should get you running if everything is as it should be. If not, then something else is wrong & it needs to come apart again...
#13 |
Senior Member
Some new observations. The secondary bowl keeps over filling with fuel. I have the needle set to where it should not be so high. I've even pretty much put the needle all the way down with should have not allowed ANY fuel to get in there and there was still fuel in there. I took the bowl off and visually checked the needle and float for good movement. Everything there looked good. Any reason the secondary bowl would get fuel from somewhere else?
#14 |
Old School HAMBer
you may have a leaking float... It will fill up with fuel, and as such, won't "float".
#15 |
Old School HAMBer
check the float itself to make sure it hann't filled with fuel. I still have a float bouncing around the back of my truck had a pin hole and filled up, it never shut off the fuel supply.
TZ |
#16 |
Also...make sure the "tang" on the float has not been bent outta shape........a little creative bending might fix it.....and shake it to be sure it has no fuel in it.....check the needle and seat REAL good !!
Jersey Skip |
#17 |
Tech Editor
[ QUOTE ]
Any reason the secondary bowl would get fuel from somewhere else? [/ QUOTE ] No, as mentioned, you may have a sunk float. OR your needle/seat is screwed. If you've got the old one from before the rebuild, try it out. Also check the tab/tang on the float as mentioned. Good Luck!
#18 |
Alliance Member
Make sure your oil isn't contaminated with gas, quick way to ruin an emgine. Trust me. I've been fighting a out of the box new Demon, Changed oil twice in about 1 hr of running.
#19 |
Alliance Member
One thing he hasn't mentioned is that the tube, not sure if it is a "bleed" or not, that sticks up out of the front of the choke horn is cracked down the side. The ONLY reason I mention this is because I've had fuel come pouring out of mine on a Holley before. Is it possible that some air to fuel pressure ratio is off because of this cracked tube?
#20 |
Senior Member
I seem to have the secondary bowl under control. It is still getting more fuel than I think it should, but the level is good. It almost comes out of the site plug, but not quite. Long story short that seems to be what is not puring fuel in the carb. I can make it idle on its own if I allow the big vac port to suck air in. And its even better if I crack the secondaries. :-)
I don't think that tube is the prob. But who knows. I'll ask this though... The choke linkage has been taken off and the choke flapper has been wired open. Does the linkage being gone have anything to do with this? |
| Thread Tools | |
| Display Modes | |
