Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 11-08-2011, 04:28 AM   #1
777
Grenade Inspector
777's Avatar
Default Listen to a pre-war flathead V8 roadster running on nitro
I was wondering whether or not it would be worth the effort / WoW factor to run Nitro in the Belond roadster since that was his fuel of choice.
I like to keep this car as authentic as possible and have been kicking the idea of mixing nitro in the tank around for awhile.
So I added this link to the roadster running on 20% Nitro http://www.youtube.com/watch?v=WLFTO0Bx9-E
but Sandy's "Hot Fuel" fuel formula of choice in 1942 was 58% Methanol, 20% low octane gas, 20% Nitro, 2% Castor oil, 572.0 cc Xylene per gal., 46.3 cc Ethyl Iodine per gal., 1.0cc per gallon Ethyl fluid. I Didn't blend this and I don't recommended doing it either.
Instead I blended 55% Methanol, 20 % Nitro, 20% race gas 4% Benzol and 1% Castor oil.
Results: When the jetting is close you can barely tell there is nitro present but as it loads up there is a bit more cackle and it does rev a little quicker. Yes it burns your eyes and people do know your running alcohol and the castor oil is pretty easy to decipher. That seems to get more people excited then anything else.
But I also tried VP M5 which is a complex hydrocarbon, methanol blend and it does run a lot harder on that but it smells "orangey" and I'm not sure either is really worth the effort.
At least this way if you were wondering what it would sound like if you tipped the can on your flattie, now you have an idea.
offline   Reply With Quote
Old 11-08-2011, 05:00 AM   #2
Human Fly
Senior Member
Human Fly's Avatar
Default Re: pre-war flathead V8 roadster running on nitro
My no no area feels funny!
__________________
WANTED: Lincoln Y block to 39 Ford box trans adapter.
online   Reply With Quote
Old 11-08-2011, 05:46 AM   #3
Jimmy B
Alliance Member
Jimmy B's Avatar
Hear that fucker snarl!!! Music I tell ya!
__________________
I don't paint by numbers.
Hot Rods of the Dry Lakes Era
jimmy
Old 11-08-2011, 05:50 AM   #4
captmullette
captmullette's Avatar
damn!! a bad ass flattie
__________________
captmullette, i started out with nothing, and I got most of it left....... in memory of my best friend "MULLETTE'
Old 11-08-2011, 06:12 AM   #5
flatheadpete
Old School HAMBer
flatheadpete's Avatar
Sounds pretty angry. I like it!
__________________
'Armin Tamzarian's reign of terror is over!'
-Superintendent Chalmers
Old 11-08-2011, 07:44 AM   #6
CAL
Alliance Member
CAL's Avatar
Thanks, that made my day.
__________________
"He's a speed addict. And its worse than dope."
-Edward De Roo-
Go, Man Go! 1959
Old 11-08-2011, 07:54 AM   #7
SUHRsc
Alliance Member
SUHRsc's Avatar
thanks....
__________________
www.zachsuhr.com
Old 11-08-2011, 08:41 AM   #8
v-v
FNG
v-v's Avatar
Post some more video at your roadster, it sounds so MEAN!!!!!!!!!1
Old 11-08-2011, 08:45 AM   #9
plan9
Old School HAMBer
plan9's Avatar
since nitromethane and methanol is expensive as shit, (plus all the other stuff you are mixing in $$$$) I'd only use it for showing off. i get what you are trying to accomplish though... wish i had sound at work!
20% is conservative, which is good... at El Mirage we gained about 10 mph with a tail wind, we started off with 100% methanol for a baseline then mixed up a batch of 20%. the 296 flathead happily made power up through 6-6500 rpm.
pump gas was shit during Belonds time and nitro didnt cost $25.00 or more per gallon. i bet the Castor oil was used to help preserve gaskets and seals. make sure you drain the fuel system after use and make sure you never go lean or your motor will eat itself
__________________
Panel Beaters CC / Sidewinders
Old 11-08-2011, 10:50 AM   #10
777
Grenade Inspector
777's Avatar
Thanks for the info Plan 9,
You might find this interesting, the old timer I got Belonds fuel formulas from told me they ran the regular gas because it would help to light the nitro.
Also I was hoping for more cackle myself and did go as high as 50%. It was more pronounced but it seems to me that the more fuel you throw at it the more it wants and it doesn't seems to ever flood like gas does but the fuel system just can't flow enough volume to keep up with the demand.
Note of caution for anyone who may attempt this. Advance the timing at least another 10 degrees ahead, to give the slower burning fuels more burn time, it seems unlikely that it will detonate, I went as far as 40-degrees ahead. And don't be scared to go Big on the jetting; actually I probably could have thrown the jets in the trash. My emulsion tubes are .125 and the jets are .098 for this set up.
On jetting. Once you go way outside of the fuel curve, think more then 7 jet sizes, the A/F ratio goes to rich in the tubes and the air bleeds will need to be opened up to compensate. I tapped the air bleed and installed screw in air bleeds instead. Eventually I also need to bore all the holes in the emulsion tubes and added another set of holes.
Old 11-08-2011, 05:01 PM   #11
777
Grenade Inspector
777's Avatar
Quote:
I'll work on it; I might pull the extensions off and head over to the Don Blair ceremony, uncorked, tonight at the Parks museum, if so I might be able to get something better shot.
Old 11-08-2011, 05:04 PM   #12
Human Fly
Senior Member
Human Fly's Avatar
Default Re: Listen to a pre-war flathead V8 roadster running on nitro
What are the details on your flathead???
__________________
Old 11-08-2011, 05:07 PM   #13
JC Sparks
JC Sparks's Avatar
You are going to need bigger tires. JC
__________________
Nitromethane is liquid Heroin
Old 11-08-2011, 05:11 PM   #14
Unkl Ian
Old School HAMBer
Unkl Ian's Avatar
Location: Just past the corner of Hell and The Twilight Zone.
Quote:
There were lots of different chemicals used to "ignite" the Nitro, because it doesn't really want to start burning.
__________________
Updated:
FlyingEyeballs.net
Old 11-08-2011, 05:12 PM   #15
Malcolm
Old School HAMBer
Malcolm's Avatar
WOW. That sounds AWESOME -- Thank you!!
Malcolm
__________________
www.instagram.com/hoesing
Old 11-08-2011, 05:14 PM   #16
Kustom Linez
Alliance Member
Kustom Linez's Avatar
Awesome sounds great!!
__________________
WANTED ---SINGLE SIDE OF HEMI EC6 EDELBROCK 6X2 LOG ---
www.chopped.com.au
www.kustomlinez.com
Old 11-08-2011, 05:16 PM   #17
Tman
Old School HAMBer
Tman's Avatar
What Malcolm said! Thanks!!!!!!!!!
__________________
Open for business, website in developement
www.compulsionrodandcustom.com
Old 11-08-2011, 05:28 PM   #18
jambottle
Alliance Member
jambottle's Avatar
Talking Re: Listen to a pre-war flathead V8 roadster running on nitro
That makes the hair on the back of my neck,stand up.I was up at Mike Longley`s in Florida, a couple of years ago and he started up the henderson Roadster for me and it gave me the same Feeling.I wonder if he has a vidio of it running.
__________________
my mother always told me;"you`ve got a champagne taste and a beer pocketbook"
Old 11-08-2011, 05:32 PM   #19
JeffreyJames
Old School HAMBer
JeffreyJames's Avatar
Best sounding engine ever. Ive listened to that like 5 times since you posted it on the 40's thread.
Any chance of a run down on some of your engine build?
__________________
I PLAY WITH TIGERS
WWW.SUGARCITYSPEEDSHOP.COM
Old 11-08-2011, 05:33 PM   #20
Iceberg460
Iceberg460's Avatar
Holy shit! That thing sounds f'in awesome. Thanks for posting man.
__________________
Wanted: 30-31 Model A Tudor or Pickup upper door skins (beltline up), ok if they need lots of TLC.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
