Reply
Thread Tools Display Modes
Old 10-28-2011, 10:44 AM   #1
rustyfords
Default Oil Bath Air-Cleaner to Paper Filter Conversion
I've been asked to share my method and photos for converting an Oil-Bath air cleaner to one that will accept a paper element.
The air cleaner in these photos is from a 55 tudor Mainline that my dad recently sold.
This is a VERY SIMPLE approach to this conversion and only takes a few minutes.
Here it is:
Step one:
On the lid, cut away the housing that contains the mesh filter. Leave enough material (as shown in the photo) to create a seal on top of the paper element.
It's important that you make this cut nice and straight.
Click image for larger version
ID:	1469918   Click image for larger version
offline   Reply With Quote
Old 10-28-2011, 10:47 AM   #2
rustyfords
Default Re: Oil Bath to Paper Conversion
Step two:
Drill relatively large holes in the base of the air cleaner as shown in the photos, to allow for air flow. If you need more air flow....drill more holes.
ID:	1469922   Click image for larger version
Old 10-28-2011, 10:49 AM   #3
rustyfords
Step Three:
Drill holes in the bottom of the base to allow air to enter the housing....again....more holes = more air flow.
Old 10-28-2011, 10:52 AM   #4
rustyfords
Step Four:
Take the base to the local parts house and test fit various paper elements until you find one that pretty much fits the diameter of the housing as well as the general height of the housing.
Measurements for this element are shown for anyone who has a 55 Ford.
ID:	1469925   Click image for larger version
ID:	1469926   Click image for larger version
Old 10-28-2011, 10:56 AM   #5
rustyfords
Step Five:
You're all done. Set the lid on top of the paper element and as long as the cut you made on the lid is nice and straight, it will dig into the rubber of the element a little bit when you tighten it down and you'll have a good airtight seal.
The air will flow in from the top a little bit, but most of it will travel into the housing of the unit and out of the holes on the inside.
When you open the hood, it'll look stock unless someone really gets close to it.
ID:	1469938   Click image for larger version
Old 10-28-2011, 10:58 AM   #6
rustyfords
Note:
This coversion is for someone wanting to keep the stock carb.
The conversion I did on my 54 Ford oil bath (see my build thread) was different because I wanted to mount it to a 4 bbl carburetor.
Old 01-08-2012, 10:54 AM   #7
Thefingerisout
Grenade Inspector
Thefingerisout's Avatar
Default Re: Oil Bath Air-Cleaner to Paper Filter Conversion
I had to check this out when I saw the header in your other posts. Good ol' American ingenuity!
__________________
"Don't pick a fight with an old man. If he is too old to fight, he'll just kill you." John Steinbeck
Old 01-08-2012, 12:40 PM   #8
38Chevy454
Alliance Member
38Chevy454's Avatar
Good creativity to keep the look with better filtering.
__________________
High Quality USA-made bear claw style latches CHEAP! Now have install kits also!
http://www.jalopyjournal.com/forum/s...d.php?t=620485
Purchase directly here: www.hotrodlatches.com
Old 01-08-2012, 12:46 PM   #9
dante81_98
dante81_98's Avatar
I did this for the air cleaner in my econoline. worked out great and kept that stock look and pretty much had the same exact steps you had here. Only caution that I would give is not to drill the holes until you know exactly where the filter is going to sit.
__________________
66 Econoline Truck
50 Ford Custom
50 Chevy 3100
Old 01-08-2012, 01:38 PM   #10
Rusty O'Toole
Old School HAMBer
I'd rather have the oil bath.
Old 01-08-2012, 01:42 PM   #11
40FordGuy
Old School HAMBer
Nice...........
4TTRUK
Old 07-25-2012, 11:33 AM   #12
fordvic54
FNG
fordvic54's Avatar
I'm concerned, my air cleaner for the 239 O/H valve V8 has 3 holes that come in the bore of the center tube of the bottom section. I can't tell by the pictures if this one has them for the 6 cyl. but I'm sure it does. The way I see it, this will allow the air flow to bypass the paper filter, correct? Maybe I'm missing something here.
Old 07-26-2012, 06:34 PM   #13
rustyfords
I don't remember there being any holes that would bypass the filter on this conversion.
If there were though, the quick answer would be to simply block them off. There'd be several ways to do so....one quickie that comes to mind would be to JB Weld some little metal patches over the holes. It's not going to be seen, so you wouldn't have to worry about it being perfect.
Old 08-26-2012, 12:40 PM   #14
jcmarz
Old School HAMBer
jcmarz's Avatar
There's a new thread on Oil Bath to Paper conversions titled "How to convert your 8BA oil bath air filter to paper/dry type" and posted by IowaMercMan. RustyFords method is simpler. So easy a Caveman can do it.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
