Go Back   THE H.A.M.B. > General Discussion > Hokey Ass Message Board
Reply
Thread Tools Display Modes
Old 10-26-2011, 05:37 PM   #1
Edelbroke
Edelbroke's Avatar
Default 55 Chevy windshield install. Can I do this myself?
I have an appointment for friday for a glass guy to come out an install a windshield in my 55 Chevy. I'd like to do it myself tonight and cancel the app. I have my own glass and a new seal. I'm not going to put the stainless trim back on it just going to be the seal and glass.
Are there any special tools to do this? I'd really like to do it myself and save a few bucks. Any tips would be great! Thanks
Click image for larger version
Name:	55 Outside 009.jpg
offline   Reply With Quote
Old 10-26-2011, 05:39 PM   #2
Old School HAMBer
squirrel's Avatar
Default Re: 55 Chevy windshield install. Can I do this myself?
It's not very easy to do it by yourself, especially if you've never done it before. I've only done it once, and I got help from a friend who'd installed a few.
__________________
Jim Forbes
my shtuff
Old 10-26-2011, 05:43 PM   #3
VoodooTwin
Senior Member
VoodooTwin's Avatar
You need 2 sets of hands.....one to hold/push the windshield tight against the seal from outside the car, while the other set of hands (inside the car) pulls the rope around to set the glass into the seal. I don't advise trying it alone. This shouldn't take the 2 of you more than 10-15 minutes, tops.
__________________
Concrete Jungle where dreams are made of
Old 10-26-2011, 05:47 PM   #4
Old School HAMBer
squirrel's Avatar
On these I seem to recall that you put the seal on the glass, then set the assembly into the opening with the bottom of the seal on the pinchweld, then pull the rope to work the seal onto the pinchweld.
__________________
Jim Forbes
my shtuff
Old 10-26-2011, 05:48 PM   #5
Chevy Gasser
Alliance Member
Chevy Gasser's Avatar
Yes you can do it yourself but it will be much easier with the help of a friend or two. I think squirrel might be right about the seal on the glass first, and I think you pull the cord around from the inside of the car. Besides the rubber channel you will need a rubber sealant that goes between the body and the rubber seal, this is an important step. If you want a good water tight seal it would be best to help and observe the glass guy.
__________________
www.mrchevynut.com
Old 10-26-2011, 05:52 PM   #6
BOWTIE BROWN
Alliance Member
BOWTIE BROWN's Avatar
I have a windshield for sale.
"AND THE BOWTIE ROLLS ON"
(see if the glass man won't help ya)
__________________
BOWTIE BROWN
YESTERDAY IS A MEMORY ...TOMORROW IS A VISION .....TODAY IS A BITCH
WOUNDED WARRIOR PROJECT.
Old 10-26-2011, 05:55 PM   #7
caseyscustoms
Default
If you've never done it before, then no. Hard enough with two people let alone one that's never done it.
Old 10-26-2011, 06:02 PM   #8
Chevy Gasser
Alliance Member
Like VooDoo said it wouldn't take 2 experinced guys long to seat a windshield but this is not a job to try to beat the clock. If you are changing the windshield on a finished car the job will take 4 hours. Unbolting the trim from the inside, removing the inner garnish molding and more. Also, for anyone who is replacing the stainless the upper trim goes in the channel before the windshield is installed. If you want a really nice car this should be polised before the windshield goes in also. A show quality finish on the stainless will take an hour or two.
__________________
www.mrchevynut.com
Old 10-26-2011, 06:02 PM   #9
Boeing Bomber
Senior Member
Boeing Bomber's Avatar
The rubber goes on the glass first, then the cord is pushed into the outer channel of the rubber, followed by a liberal amount of glass cleaner as a lubricant. The cord starts, and ends at the bottom, overlapping by several inches. Then the whole thing is set into the lower pinch weld with the extra cord on the inside, and pushed up against the window opening as close as possible. as you slowly pull the cord from the inside, the rubber will fold over the pinch weld. With the help of some one on the outside MILDLY pounding on the glass, open handed in the area you are pulling the cord from, the two of you will walk the rubber over the pinch weld. First a little on one side, then the other, until you meet at the top center. Some times you may need to work the cord in a circular motion (like 'Wax on") as you walk it along.
All that being said, it is FAR better to help a professional do this for your first experience, and learn from him. PLUS, after it's in you will still need to use a sealant to keep out the water leaks. If you try it with a buddy, and it leaks, it's all on you. If you pay to have it done, and it leaks, you can take it back to him and he'll have to fix it.
__________________
Beware of High Performance cars with Low Performance drivers
Old 10-26-2011, 06:03 PM   #10
slammed
Old School HAMBer
slammed's Avatar
Once it gets started, you may lube (WD-40) it, to help it slide in.
__________________
Ryan supports small business and American values.
Get's trolled.
Awesome. -097
Old 10-26-2011, 06:09 PM   #11
Blackmaria60
Blackmaria60's Avatar
Yeah, and that black good gets everywhere. I put my rear window in a '62 Olds and yuk
__________________
Step up or Step Aside
Old 10-26-2011, 06:30 PM   #12
Special Ed
Old School HAMBer
Special Ed's Avatar
Perfect description. That open-handed "pounding" on the glass is more than a little tricky. If you've never seen a guy who has done it, it can end poorly for you.
__________________
"If it's important you'll find a way, if not you'll find an excuse"
online   Reply With Quote
Old 10-26-2011, 06:44 PM   #13
low budget
Senior Member
low budget's Avatar
I put a back glass in a 55 by myself, I also bought and took a windshield out of a 55 without breaking it by myself ........... I then gently laid it on a peice of foam in the back of my truck,I then saw a crack line ease gently across the middle of it I then gently picked it back up and took it back to the car I took it out of and threw it back in it
(50 bucks shot)
I hate to say it but it might be cheaper to pay the guy to do it than to buy 2 windshields, winding up paying him to do it anyway.
Since you are paying him,will he be responsible if he breaks it?
Old 10-26-2011, 06:54 PM   #14
_ogre
Grenade Inspector
_ogre's Avatar
do like squirrel and bomber say. 2 of us put the front and rear glass in my truck. it's easy enough to do. a 3rd hand helps to push on both sides from the outside. use glass cleaner as lube not wd40.
the glass shop guys don't know how to put them in right. we had to re-paint a 63 vette from the glass shop guy messing everything up.
you are the best man for the job.
Old 10-26-2011, 06:59 PM   #15
bryan6902
Senior Member
bryan6902's Avatar
I always liked the fact that if the glass cracked, the installer/company buys you a new one. I think Danchuk has a how-to article on their web site. And you can get the trim in afterwards it just takes a lot of silicone spray and open palm hits.
__________________
Check out my 57 Pontiac build!
http://www.jalopyjournal.com/forum/s...d.php?t=332564
Old 10-26-2011, 07:07 PM   #16
VoodooTwin
Senior Member
VoodooTwin's Avatar
Quote:
Yeah, you're right. I misremembered. Gettin old sucks.
__________________
Old 10-26-2011, 07:22 PM   #17
Edelbroke
Edelbroke's Avatar
Thanks for all the replys. I'll learn on friday with the pro.
Old 10-26-2011, 07:28 PM   #18
tooljunkie
Grenade Inspector
tooljunkie's Avatar
done lots,broke one.My co-worker was in a hurry.i have roped in quite a few,the open hand is like a gentle slap.centre outwards and patience.outside on a warm sunny day doesent hurt,just more glass cleaner for lube-you dont want to use anything else as it can be difficult to clean off later.a bead of butyl sealant under the molding and you are done.butyl will ooze out in very hot climates.check with your local glass supplier.
as mentioned earlier,learing from a professional may be in your best interest.
it will be money well spent,you wont have to spend it again.thats how i learned a few procedures in my past.
Old 10-26-2011, 07:35 PM   #19
60galaxieJJ
Senior Member
60galaxieJJ's Avatar
Just out of curiousoity about how much do they charge to come out and do that? I ask because I'm in the same boat and wanna know what I'm getting into
__________________
BUILD IT, AND THEY WILL CUM
Old 10-26-2011, 08:29 PM   #20
40Standard
Old School HAMBer
soapy water, a plastic putty knife, twine and the old lady to help. it's not that hard on a 55 chevy. try looking on youtube for a video
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
