Welcome to the THE H.A.M.B. forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! |
Thread Tools | Display Modes |
#1 |
Grenade Inspector
Model A "Easy Weld" Boxing Plates Our Easy Weld boxing plates are cut undersized so that they would basically slip inside the original frame rails, to allow for a V gap for great weld penetration, without the worry of grinding away too much weld and sacrificing strength when grinding the welds flush. There are steps or outward notches incorporated into our boxing plates to prevent them from slipping inside the frame and making fitting and adjusting difficult. These are cut from either 1/8" (10 gauge) or heavier 3/16" steel to give even more added strength when welding motor mounts, crossmembers and etc to the inside of the chassis. The 3/16" plates also allows more threads, when drilling and tapping holes for clamping brake & fuel lines, wiring, etc. This is a 6 piece set. The two longer pieces run from the rear of the frame, right up to the front crossmember. The main plates are made in 2 smaller pieces for ease of shipping and to reduce shipping costs. The smaller 2 pieces for the frame horns may not be needed, but can be used (whole thing or trimmed to needed length) with certain independent suspension front crossmembers, and/or if you are wanting a cleaner look up front and are not using the front splash pan. These will fit 28, 29, 30 & 31 model a cars or trucks To state the obvious..some assembly, fitting and welding is required. =) NEW Featured Product! Model A "Easy Weld" "DIMPLED" 1/8" Boxing Plates $325 https://www.paypal.com/cgi-bin/websc...=5P6M2MWXTXFFC Model A "Easy Weld" 1/8" Boxing Plates $150 with FREE shipping for the HAMB! https://www.paypal.com/cgi-bin/websc...=3GRWUPGX253EW Model A "Easy Weld" 3/16" Boxing Plates $200 https://www.paypal.com/cgi-bin/websc...=CECB52T89YG6J Model A "Easy Weld" "Drilled" 1/8" Boxing Plates $225 https://www.paypal.com/cgi-bin/websc...=27CAY4SUNXGPC If you need to see the appropriate pictures for the different sets for clarification, see the website link in my sig. Use the Above links to purchase them using PayPal or a Credit Card, with or without an account or PM me for other payment methods. Thanks, Brian
__________________
Model A/T/32/33-34/35-40 Ford Boxing Plates, Shrinking Discs & more www.wolfesmetalfabrication.com Last edited by metalfaber; 03-22-2013 at 06:11 PM. |
#2 |
Grenade Inspector
bump ttt
__________________
Model A/T/32/33-34/35-40 Ford Boxing Plates, Shrinking Discs & more www.wolfesmetalfabrication.com |
#3 |
FNG
Brian, I would like a set of the Model A plates (1/8). I can send a check or Mo now and you ship when receiving or give you a CC number. Which do you prefer. I am not up on Paypal. Would you give me a phone number?
Thanks, Bill |
#4 |
Grenade Inspector
Bill, which ever works for you, is ok with me. You can also use a credit card through the PayPal links without having or logging into a PayPal account, but I will be more than happy to run your card for you if you would like.
Wolfes Metal Fabrication Brian Wolfe 335 West St. Bradshaw, NE 68319 (402) 366-7303
__________________
#5 |
FNG
Check sent 10/05/11.
Thanks 29kyham |
#6 |
Grenade Inspector
29kyham, sounds good!
Brian
__________________
#7 |
Grenade Inspector
bump ttt
__________________
#8 |
Grenade Inspector
Bump ttt
__________________
#9 |
Grenade Inspector
Got Plenty ready to ship on Monday!
__________________
#10 |
Grenade Inspector
bump
__________________
#11 |
Grenade Inspector
Just cut up a bunch more sheets in all flavors of boxing plates.
__________________
#12 |
Grenade Inspector
Bttt
__________________
#13 |
Grenade Inspector
Currently working on Belled or Dimpled hole plates for the Model A's, should have some ready to ship in a week or 2, contact me if interested! Will be first come first serve till I can get ahead and get them in stock.
Initial pricing is going to be $325 a set, and I can ship them in the US for $25. EDIT: New pictures of the complete set can be seen above.
__________________
Model A/T/32/33-34/35-40 Ford Boxing Plates, Shrinking Discs & more www.wolfesmetalfabrication.com Last edited by metalfaber; 11-18-2011 at 06:05 PM. |
#14 |
Grenade Inspector
Weekend Bump
__________________
#15 |
Grenade Inspector
Updated with the Dimpled set info!
__________________
#16 |
Grenade Inspector
Starting this weekend, first person to post up on the Sneak Peak Thread (so we know who gets them) and purchase one of our NEW Dimpled set gets Free shipping for them!
The Sneak Peak Project Thread http://www.jalopyjournal.com/forum/s...d.php?t=639310 First Post there saying they want a set, gets free S/H (contact me for shipping free invoice) Brian =)
__________________
#17 |
Grenade Inspector
bump for thanksgiving weekend!
__________________
#18 |
Grenade Inspector
ttt
__________________
#19 |
Grenade Inspector
ttt
__________________
#20 |
Grenade Inspector
Bump
__________________
| Thread Tools | |
| Display Modes | |
