Reply
Thread Tools Display Modes
Old 09-29-2011, 02:50 PM   #1
Kustom7777
Old School HAMBer
Kustom7777's Avatar
Default anyone know an easy way to remove the galvanizing from emt?
does anyone know of a way to remove the galvanizing from conduit other than grinding it? is there a chemical process or some other method that would work effectively? thanks,,,,,
__________________
WANTED: DEAD OR ALIVE- a set of 57-61 studebaker hawk fins
offline   Reply With Quote
Old 09-29-2011, 02:54 PM   #2
badshifter
Alliance Member
badshifter's Avatar
Default Re: anyone know an easy way to remove the galvanizing from emt?
Muriatic acid (pool acid). Gloves, glasses and outdoors! Will smoke and fizz like CRAZY and when it stops, you'll have nice raw metal. Works like a champ.
__________________
And If you aren't into traditional cars, find another forum.
Ryan Cochran
Old 09-29-2011, 02:56 PM   #3
OLLIN
Old School HAMBer
OLLIN's Avatar
uh oh! what could he be up to now...?
__________________
I Need a decent model A Rumble Lid Please!
online   Reply With Quote
Old 09-29-2011, 02:56 PM   #4
belair
Old School HAMBer
belair's Avatar
Don't breathe the fumes. I bet they're zinc-y and bad for you.
__________________
Every knee will bow
H.A.M.B. Chapel
322 Naihead and complete stick set-up for sale
Old 09-29-2011, 03:14 PM   #5
badshifter
Alliance Member
badshifter's Avatar
I was bored, so I did a quick sample for ya. Did I mention fumes? Very bad.
Click image for larger version
ID:	1442421   Click image for larger version
ID:	1442422   Click image for larger version
__________________
Ryan Cochran
Old 09-29-2011, 03:29 PM   #6
thesupersized
Senior Member
thesupersized's Avatar
Im assuming you want to remove the galvanizing to weld it. I came across this online, I didn't read the whole thing, and im not sure how true it is, but I'm pretty sure it says welding galvanized steel has no long term affects on you, and it's not as bad as most people think.
http://www.sperkoengineering.com/htm...Galvanized.pdf
__________________
I like real customs.
Old 09-29-2011, 03:29 PM   #7
BLUECOLLARKUSTOMS
Grenade Inspector
BLUECOLLARKUSTOMS's Avatar
Dont store it in an open container inside your shop, it will turn all your tools in your toolbox and any other bare metal orange with rust by morning, just from the fumes. I'll never do that again.....Scott
__________________
Its a life, Its a hobby, and so thats what I do
I'M A KUSTOM CAR BUILDER "Gene Winfield"
Old 09-29-2011, 03:50 PM   #8
badshifter
Alliance Member
badshifter's Avatar
You may want to read the whole thing before you say it ain't bad for you. Do you really trust your life to an article on the internet?
From your article:
Typical “metal fume fever” begins about 4 hours after exposure, and full recovery occurs within 48 hours. The symptoms
include fever, chills, thirst, headache and nausea. All of these symptoms, pain and suffering, as well as lost work (and play)
time, can be avoided entirely by simply not inhaling the zinc oxide fumes. This can easily be done using any of the
methods described later.
To complement proper positioning, a fully effective method to preventing inhaling zinc fumes is to wear a suitable respirator
(mask). Some of the commercial products which are suitable are:
Masks that are not properly fitted will not be effective in protecting the welder since the zinc oxide can be pulled through any
openings between the mask and the welder's face. Welders who are given masks or any other kind of personal protection
equipment have to be trained how to adjust them so that they work correctly. In addition, OSHA regulations (29CFR Part
1910.134(b) requires that fabricators have a written procedure for use of personal protective equipment such as respirators and
masks; that the equipment be selected from that approved by the Mine Safety and Health Administration and the National
Institute for Occupational Safety and Health; that the equipment selection be based on the hazard to which the welder is
exposed; that only employees who are physically capable of doing the job and know how to use the safety equipment are
assigined to perform work; that respirators are cleaned and disinfected regularly, stored in a convenient, sanitary location and
kept in good repair; that the work area be monitored for changes in exposure; that the medical status of employees is
reviewed regularly; and that the program be reviewed on a regular basis to appraise its effectiveness. OSHA does not
currently require periodic medical evaluation of employees, but that is under consideration. Disposable masks eliminate
some of the hassle associated with meeting these OSHA regulations.
__________________
Ryan Cochran
Old 09-29-2011, 03:50 PM   #9
twochops
Senior Member
twochops's Avatar
Save the old Black acid in a
closed jam
if you have to solder or tin some bare steel
it will do the job.------TwoChops
__________________
I TOLD YOU A MILLION TIMES NOT TO EXAGGERERATE
Old 09-29-2011, 05:51 PM   #10
stealthcruiser
Old School HAMBer
stealthcruiser's Avatar
Get a piece of vinyl rain gutter, ( the length to hold your EMT), and cover the EMT with the strongest vinegar you can buy........................Works well, if a little slow, check it in a day or two, and swap out the vinegar if it's progress slows or stops.
And do it outside.
__________________
Chuck
Old 09-29-2011, 07:54 PM   #11
Zeke
Senior Member
Zeke's Avatar
Quote:
And do it outside.
Agreed I've done it and didn't have an issue welding on the metal. But let it sit for a good bit, and rinse rinse rinse
Old 03-16-2013, 07:56 AM   #12
lippy
Old School HAMBer
lippy's Avatar
Why use anything galvanized? What cha up to? LOL. Lippy
Old 03-16-2013, 08:48 AM   #13
swade41
Old School HAMBer
swade41's Avatar
I was just looking at conduit to make the structure for my tilt front end and thinking of a way to get rid of the galvanizing.
__________________
Gasser Gang of WNY
Old 03-16-2013, 09:01 AM   #14
readhead
I know conduit is cheap but why not buy tubing the same size. If you need to remove the zinc where you want to weld heat it with a torch and brush it off. We generally put a fan close by and blow the fumes away.
Old 03-16-2013, 09:18 AM   #15
eugene vik
Alliance Member
eugene vik's Avatar
braze it and dont inhale, it brazes real easy
other choice steel tube and wire feed
JMHO
__________________
disabled nam vet. BSU, MSU , NDSCS , Alexandria Tec. , ASE Tripple Master Tec.
Old 03-16-2013, 10:31 AM   #16
bobss396
Old School HAMBer
bobss396's Avatar
I don't think that all EMT tubing is galvanized, shop around.
Bob
__________________
Proud member of the "they closed my thread" HAMB crew. -- BobSS396
Old 03-16-2013, 10:45 AM   #17
gatz
gatz's Avatar
Quote:
that's very light tubing to make something requiring structural strength.
by the time you get that coating (partially?) off and figure your time is worth anything, you could buy some steel tubing as suggested above and be further ahead.
Old 03-16-2013, 11:08 AM   #18
Weasel
Old School HAMBer
Weasel's Avatar
Anyone mentioning EMT and hot rod in the same sentence makes me nervous. One of my criteria of a 'Redneck engineered' car includes the use of galvanized tin and tubing....
__________________
Procrastinate NOW!
Old 03-16-2013, 11:21 AM   #19
WillyKJr
Alliance Member
WillyKJr's Avatar
Quote:
I'm with ya on this one Weasel. Seems the discussion is going in the wrong direction. There should be a fab shop (hot rods, race cars, agricultural, etc.) within a short distance of everywhere to get the proper material for this job. Don't cheat with your safety, use the right stuff. Especially on a cool project like this one.
Old 03-16-2013, 11:30 AM   #20
choprods
Alliance Vendor
choprods's Avatar
Location: Elmer,Mo.USA All the COOL... people on the HAMB have already been here,why haven't you?
Jim the best and least lethal way to use Conduit [traditional Kustom method of construction BTW]....Is to use a coarse Cup style wire brush on a hi speed angle grinder and just bear down and burn it right off.
It does a nice job and you should use a good dust mask while doing that.... it works well and is la lot less mess.....
__________________
Running in place, will never get you the results that running from a Lion will.....
Old 03-16-2013, 12:09 PM   #21
Engine man
Senior Member
Quote:
Originally Posted by iwanaflattie View Post
Hey guys.
I've read about the dangers of welding galvanized So I googled for a welding mask that could help with the fume problem but also that Is not bulky to wear under a welding helmet.
I found this:http://multimedia.3m.com/mws/mediawe...9925DS.pdf,but it looks like it's only available in the UK.
Anyone know how to get it in the usa?
thanks.
Also this would be great for welding inside the cab etc.
Better to use a powered respirator that sucks air through a filter and puts it in a mask under pressure so you don't suck fumes around the mask.
__________________
Anything dropped while working on a vehicle will roll underneath to the exact center.
Old 03-16-2013, 12:11 PM   #22
hotrod40coupe
Alliance Member
hotrod40coupe's Avatar
EMT is a lot stronger than you might think. We used to make Go-karts out of it that would run 70-80 MPH and never had any problems.
__________________
Racing is the process of turning money into noise.
Old 03-16-2013, 12:35 PM   #23
choprods
Alliance Vendor
choprods's Avatar
As it is cheap and lightweight and available most all places-It was always used in some early Kustoms as a form of fabricating shaped bodys -panels,wheel well flares etc- back in the day.......It was never intended as all out structural tubeing,we all know that,.....
Its great for understructure ,for body bracing,fender supports etc-,but used as any sheetmetal/structural member in itself the welds can easily be corrupted by poor removal of that Galv' coat, so be careful in that reguard as well as the health hazard discussed....
__________________
Old 03-16-2013, 12:59 PM   #24
bobss396
Old School HAMBer
bobss396's Avatar
Plus EMT has a very thin wall, easy to bend on electrical installation sites. I sure wouldn't use it on a car.
I saw some dipshits years back weld a fuel cell guard on the rear frame of a stock car made from EMT tube.
Bob
__________________
Old 03-16-2013, 01:06 PM   #25
Snot Rocket
Grenade Inspector
Snot Rocket's Avatar
If you aren't in a hurry to remove the zinc, dip it in Diesel fuel. After a couple of months, the zinc/diesel will be a gooey mess and the steel will be clean. No fumes.
__________________
Run it, wreck it, don't never check it.
Old 03-16-2013, 06:00 PM   #26
swade41
Old School HAMBer
swade41's Avatar
I know quite a few race cars that use it for tilt front under body bracing. You bond it in with mat and resin so the coating makes sense because it will not rust. I'm not standing the car on it's hood, it just has to hold it in place.
__________________
Gasser Gang of WNY
Old 03-16-2013, 06:22 PM   #27
chopolds
Old School HAMBer
chopolds's Avatar
Jim ain't building a hotrod, he's building a Kustom. I use it a lot to brace stuff, frame out grills, tail lights, etc. Starbird also uses it to frame out his custom bodied bubble top cars. he tried to buy it from the manufacturer, un-galvanized, but they refused.
Also works well as a quick form to hammer metal over.
__________________
Finished The Kart
Proud Member: Gold Chainers CC
Old 03-16-2013, 11:59 PM   #28
nali
nali's Avatar
Many paint don t hold very well on galvanized parts IIRC.
Use at least epoxy or a good etching primer.
Old 03-17-2013, 12:12 AM   #29
go-twichy
Quote:
dragster frame?
Old 03-17-2013, 09:12 AM   #30
chopolds
Old School HAMBer
chopolds's Avatar
This is an old thread.....I'm sure Jim was looking for an easy way to frame/support the radical body changes on his "Telstar" project. And conduit is a good way to do this, quick and easy compared to other methods.
__________________
Finished The Kart
Old 03-17-2013, 09:25 AM   #31
pastlane
Senior Member
pastlane's Avatar
Only two ways to do it. Sandblast or chemically strip it. Grinders or course sanders/wire wheels will clear off some of the coating but will also embed it deeper into the base.
Done right conduit can be used to build a tilt front end structure but I'd have to agree by the time it's all said & done, buying thin wall steel tubing is the best way to go.
__________________
"Your mind is like a parachute, it only works when it is opened" ~Frank Zappa
Old 03-17-2013, 09:26 AM   #32
choprods
Alliance Vendor
choprods's Avatar
Chopolds, we are surrounded by folks who know it all without ever having done anything......
A look back thru about any of the old books will show you conduit was used on a lot of early customs as substructure.
we all know its not used to build a frame ,for Gods sake,it wasn't even hinting at that.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
