Reply
Thread Tools Display Modes
Old 09-25-2011, 03:29 PM   #1
Fordor Ron
Senior Member
Fordor Ron's Avatar
Default 1932 Ford rain gutters... How do you remove them?
I need to rework the rain gutters on my 32 Fordor. I found some 5 window re pops which should give me the piece I need as I am only replacing the front curve area.
How do you remove the factory drip rails so I can splice the new section in?
Thanks in advance...
__________________
Gee... I... wonder where the mama bear is???
offline   Reply With Quote
Old 09-25-2011, 04:46 PM   #2
3blapcam
Grenade Inspector
3blapcam's Avatar
Default Re: 1932 Ford rain gutters... How do you remove them?
I was looking at the drip rails on my coupe and they look spot welded on... So I think that's your answer. They have cheapies at Horrible Freight...
http://www.harborfreight.com/catalog...ot+weld+cutter
Buy 2, go slow & have fun!
3blap.
__________________
I ain't nobody... dork!
Old 09-25-2011, 05:08 PM   #3
JeffreyJames
Old School HAMBer
JeffreyJames's Avatar
They are spot welded on and I think they are ever 3.5" so if you find one you should be able to measure that to the next one to find them. I just took my driver's side off the other day and I drilled a few out and I also slid a very skinny cut off wheel in between to get others off.
I would wire wheel the drip rail first so you can pin point them and then drill them out with a rotobrotche which is like a spotweld hole saw. Good luck!
__________________
I PLAY WITH TIGERS
WWW.SUGARCITYSPEEDSHOP.COM
Old 09-25-2011, 07:06 PM   #4
Fordor Ron
Senior Member
Fordor Ron's Avatar
Yeah... That's what I was thinking although because it's at the front curve I wasn't sure.
I'm gonna buy a spot weld cutter too...
__________________
Old 09-25-2011, 07:38 PM   #5
oldrodkid
oldrodkid's Avatar
If youíre not trying to save the piece your cutting off...and you canít see exactly where the spot welds are to drill, Hereís another way to do it...
Using a cut off wheel or small grinding wheel... carefully and slowly grind away the drip rail in the area where it's spot welded and stop just as youíre grinding through it, before you get into the metal on the roof...
I know everyone says you need a spot weld cutter, but this way has worked well for me... but like I said, carefully and slowly...you can get them off with out grinding/messing up the roof.
Old 09-25-2011, 07:41 PM   #6
3blapcam
Grenade Inspector
3blapcam's Avatar
The rotobroche(sp?)/Blair would be better because you can use smaller cutters than the default 3/8" cutter that I posted. The spot welds looked kinda small at first glance...
3blap.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
