Reply
Thread Tools Display Modes
Old 09-08-2011, 11:00 PM   #1
Scotch Buzzard King
Senior Member
Scotch Buzzard King's Avatar
Default Twin Engine Coupling (How Do You Get Two V8's In-Line?)
I know one of you's is building a twin engine inline V8 dragster or hot rod. My question is how did you connect up the motors? How did the old guys connect up the motors? Any pictures? Any build pictures?
__________________
"This is no dress rehearsal, we are professionals, & this is the big time."--Waylon Jennings
offline   Reply With Quote
Old 09-08-2011, 11:51 PM   #2
48fordor
Grenade Inspector
Default Re: Twin Engine Coupling (How Do You Get Two V8's In-Line?)
Quote:
For two in line, I'm told by someone who ran one in the '60s (two injected flatheads) that he used two large gears of the same size. One at the back of the crank on the front engine, and one at the front of the crank on the rear engine. He brought them together and wrapped it with double roller chain just long enough to go around. This secured the two gears together face to face and linked the cranks together.
Edit:
Ha! I think the owner is here on the hamb, here is his page:
http://www.norbsplace.com/page3.html
with the info. I traded some email with him a few years back.
Goes to show you everything is already here on the hamb.
online   Reply With Quote
Old 09-08-2011, 11:53 PM   #3
titus
Old School HAMBer
titus's Avatar
Double row chain and a couple of sprockets is one way, ive collected up the stuff to do it with for a "future" project.
jeff
__________________
who owns this car with the peace sign, mag wheels, and four on the floor?
Old 09-09-2011, 04:02 AM   #4
Deuces
Old School HAMBer
I think the # 1 cylinders on both motors would fire @ 45 degrees apart..... Or something like that...
Old 09-09-2011, 04:53 AM   #5
STURGIS39
STURGIS39's Avatar
Alignment is the most important thing. The engine mounts need to be adjustable and allow the engines to be move sideways and up and down. Shims and feeler gauges will be required and a lot of time and patience. There are all types of couplers for motors and pumps. McMaster Carr is a good source for couplers.
I have used a rubber hose and hose clamps on some small applications.
When we were kids, some of the toys used ball point pen ink tubes.
__________________
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, DUCT TAPE OR JB WELD , IT CAN NOT BE FIXED
Old 09-09-2011, 04:57 AM   #6
DocWatson
Old School HAMBer
DocWatson's Avatar
Cattle dogs...........
__________________
There’s a meaning there, but the meaning there doesn’t really mean a thing.
Old 09-09-2011, 08:52 AM   #7
296moon
Grenade Inspector
296moon's Avatar
I am building an inline twin, at first I was going to go with the two sprockets and double chain route but when looking for the box to rearend coupler I found that I could get male and female blank rings, these are as I write this, being fitted to flanges that will bolt crank to crank so the front engine will slide in, it will now be far easier to take apart and timeing between the two can be ajusted by ether the moveing the coupler round a tooth (18 degrees per tooth) or if it needs more we can offset drill the flanges, heres a pic of the rear coupler, Ill post a pic of the middle one when I get it back from my machinest frend trevor,
Old 09-09-2011, 09:21 AM   #8
hotroddub
hotroddub's Avatar
Like this?
Old 09-09-2011, 10:20 AM   #9
haroldd1963
Alliance Member
haroldd1963's Avatar
This should be an interesting thread...keep the pictures and ideas coming!
Old 09-09-2011, 10:57 AM   #10
Scotch Buzzard King
Senior Member
Quote:
Originally Posted by hotroddub View Post
Like this?
What kind of adapter is that? Looks like a couple of transmission bearing collars. This link was posted on another thread: http://www.dodge-pt.com/pdf/brochure...nts/BR4000.pdf Does this coupler look like a better fit?
__________________
Old 09-09-2011, 11:02 AM   #11
enjenjo
Senior Member
The engines do not need to be timed together.
__________________
You can't be part of the elite unless you have someone to look down on.
Old 09-09-2011, 11:02 AM   #12
john walker
Alliance Member
john walker's Avatar
a lot of stress on a damper and single key. what is beefed up in order to keep it together?
__________________
www.johnwalkersworkshop.com
206 789 6800
7613 greenwood ave n
seattle, wa, 98103
Old 09-09-2011, 11:06 AM   #13
Deuces
Old School HAMBer
Quote:
As stated above... They are timed to fire @ 45 degrees from each other on the # 1 cylinders...
Old 09-09-2011, 11:19 AM   #14
enjenjo
Senior Member
Quote:
It's not necessary. It will run just as well at 5 degrees, or 40 degrees. It may sound different, but the output is the same. The engines do not have to be the same size, or the same make, or the same number of cylinders.
__________________
Old 09-09-2011, 11:40 AM   #15
dreracecar
Senior Member
dreracecar's Avatar
Ivo's "SHOWBOAT"
Old 09-09-2011, 12:20 PM   #16
Scotch Buzzard King
Senior Member
Now I'm confused...
__________________
Old 09-09-2011, 12:28 PM   #17
296moon
Grenade Inspector
296moon's Avatar
There would be alot of stress if my engines were blown but sadly their not, so we have just hardend the key, we can add more keys or bolts if anything shears but should be ok with mine, I wanted the engines as close a possible so we are useing these couplers from mark williams,
Old 09-09-2011, 12:29 PM   #18
Blind Elwood
Grenade Inspector
Blind Elwood's Avatar
45* is not really the best.It's hard on cranks and bearings. I always recommend going with 10*. What your looking for is 8 long burns instead of 16 short ones. It's really all about the harmonics between both engines. Look up Toymakers thread he set his engines up @ 10* check his video of his engines running.
Blind Elwood
Old 09-09-2011, 12:32 PM   #19
296moon
Grenade Inspector
296moon's Avatar
Quote:
Blind Elwood
Yes your right, but I want to try 90 off as well
Old 09-09-2011, 12:41 PM   #20
Scotch Buzzard King
Senior Member
Actually 296moon, you're coupler idea is a pretty good one. You say that Mark Williams makes those? Does he have a website?
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
