Reply
Thread Tools Display Modes
Old 08-30-2011, 10:16 AM   #1
Hellfish
Old School HAMBer
Hellfish's Avatar
Default Bending 1/8 or 11ga steel
I need to bend some into a 3.5 x 4" hat channel. I don't have a brake. Can this be done in a hammer form, or a homemade brake, or is it too thick?
offline   Reply With Quote
Old 08-30-2011, 10:24 AM   #2
Jim Stabe
Grenade Inspector
Jim Stabe's Avatar
Default Re: Bending 1/8 or 11ga steel
If you have a press you could make something like this
Click image for larger version
Name:	Bending angles.jpg
__________________
MGB widened 11". C4 Vette running gear, LT1 with 6 sp. http://forum.britishv8.org/read.php?13,7581
Old 08-30-2011, 10:33 AM   #3
The Internet
Grenade Inspector
The Internet's Avatar
Hat channel would be difficult to form with a press.
I have done 1/8" with a hammer and torch. Depending on the aplication, you may not want to change the metal with the heat.
__________________
Please check out my build thread! http://www.jalopyjournal.com/forum/s...d.php?t=578775
Old 08-30-2011, 10:39 AM   #4
Jmountainjr
Alliance Member
How long is the section you need to bend? If fairly short, I bend small 11ga items all the time with a 24" adjustable wrench in the vice.
__________________
Jim
Old 08-30-2011, 10:44 AM   #5
R Frederick
Old School HAMBer
R Frederick's Avatar
If it's very long, I've scored it with a thin cutoff wheel and stitch welded after it was bent. As I did for my floor pans that I accidently ordered 16ga. instead of 18.
online   Reply With Quote
Old 08-30-2011, 10:50 AM   #6
silent rick
Alliance Member
doesn't kevin have anything at the shop that will handle that?
__________________
selfish disgusting anti-social bad influence friend of the devil seeks an intelligent young hard belly with large breasts to dance naked for my amusement.
must ride on fender.
Old 08-30-2011, 10:59 AM   #7
Hellfish
Old School HAMBer
Hellfish's Avatar
I need to bend up 2 sections that are about 14" long, 4" tall, and 3.5 wide. I'm replacing a section of unibody frame. It was a little thinner from the factory, but I have a sheet of 1/8 (maybe 11 or 12ga?) already. A little thicker is better in this case since the springs attach to it. I could just get some box tubing, but like I said, I already have a sheet in the gauge I need...
Old 08-30-2011, 11:00 AM   #8
scottb356
Grenade Inspector
scottb356's Avatar
bench vise, mapp gas, adjustable wrench, bfh. Done
__________________
http://www.kahikocustoms.com/
Old 08-30-2011, 11:22 AM   #9
Roger Walling
Senior Member
Roger Walling's Avatar
1/8" is thick enough to mig. very easly. Cut strips and weld and grind.
or use 4" square tubing and weld a flat stock onto it.
Old 08-30-2011, 11:48 AM   #10
Alliance Member
Mr48chev's Avatar
A friend who works in a local welding fabricating shop with a big brake always comes in handy at times like this.
Otherwise I'd take JIm Stabe's idea and run with it.
__________________
Happiness is having a garage big enough to hold all ttools and projects and small enough to keep warm enough to work in the winter.
Old 08-30-2011, 09:47 PM   #11
50dodge4x4
Old School HAMBer
Clamp it to a steel bench, heat it up and bend it with a hammer. if you heat the flat stock, you don't have to hit it very hard to bend it to a 90 degree bend. Won't look pretty but will do the job. If you have some heavy angle a a good vice, you can clamp the flat stock between two pieces of angle in the vice, heat and bend, finish with tapping the bend flat against the angle. Makes a prettier bend but takes a little longer. Don't forget to bend the flanges to weld to the floor pan as well. Gene
Old 08-30-2011, 10:05 PM   #12
budd
Old School HAMBer
budd's Avatar
what is the thickness of metal your replacing? if you go thicker then its a good chance it will crack along the joint, the thinner metal will have more flex then the thicker, also if i follow you a brake would require a goose neck punch, not something everyone has.
Old 08-31-2011, 09:50 AM   #13
73RR
Old School HAMBer
73RR's Avatar
You may be better off buying a small length of light wall tubing:
http://www.metalsdepot.com/products/...mAcc=%24LimAcc
__________________
www.qualityengineeredcomponents.com
Early Hemi Parts, Pieces, Tech
Trans adapters for EarlyHEMI, Flat 6&8 and pre-62 A series
http://www.discoverthenetworks.org/Articles/Hansen.pdf
Old 08-31-2011, 10:32 AM   #14
jimvette59
jimvette59's Avatar
Use box tubing, cut it and weld it back to the shape you need. I know you have the plate but it may be better to use box tubing or cut the plate in strips and weld it together. Just my way of thinking ???
Old 08-31-2011, 11:41 AM   #15
realkustom51
realkustom51's Avatar
You can also make a "Window Punch". A punch that can disassemble to get the part out. In fact you can form up square tubing in a window punch.
Keep in mind that you may have to over bend about 4 to 12 degrees so that you part relaxes to 90 degrees.(springback).
Bear with me, I had to draw these driving down the road when I read the thread.
Old 08-31-2011, 11:49 AM   #16
117harv
Alliance Member
117harv's Avatar
You are replacing a factory piece, if you bend it in a brake or press the bends will be rounded and not sharp like the origonal being thicker steel. I would do like another poster suggested and score it with a cut-off wheel, bend and weld. The inner weld will be hidden and the outer is easily ground and detailed. Doing it this way will keep the bends crisp. Clamp a piece of tubing inside as you weld to help keep it's shape.
__________________
Posted via vintage Dixie cup and kite string.
A hot rod with too much modern spice, loses it's traditional flavor.
Old 08-31-2011, 12:13 PM   #17
R Frederick
Old School HAMBer
Quote:
Thank You. You can re-score it as you go if it doesn't bend far enough to widen the gap again. Because the gap will pinch as you fold it together. It leaves a nice crisp edge on the outside. I've even folded on a curved score.
Old 08-31-2011, 03:52 PM   #18
117harv
Alliance Member
117harv's Avatar
Yes you can do it that way, but i usually score it and open it up not pinch it, and then weld back in what you ground out.
__________________
Old 08-31-2011, 03:59 PM   #19
R Frederick
Old School HAMBer
I'll do it that way too, (when I screw up and score the wrong side from the pattern) lol.
Old 08-31-2011, 04:15 PM   #20
realkustom51
A real sharp radius will dictate how the part is formed. A press brake or leaf brake is out of the question if the radius needs to measure smaller than the material thickness. A typical industry standard is V x .155 = IR , (Vee Die Size times .155 equals the Inside Radius.
example.
11GA (.120) times 8 gives me the VEE DIE Opening (V=8t) which is .960 so rounded that of to 1" VEE DIE Opening.
Now take 1.000 and multiply it by .155 (5/32) and then you get the ball park inside radius needed to form the part. By the way, that equals .155 and the official chart says .156 (ballpark).
Just for kicks. I install and repair Accurpress Press Brakes and here is a back yard size 30" model. Uses standard american style tooling and is considered a 11GA press. (10 Ton Capacity=4 tons per ft). Just thought Id show it off since the subject was 11GA.(.120)
Also here is a Bend Allowance Chart you can print out. Helps you cut the unbent blank the right size so it bends correctly.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
