Reply
Thread Tools Display Modes
Old 08-15-2011, 01:09 AM   #1
metricmania
FNG
Default Best stock SBC head?
OK, for my class of racing, I have to use stock, unported heads. I can change valve size. I can't use Vortec heads, but can use any thing else. Right now, I have camel hump heads. I find that they can rev up to about 6000 RPM and after that, they start to fall flat though RPM does still increase, just not as much as 3000-6000.
My engine is a 355. Stock intake and exhaust.
What could I expect if I put some 305 heads on there with big valves? I can do machine work 1/2" above the intake seat, not sure if that would help with making a 305 head work or not.
I heard 305 heads fall flat after 4000 RPM is that true? What about if they have bigger valves? The reason I'm considering 305 heads is for more compression. I heard the 601 casting is a good head, and it would bump my compression up by 1 full point. But it won't help unless they rev up to 6000 RPM (I'm hitting 6500 RPM at the end of the straight).
offline   Reply With Quote
Old 08-15-2011, 01:45 AM   #2
JeffB2
Old School HAMBer
JeffB2's Avatar
Default Re: Best stock SBC head?
It could be your valve springs and lifters causing your problem,in your class it is common to use "cheater" valve springs like these: http://cgi.ebay.com/ebaymotors/SBC-C...#ht_3510wt_951 they are stock diameter and you will be able to use the stock retainers and look "stock" if you are using a hydraulic cam OEM type lifter they will "float" at the RPM you are running,solution is swap to the Rhoads RHL-8178 lifters these are anti-pump-up and have a little extra advantage below 3500 RPM they increase torque which will pull you off the corners faster.Do not swap to the 305 head to use the larger valves it requires "bowl hogging" to unshroud the valves to do this is a waste of money for the gains you might get from it and some 305 heads being a thinner casting are prone to cracking.
Old 08-15-2011, 02:02 AM   #3
slammed
Old School HAMBer
slammed's Avatar
Is Extrune honing legal? Tappered valve stems? Sodium filled valve's? Roller rocker or tipped ones?
__________________
In 1950, 80% of all men in the United States had jobs. Today, 65% of all men in the US have jobs.
Old 08-15-2011, 05:33 AM   #4
big duece
Old School HAMBer
big duece's Avatar
1960-63 "461X" castings have a larger than normal intake runner
__________________
You can't polish a turd, but you can roll it in glitter!
Old 08-15-2011, 10:15 AM   #5
Homespun91
Old School HAMBer
Homespun91's Avatar
The old school solution to those class rules was, as big duece noted, 461X heads; their intake runner volume is 10cc + larger than the 461 (no "X") heads. They are relatively hard to find, but still out there.
The first place I would start is to use 2.02 or 2.05 valves on the intake, and 1.6 on the exhaust, if you aren't already. These won't have much effect unless you have the port throat opened up to roughly 90-95% of the actual seat diameter; fortunately you can work with that 1/2".
If you are allowed to modify the chamber, by all means have the chamber "swept" with a side mill around the intake valve. Though you will slightly increase the chamber size, you'll get greater benefits by unshrouding the intake valve. If you are running 4 valve relief pistons, get rid of them and use 2 relief pistons; you'll compensate for the sweep and you'll increase your compression even more as a result.
If permitted, I would use reduced diameter ("necked down") stems, or even go to a smaller diameter stem & guide. If allowed, have the bowl end of the guides shortened so they don't protrude from the guide boss- though be aware that you may get much shorter guide life as a result. Set the guide clearance as tight as you can reasonably get it to help this.
I agree with Jeff about the 305 heads...
If they don't have to be "production heads"...just "Chevy heads"...you can switch to Bow Tie heads or even the old 292 "Turbo" heads and pick up some gains, though for a claimer engine it may not be cost effective.
Lastly...if you're sneaky as Dick Cheney...peruse this: http://www.castheads.com/
And yes...they are that good.
__________________
Against stupidity, the gods themselves contend in vain. - Schiller
Life's a bitch. If it was easy, it would be a slut.
Old 08-15-2011, 12:28 PM   #6
David Chandler
If things are falling flat at whatever rpm, perhaps you should consider switching cams to find one that better suits the rpm range that you are trying to run in? The same thing applies to everything else too. Manafold design, carb sizing, exhaust restrictions, etc. If you are stuck using stock heads then you are probably limited on what intake you should use too. The cast iron Z28 style is suposed to be as good as it gets for a "limited" engine.
Old 08-15-2011, 12:41 PM   #7
Pro Stock John
Old School HAMBer
Pro Stock John's Avatar
Post up what valve springs you are running, maybe your springs at done at 6k. Then again, post the cam too.
Old 08-15-2011, 01:47 PM   #8
porknbeaner
Alliance Member
porknbeaner's Avatar
Quote:
I was actually thinking that I may not be the heads that are done @ 6K it could be the engine.
__________________
If it don't make ya dirty it ain't yours
No man crosses a chasm in two jumps
online   Reply With Quote
Old 08-15-2011, 01:57 PM   #9
lippy
Old School HAMBer
lippy's Avatar
Quote:
Exactly, we know nothing about this deal. Lippy
Old 08-15-2011, 02:08 PM   #10
Homespun91
Old School HAMBer
Homespun91's Avatar
He says that it will turn 6500 at the end of the straights, and that it will still rev at 6000, just not as easily. If he was having serious spring issues, i.e. spring harmonics or valve bounce, it probably wouldn't be capable of turning 6500...or at least not very many times.
Factory SBC heads have fairly weak intake port flow and this is a fairly common symptom. A different cam might help, depending on what he has now...but then again it might not.
I'd like to see more details of the cam, intake manifold, and exhaust system...if he cares to share...he asked specifically about cylinder heads.
__________________
Old 08-15-2011, 02:51 PM   #11
narlee
Grenade Inspector
narlee's Avatar
There are other heads that will flow but those heads will run well over 6 grand. Carb, intake, cam, etc as posted earlier would be a big help. If you don't have the components to support bigger valves they won't help.
Old 08-15-2011, 05:53 PM   #12
Pro Stock John
Old School HAMBer
I've run OT LS1 engines to 7200 with a hydraulic cam, and we ran spring pressures that traditional SBC guys said were too much. I'd be curious to hear the spring package, there are lot of really good springs out there.
Old 08-15-2011, 06:03 PM   #13
derbydad276
Senior Member
derbydad276's Avatar
my vote would be
1970-73 LT-1, Z-28 and ANGLE PLUG CYLINDER HEADS
(Chevy Part No. 3965742)
if I remember correctly they used the same head on the 302 engine that would rev forever
Old 08-15-2011, 06:48 PM   #14
Deuces
Old School HAMBer
I like the "492" and "292" angle plug heads...
__________________
***** God Bless the U.S. *****
Old 08-15-2011, 06:56 PM   #15
plymouth1952
Senior Member
plymouth1952's Avatar
I like the 39711 heads good for uper RPM
Old 08-15-2011, 07:20 PM   #16
brandon
Old School HAMBer
brandon's Avatar
Quote:
turbo heads....old school over the counter race castings. big thing about finding a stock casting ....old heads are out there , finding a pair of virgin castings might be possible , and probably costly.....used castings are probably on the 4th or 5th life cycle by now.....a pair of 186 or 041's might be another vintage possiblitly
how much work would be involved in trying to use a set of steel late model lt1's.... supposed to be where the vortec evolved from.
Old 08-15-2011, 07:26 PM   #17
Dyce
Senior Member
Dyce's Avatar
We had a class limited to 360ci and stock heads with no porting. They would allow larger valves and milling. We ran 2.02-1.6 valves, I unshrouded the chambers like Homespun91 explained, and anglemilled the heads .125 to get the chamber volume down. The angle mill also tips the intake runner a little in the right direction for better flow. I'll take 12 to 1 with a flattop over 13 to 1 with a dome any day!! Lightweight 2 valve releif pistons are a must both for durability, and the lightweight helps the engine rev quicker on starts and comming out of the turns.
Maybe I missed it, but what are you running for a carb?
Old 08-15-2011, 07:45 PM   #18
DaddyO's..Deuce
Alliance Member
DaddyO's..Deuce's Avatar
Default
186 camel humps came on the DZ 302's and have the advantage of accessory bolt holes in the end if you need them. There were some different varieties of 186's though so watch for them. Some had screw in studs, & 2.02's while others had press in studs and 194's. Later
__________________
$ Forgivness is always easier than permission $
Old 08-15-2011, 08:42 PM   #19
ANDEREGG TRIBUTE
Senior Member
ANDEREGG TRIBUTE's Avatar
I swiped this from his other thread.....
"I have the following:
462 camel hump heads
355 C.I. small block chevy
flat top pistons, 10:1 compresion ratio
camshaft: 106 degree LSA, 250 degree duration at .050"
165-180 cranking PSI in all cylinders.
Quadrajet, stock intake, exhaust and heads, no porting (it is on a circle track street stock and those are the rules)."
This is just my .02 from 20 years of turning left on dirt..... I have won in hobby stocks with smog heads, I have won with 305 heads. Have never used double humps. The 305 heads were awesome (casting 14014416) and Z28 springs (no port work, stock valves) with a 355 flat top solid or hyd cam. Solid cam was a pretty big cam (Speedway Motors' 2 barrel grind) with QJ and open tube headers...would turn 6800 rpms all day. Hyd cam was was Lunati Voodoo and also would pull 6800 rpms with no probs, but was more a torque cam and was run with a holley 500 and stock log manifolds and flowmaster mufflers. The lunati had a ton more lift and duration on the exhaust side. I always ran 38 degress total advance autolite 26 and HEI. Its racing remember...good cooling is a must, free flowing exhaust and plenty of maintenance and attention to detail. Make sure your ignition system (that means every part of it) is in perfect working order. Have your carb guy tell you how to tune the secondary butterflies and the importance of your secondary metering rods and hangers.....ask him he will know...at least he better. I dont think your heads are your problem, I think its a tuning or valve train issue.
__________________
HAMB-ON!!
Looking for info/pics of the Anderegg Roadster. http://www.jalopyjournal.com/forum/s...d.php?t=415187
Old 08-15-2011, 08:45 PM   #20
ANDEREGG TRIBUTE
Senior Member
oh and remember to check this site.....http://www.thedirtforum.com/
__________________
HAMB-ON!!
Old 08-15-2011, 08:58 PM   #21
spooledup
FNG
882 &993 Heads have as good flow as the 292 heads
but the chambers are not good at 76cc's. If angle milling is legal
that would get your compression back up to where it would be with
With the 64cc's of the double humps. They are cheap, plentiful,
and some had 2.02, 1.6 valves. Most had 1.94, 1.5.
__________________
If it dont fit...force it.... If it breaks, it needed to be replaced anyway.
Old 08-15-2011, 08:59 PM   #22
bryan6902
Senior Member
bryan6902's Avatar
Anderegg just said everything I couldn't remember from racing circle track, 305, bombers. Sounds exactly like our set-up. Stock bore, 305, factory heads, HEI, tweaked-out 2-Jet, same timing, stock manifolds, no mufflers, .420 lift cam.... Would turn 6500-6800 RPM at the end of the straights, no problem. One engine I built lasted nearly 5 seasons and it only broke after a hard hit.
__________________
Check out my 57 Pontiac build!
http://www.jalopyjournal.com/forum/s...d.php?t=332564
Old 08-15-2011, 09:09 PM   #23
man-a-fre
Senior Member
man-a-fre's Avatar
[Heres your answer.
QUOTE=Deuces;6859032]I like the "492" and "292" angle plug heads...[/QUOTE]
Old 08-15-2011, 09:17 PM   #24
lippy
Old School HAMBer
lippy's Avatar
Stock bore? A 355? LOL. You already bumped the comp when you bored it ,030. Lippy
Old 08-29-2011, 01:22 AM   #25
metricmania
FNG
Sorry guys, I wasn't keeping up with this post.
Cam is: Howards 110812
Basic Operating RPM Range2,500-6,500
Intake Duration at 050 inch Lift248
Exhaust Duration at 050 inch Lift252
Duration at 050 inch Lift248 int./252 exh.
Advertised Intake Duration286
Advertised Exhaust Duration294
Advertised Duration286 int./294 exh
I've used a few carburetors from different builders-car acts exactly the same. HEI ignition with pertronix flame thrower coil and module. 36 degrees total timing.
Valve springs are: Isky 8205, seat pressure is 160 lbs and it's close to 390 on the nose. My machinist picked out these springs and I didn't reealize I was running that much spring pressure.
Pushrods are supposed to be good up to 500 lbs.
screw in studs and guideplates. stock stamped rockers.
Well, right now, I have my motor half apart because I was told by numerous people, I'm running way too much cam for my car. I'm going to put Comp # 12-646-5 in there now with matching valve springs.
Valves are 1.94/1.60
Old 08-29-2011, 01:58 AM   #26
Deuces
Old School HAMBer
Thumbs up Re: Best stock SBC head?
Quote:
Originally Posted by man-a-fre View Post
[Heres your answer.
[/QUOTE]
Thanks Man!!
__________________
Old 08-29-2011, 07:59 AM   #27
Deuces
Old School HAMBer
How about the early cast aluminum "recall" heads from the early '60's... Those were recalled because of porosity issues...
__________________
Old 08-29-2011, 08:04 AM   #28
HEATHEN
Old School HAMBer
All right if you really luck into a set, but the only ones I've ever seen came with an asking price in the $2500 range.
Old 08-29-2011, 08:24 AM   #29
Deuces
Old School HAMBer
.....Yikes!!
Does anyone have pictures of those??? I think I read an article once that people were bolting those on the 283/315 hp fuelie Vettes back in the day... Or, they were a factory installed option..
__________________
Old 08-29-2011, 08:37 AM   #30
Larry T
Old School HAMBer
Larry T's Avatar
Quote:
Originally Posted by derbydad276 View Post
my vote would be
LT-1's came from the factory with straight plug heads. The angle plug 492's were over the counter heads only.
292's were over the counter heads too.
If these are legal, the "bow-tie" head will be too, and would be a better head.
But all this depends on if the spec is "stock production head" or "OEM casting numbers".
Larry T
BTW, all production 2.02 heads had the chambers milled around the valve as suggested above. The smaller valve "camel hump" heads didn't.
__________________
Goldchainers CC
Old 08-30-2011, 08:55 AM   #31
HEATHEN
Old School HAMBer
.....Yikes!!
They were installed on the assembly line, but so many of them had coolant leakage problems that they recalled them very early in the model year and switched to cast iron. Given that fact, I certainly wouldn't pay the price for them just to try to use them in a non-stock application. The same money will buy you lots better performance elsewhere.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
