Go Back   THE H.A.M.B. > The H.A.M.B. Marketplace > The H.A.M.B. O'Dex
Reply
Thread Tools Display Modes
Old 08-12-2011, 03:46 PM   #1
Tugmaster
Alliance Member
Tugmaster's Avatar
Default Milltown Auto Wire
My original add got deleted so I am reposting it. My name is Todd. I am your friendly neighborhood Rebel wiring harness dealer. I strive to offer the best service possible. I offer a 10% discount to all HAMB memebers.
Please feel free to contact me 860 214 6974 Nights and weekends. I accept paypal, major credit cards and money orders. THANK YOU!!
Rebel Wire 8 Circuit Wiring Harness $135.95
Rebel Wire harnesses are all assembled in America from American made components. The 8 circuit wiring harnesses is perfect for Hot Rod, Rat Rod, T-Buckets, or Custom applications that require only basic circuits.
Assembled with heavy duty SXL wire labeled every 6" and bundled for easy
installation. This kit has 8 circuits for lights, gauges, radio, motor and third brake light. Kit comes with easy to use instructions for Chevy, Ford or Mopar installations, dash light wire, neutral safety switch wire, fusible link, 1 1/4" rubber grommet for the firewall, and fuse block label.
__________________________________________________ ____________
Rebel Wire 9 + 3 Circuit Wiring Harness $153.00
The Rebel Wire 9 + 3 circuit wiring harness is perfect for your hot rod, street rod,custom or muscle car applications that require fewer circuits. Assembled in American from American made components, the heavy duty SXL wire is labeled every 6" and bundled for easy installation. This kit has 9 circuits for lights, gauges, radio, heater, motor, and third brake light, plus 3 open circuits for whatever you might want to add such as power windows and doors, electric fan, etc. Kit comes with easy to use instructions for Chevy, Ford or Mopar installations, dash light wire, neutral safety switch wire, fusible link, 1 1/4" rubber grommet for the firewall, 3 fuse block terminals and fuse block label.
Rebel Wire 14 Circuit Wiring Harness $175.00
The REBEL WIRE 14 Circuit wiring harness gives you a great mid-range kit at an affordable price. Kit has circuits for lights, gauges, radio, ac-heat, wipers, turn signals, hazard 4-way, horn, power windows, electric fan,cell phone charger. Assembled with heavy duty SXL wire and labeled every 6" and bundled for easy installation.
Rebel Wire 20 Circuit Wiring Harness $219.95
This Rebel Wire 20 Circuit for lights, gauges, radio, heater, motor, and third brake light, Power Doors, Power Windows, Power Seats, Cruise and Electric Fan Relay Control wire. Assembled with heavy duty SXL wire labeled every 6" and bundled for easy installation. Comes with Fusible link, 1 1/4 Rubber grommet for firewall. Instructions and Fuse Label.
ELECTRIC FAN RELAY$27.95
30-40 AMP RELAY, 30 AMP CIRCUIT BREAKER, 6 FOOT 12 GAUGE BATTERY POWER, 6 FOOT 12 GAUGE FAN POWER, 6FT 18 GAUGE SENDER SWITCH, 6 FT. 18 GAUGE IGNITION SWITCH.
ELECTRIC FAN RELAY KIT WITH SWITCH 180 DEGREES $39.95
30-40 AMP RELAY, 30 AMP CIRCUIT BREAKER, 6 FOOT 12 GAUGE BATTERY POWER, 6 FOOT 12 GAUGE FAN POWER, 6FT 18 GAUGE SENDER SWITCH, 6 FT. 18 GAUGE IGNITION SWITCH. INCLUDES 180 DEGREES SWITCH
ELECTRIC FAN RELAY KIT WITH 200 DEGREE SWITCH $39.95
30-40 AMP RELAY, 30 AMP CIRCUIT BREAKER, 6 FOOT 12 GAUGE BATTERY POWER, 6 FOOT 12 GAUGE FAN POWER, 6FT 18 GAUGE SENDER SWITCH, 6 FT. 18 GAUGE IGNITION SWITCH. INCLUDES 200 DEGREE SWITCH
HEADLIGHT RELAY KIT $37.95
Headlight Relay Kit
2 - 30-40 Relays, 6' 12 ga. fused Battery Power, 3' 14 ga. Ground Wire.
Kit can be added to existing wiring or incorporated into new wiring
REBEL WIRE GAUGE HARNESS$39.95
Universal gauge harness includes terminals for blade or stud mount
connections, connector and terminals for electronic speedometer connection and complete instructions.
700R4 & 2004R LOCK UP KIT $59.95
This kit allows the use of a lockup style torque converter without the use of a computer. For 700R4 and 2004R automatic transmissions
Other kits and accessories available, just drop me a line!!
__________________
HAMB dealer for Rebel wiring products. 10%discount to all HAMB members
http://www.jalopyjournal.com/forum/s...d.php?t=614260
__________________
online   Reply With Quote
Old 08-23-2011, 09:00 PM   #2
ryno
Old School HAMBer
ryno's Avatar
Default Re: Milltown Auto Wire
dealt with tugmaster on a few projects, fast service, quick response on communications, and a GREAT product. what else can you ask for?
order with confidence.
offline   Reply With Quote
Old 08-26-2011, 12:14 PM   #3
100% Matt
Senior Member
100% Matt's Avatar
Need wiring??? Todd and Rebel Wire will hook you up. WE use Todd and Reble Wire for all our projects
__________________
the Others!
Hot Rod Fall Out VIII
Oct 12' 2013
South Glastonbury, CT
www.hotrodfallout.com
Old 09-06-2011, 04:08 PM   #4
Bobert
Alliance Member
Bobert's Avatar
Just finished my first wiring job using the 14 circuit kit. Easy to follow instructions and really great support for when I tried to over think the installation.
__________________
"It's always something." Roseanne Roseannadanna
Old 09-30-2011, 11:32 PM   #5
Concrete B
Grenade Inspector
After discussing my application with Todd I decided on the 20 circuit harness for my 63 Coupe DeVille. I ordered and received within a week, and everything looks excellent. Todd was great to work with and a great online seller. I can't wait to rid myself of the factory spaghetti that is under my dash...
Old 11-09-2011, 08:21 AM   #6
American Metrics
Newbie
American Metrics's Avatar
I just got my new 9+3 kit yesterday. It took less than a week to arrive at my door. Todd was great to work with. I installed one of these in my hot rod a year ago and was impressed with the quallity and price. I'm now working on my 54 f100 and when it came to wiring there was no choice for me. I will always use Rebel Wire!
Brett
Old 11-29-2011, 04:30 PM   #7
glenn33
Senior Member
glenn33's Avatar
Just got my 9+3 for the Willys Coupe project. Todd is a great guy to deal with...I should know
__________________
www.KROPDUSTERS.com
www.rustrevival.com
"Don't be a Janet"
Old 01-05-2012, 06:34 PM   #8
Givens
Newbie
Givens's Avatar
Thumbs up Re: Milltown Auto Wire
My 6 volt 8 circut showed up today! Only took 4 days to get here. Very nice quality. Fast friendly service the way things should be. Thank you! I would gladly buy from again.
Old 01-05-2012, 06:55 PM   #9
outlaw1949
Got my 9+3 harness in 2 days. thats incredible!!!!! thanks Todd
Old 03-29-2012, 08:16 PM   #10
usmile4
Alliance Member
Rebel wire is the greatest. I've wired 2 cars with the 21 circuit kits and the wire is great quality and easy to use with being labeled on each wire. I just ordered a gauge wiring kit as I thought I would not need it with my second car, but it makes wiring the gauges so easy I just had to order it for this car too. Todd shipped it and I got it in one day. Thanks, Todd.
Old 04-18-2012, 03:48 PM   #11
Kage
Kage's Avatar
Great customer service. and rebel wire is the best.
__________________
"The clutch is on the left. Gas on the right."
"What's this one in the middle?"
"It's for pussies."
Old 07-23-2012, 05:21 PM   #12
Da' Bomb
Alliance Member
Da' Bomb's Avatar
Damn Nice! Excellent customer service too. Thanks Todd
Pat
Old 08-02-2012, 07:00 PM   #13
Gearhead Graphics
Senior Member
Gearhead Graphics's Avatar
Got my setup, looks great. Will be installing it this winter sometime.
__________________
"Will pinstripe for 1 Shot"
http://www.facebook.com/gearheadgraphicspinstriping
Old 10-19-2012, 05:22 AM   #14
chopt55bc
chopt55bc's Avatar
fast service, easy to install, great guy to deal with! what more could you ask for? thanks Todd.
Old 02-28-2013, 03:22 AM   #15
Da' Bomb
Alliance Member
Da' Bomb's Avatar
Hooked me up again....Thanks Todd
Old 04-10-2013, 11:01 PM   #16
happy hoppy
Alliance Member
happy hoppy's Avatar
Great service, fast shipping, keeps in touch with customers.
The labeling on the individual wires is printed BIG and easy to read, not like other kits I have installed. Great instructions.
David
__________________
cut, hammer, weld ,drive.
not necessarily in that order.
http://cuthammerwelddrive.blogspot.com/
PANEL BEATERS C.C - WE GOT GREASE UNDER OUR NAILS, NOT IN OUR HAIR
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
