Reply
Thread Tools Display Modes
Old 08-10-2011, 02:44 AM   #1
23dragster
Grenade Inspector
23dragster's Avatar
Default Shortening Ford 8.8 axle
My T bucket has driveline vibrations. Turns out my rear-end pinion is off-center to the right (3") that it's causing driveshaft harmonics. I forgot about the offset when I built it. I am running an early 90's Ford Explorer 8.8" rear axle. I did some research and found that it "may" be possible to have the "long side" (left) of my axle-tube shortened by 3" and then just use two stock Explorer "short side" axle shafts. This almost sounds too good to be true. Anyone ever done it or seen it done? [/B][/FONT]
P.S. The rear wheels are centered in comparison to the frame rails in my rod... The pumpkin and pinion are both offset in the original Explorer so the drive-shaft would clear the fuel tank. My driveshaft is about 20 inches long; this offset is too much for the u-joints. I am not sure yet if I have 28 or 31 spline axle shafts. I want the pinion centered and don't mind having the pumpkin off-center. I can't afford a Ford 9" axle. Thanks!
Click image for larger version
ID:	1396885   Click image for larger version
__________________
"If everything seems under control you're not going fast enough"
offline   Reply With Quote
Old 08-10-2011, 03:23 AM   #2
Salty
Senior Member
Salty's Avatar
Default Re: Shortening Ford 8.8 axle
Yup totally possible....My pops used to do it on I believe Dana's out of....crap I forgot....an older SUV 4X4 of some sort....unfortunatly I was a kid and dont recall all of the specific details.
__________________
Be professional, kind and courteous to everyone you meet while simutaneously formulating a plan in which to kill them.
See My "Chop Sewage" 1949 Chevy Truck Build Thread HERE
Old 08-10-2011, 03:31 AM   #3
23dragster
Grenade Inspector
23dragster's Avatar
Glad to hear it's been done before.
I just measured the drive shaft and it's 14.5" inches with a current operating angle of 12 degrees. If I shorten one axle tube side by 3" and move the axle over 1.5" it will reduce the operating angle to 6 degrees. I wonder if that would vibrate or not.
__________________
Old 08-10-2011, 07:20 AM   #4
bobscogin
Senior Member
Quote:
I think if you do some research, you'll find that the recommended maximum angle is 4 or less. Not saying 6 won't solve the problem, but if you're doing all that work you may as well get it to within the recommended spec.
Bob
Old 08-10-2011, 07:31 AM   #5
58fed
Is it me or wouldn't you be moving the axle over the full 3" if you're only removing it from one side, in order to center the yoke? Make sure you're overall will fit between the body taking the 3" out of the width of the axle. I know that you could split the difference to the 1.5" to each side but that wouldn't center the yoke.
Old 08-10-2011, 09:34 AM   #6
aaggie
Alliance Member
I have a 2000 8.8" from an Explorer in my '40 Chevy and I think the pinion is only 1.5" offset. You might measure the later rear end and it will be easier to center after cutting 3" off. At least you will have disk brakes and 31 spline axles.
Old 08-10-2011, 10:13 AM   #7
1950ChevySuburban
1950ChevySuburban's Avatar
If you're in Tucson, I have an early '90s Ranger diff I'm not doing anything with.
__________________
My '29 Sedan build thread can be viewed here:
/showthread.php?t=635145
Old 08-10-2011, 11:37 AM   #8
shagg'n
Newbie
shagg'n's Avatar
did 2 short axle deal on my latest creation,worked out perfect...still ways from road test,but otherwise ok.Mine has 3.73/disc from exlplorer.I had people tell me to use c clip eliminators,but with disc's,even if axle breaks,cant really go anywhere,especially on street carGood luck
__________________
If the wagon's rock'n-keep on walkn'!
Old 08-10-2011, 11:57 AM   #9
need louvers ?
Alliance Member
need louvers ?'s Avatar
I have never done this with an 8.8, but it shouildn't be any different than with the 9" and 8" rears and I have done that several times. I'm sure you know that you will have to relocate all of your brackets and such on the axle for suspension and radius rods; right? after cutting them off and welding a second time, I would really recommend taking the housing to a good machine shop or axle shop and having it checked and corrected for straight... You would be suprised how much they warp from the heat of welding brackets.
__________________
HOT ROD CENTRAL LOUVER CO.
602.881.0175
louverguyquinn@yahoo.com
online   Reply With Quote
Old 08-10-2011, 12:47 PM   #10
23dragster
Grenade Inspector
23dragster's Avatar
Thanks for the recommendation Bob; I'm actually planning on turning my panhard bar out just a tad to maybe remove 1 more degree, but that's as far as I can go; giving me 5 degrees u-joint angle, in order to still (theoretically) use stock axle shafts.
58Fed: Well, I guess I mis-wrote that as I "want" my pinion centered, but I don't think I can move it all the way like this. I'm trying to figure if I goofed on the moving 1.5" or the full 3"?
Thanks a bunch for the axle offer 50ChevySuburban, but I'm about 9 hours away, sadly.
Shagg'n: sounds good, I like the positiveness here. =)
Louvers: My brackets aren't a problem, I can re-do those easy enough. Once I cut them all off, I would have it straightened at a local shop (I don't have the machinery for that).
I just talked to a guy that runs a frame shop, and he says he'll do it for $300, but I have to strip the axle housing, including taking the pinion out; which means I'd have to re-set my gears... This guy pushes the tubes out of the diff housing and re-does them. He said there are other guys that will just cut the tube and re-weld it; which means I don't have to remove my pinion shaft, which would save me $, but may not be as strong. Any thoughts on the strength issue if done the cheaper way? Choices choices.
P.S. I'm running approx. 540 hp, but the rod is light and I can't mash the pedal all the way as it'll self destruct or go out of control.
__________________
Old 08-10-2011, 12:48 PM   #11
23dragster
Grenade Inspector
23dragster's Avatar
Oh and 58Fed: You are correct, the right axle will move inboard 3", which means I'll be moving my pinion 1.5". Thanks for checking that.
__________________
Old 08-10-2011, 12:55 PM   #12
55chieftain
Senior Member
55chieftain's Avatar
Removing and reinstalling the pinion and carrier will not change the gears to where they have to be reset, only with a new crush sleeve the rolling torque will need reset. 6-15 in lbs on used bearings, 15-29 in lbs on new pinion bearings. Keep the caps and pinion shims in order and nothing will change. I always kinda glue the shims in first with some thick grease in the housing than install the carrier.
If you spending that kinda money replace the axle ends with 9" big bearing and buy new axles. Recut and splines axles aren't as strong. Also the 31 spline is the same dimensions as a 9". Most van & truck 9" axles from the 70's used a 32 " axle" and cant be shortened less than 4"
Old 08-10-2011, 01:27 PM   #13
Jalopy Joker
Old School HAMBer
so, you can't use another rear axle set up that is the correct width and pinion location?
Old 08-10-2011, 01:28 PM   #14
yule16met
yule16met's Avatar
The explorer axles are all 31 spline, ranger and mustang 8.8s were 27. I have a 8.8 in my car, runs great. Don't push the tubes out, way to much work. Just cut and weld in square. The 8.8 axle shafts are stronger than Dana 60 axles. Check out a jeep forum about them. The 8.8 explorer axle is a perfect fit in a wrangler and they make tons of aftermarket stuff for them now. If u get one from after 1995 they are disk and possibly posi.
Old 08-10-2011, 02:31 PM   #15
Safari-Tracker
FNG
Safari-Tracker's Avatar
I cut one down for my 64 falcon, I can say it was easy. I got a short side axle cut 3" off the long side put new spring perchs on and its been under my car now for two years no problems.
Old 08-10-2011, 03:01 PM   #16
55chieftain
Senior Member
Wouldn't it be easier and cheaper if possible to move the engine over? I have a 91-94 8.8 explorer in my 55 and don't have any driveline vibrations because of angle. Both my pinion and trans angles are equal and the side offset doesn't affect mine any.
Old 08-10-2011, 04:25 PM   #17
bobscogin
Senior Member
Quote:
Do the math. His driveshaft is 20" long. I'd think your's is quite a bit longer, thus reducing the angle.
Bob
Old 08-10-2011, 04:41 PM   #18
Atwater Mike
Old School HAMBer
"Two short axles". I recall this trick. Some customers of mine in the '70s had some Galaxie rears they wanted to narrow "the easy way".
One shortened the housing's long side and the short axle slid right in...he had a 460" with a 1/2" crank, DOVE heads, Crane, Edelbrock, etc. in a '56 Ford Vic.
I told him to watch out, those axles had a 'set', and would 'unwind'. He said, "Oh yeah, right."
He peeled off the axle in a week. (on the street) Another axle, another unscrewed spline. He and his bud then ordered axles from Summers Bros. ( $200, when Summers Bros. still had the shop)
My illustrious brother peeled BOTH axles in his roadster pickup's Olds rear. (he switched them left for right, then had oil leaking from the axle seals. Removed the axles and the splines were twisted 3 splines, in the splined pattern. This made the side gears push the axles outward, bending the outer bearing plates.
Stubborn brother insisted the splines were machined like that. "You can see it!" Hmmph.
__________________
Mike in Atwater
Old 08-11-2011, 01:17 AM   #19
23dragster
Grenade Inspector
23dragster's Avatar
Thanks 55Chief, I can do preload as I've done it before lots of times; I just haven't set backlash in a long while.
Jalopy Joker: Yes, I could, but I already rebuilt my brakes, I like my gear ratio and posi, the width is good, and this axle is strong enough (so far), so I limited myself to a Ford 9" or keep this 8.8. If there are other choices, that might work out too, but I don't know of any yet. If you do, I'd be up for more knowledge. =)
Yule: The expensive shop-guy that would redo the axle-tube for me was going to push them out of the housing. He said others would do it cheaper than him if not his way, but he recommended doing it his way; he said it was a bunch stronger. I'm leaning toward just having a different shop do it and have them weld square like you suggested; then I don't have to strip my gears. If it's strong enough the "cheaper" way, it would save me a lot of time setting up my gears.
Safari: Sounds good.
55Chief: I would move my motor, but I can't as my headers already hit my tie rod when I turn, plus, my frame doesn't allow that movement in the rear (my steering box is .75" from trans). I think yours works well because your driveshaft is longer; mine turned out to be 14.5" from joint to joint, around 20" total.
Right on Mike. I had that thought last night too, about stock axles having the forward rotational force make them only useable in one direction. At least I can order new shafts from Moser/Strange/Currie or some other axle-shaft place when it's finished.
Thanks so much again guys; this really helps me out.
So I'm thinking about just having a tube cut on the outside of the diff, shortened, squared up, and welded back up; instead of pushing a tube out. I woudl still be using C-clips and the original axle bearings so I can still use my brakes. Anyone know if doing it that way is "weak". and by weak I mean not able to handle 450hp with an occasional "punch" of the go pedal.
The pic is old, but it's still the same axle.
__________________
Old 08-11-2011, 11:52 AM   #20
Kenneth S
Senior Member
Kenneth S's Avatar
If you were close to San Antonio Texas, I have a friend that has the jigs to shorten any just about rearend. He cuts the ends off, cuts a section out, then re-welds it, and never had any problems (even on 10 second drag cars).
__________________
Ford 2.3L Lima engine guide.
http://www.jalopyjournal.com/forum/s...36#post3389436
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
