Reply
Thread Tools Display Modes
Old 08-07-2011, 09:58 PM   #1
noclubjoe
noclubjoe's Avatar
Default alternator help....car wont shut off
so the volt gauge in my model a has been acting funny the last week or so, jumping around alot between 14-16 volts.... ok no problem ill just rebulid the alternator... fast foward to today. I take apart the alternator (stock chrome GM style internal reg.) to find the diode trio is burned up, Great! i install the new voltage regulator, diode trio, brushes, ohm the stator, clean up the commutator where the brushes ride, new bearings etc.... put her all together, runs good charging just over 14. Cool! go to shut it off..... still runs... ? i know about putting a diode in with the exciter wire to keep from feed back to the ign switch. ( had to do this on my OT Nova) my question is why now? i put this car together 6 years ago and never had this problem before? why with a rebulit alternator does this problem start? or could it be in the ing switch and it just shit today? what do you guys think?
offline   Reply With Quote
Old 08-07-2011, 10:09 PM   #2
rustyangels
Grenade Inspector
rustyangels's Avatar
Default Re: alternator help....car wont shut off
Are you running an MSD box?
Old 08-07-2011, 10:11 PM   #3
markjenks
Grenade Inspector
markjenks's Avatar
I'm guessing that the old regulator in the alt didn't need the diode and the new ones does. 5 mins fix after a trip to radio shack.
__________________
(2)1940 Pontiac Deluxe Six
1953 Chevy 210
1966 Harley FLH
1972 Pontiac Lemans
Old 08-07-2011, 10:14 PM   #4
noclubjoe
noclubjoe's Avatar
Quote:
no stock points ing system, i know what you mean about the MSD box, i run a digtal 6 box in my Nova and it did the same thing to me after i installed it. that i could understand because the car had never ran with a msd system before.
Old 08-07-2011, 10:18 PM   #5
noclubjoe
noclubjoe's Avatar
oh by the way guys i forgot to add in my first post.... after the car not shutting down with the chrome alternator that i was in, i put on a stock GM alternator that i had laying around just to try it...... same shit wont shut down....? Mark i see what your saying about the new regulator not needing the diode, but with 2 different alternators and still the same problem?
Old 08-07-2011, 10:22 PM   #6
rustyangels
Grenade Inspector
Any other hot wires feeding off the positive+ terminal on the coil?
Old 08-07-2011, 10:35 PM   #7
wildearp
wildearp's Avatar
If you have an accessory side on your ignition switch, if you tie the exciter to that side and the ignition to the ignition side, they will separate when power is off and you won't need a diode.
__________________
Simple solutions to complex problems.
Old 08-07-2011, 10:35 PM   #8
Weasel
Old School HAMBer
Weasel's Avatar
There is a little known condition with GM alternators where they are prone to backfeeding despite all electrics being switched off - cost me a lot of money finding this out the hard way. Painless Wiring has a kit for around $85.00 to eliminate this problem....
__________________
Procrastinate NOW!
Old 08-07-2011, 10:49 PM   #9
ironpile
ironpile's Avatar
Alt and ign hooked to same hot wire
__________________
Retirement: Nothing to do and plenty of time to do it.
Old 08-08-2011, 09:35 AM   #10
noclubjoe
noclubjoe's Avatar
thanks for the info guys, iam sure i will get this taken care of later today when i get out of work, my question is still why has this car been fine and shut off for the last 6 yrs? only when i changed the parts in the alt. with new parts has this problem came up? i dont have a problem doing any of the above to slove it...it just really seems odd that it has been fine up untill now?
Old 08-08-2011, 09:48 AM   #11
porknbeaner
Alliance Member
porknbeaner's Avatar
Quote:
All power to your dizzy should go through the ignition switch with the exception of the hot start wire that comes from your starter solenoid. You should not be getting any hot directly from the alternator to the ignition. if you are you have it wired wrong.
First thing I would try is this; if you have a hot start wire from the solenoid to the coil, shut the switch off and then pull the hot start wire from the solenoid. If that kills it I would suspect the starter solenoid. If it still doesn't shut off I would suspect the ignition switch.
__________________
If it don't make ya dirty it ain't yours
No man crosses a chasm in two jumps
Old 08-08-2011, 10:22 AM   #12
26 roadster
Senior Member
26 roadster's Avatar
I think any electrical part that has small colored parts in it is FM, (FREEK'IN MAGIC) and I don't argue with it, put in the diode!
Lights will go bad setting on the shelf I have found
fuses that LOOK good, are not
the list goes on.............................
__________________
your old when everything reminds you of a story,,,I have a lot of stories
Old 08-08-2011, 11:23 AM   #13
noclubjoe
noclubjoe's Avatar
Guys i think everyone is missing my question......... i dont have a problem putting in the diode if thats what needs to be done, what i want to know is why does it need it now? this car has been shutting off with the key for 6 years with out a diode in the wire!
Old 08-08-2011, 12:34 PM   #14
George/Maine
George/Maine's Avatar
If you have a regulator and has I wire thats goes to IGN switch,my guess its the reg thats at fault.
Old 08-08-2011, 01:09 PM   #15
ironpile
ironpile's Avatar
I Remember now,one of the bolts in the diode trio is the wrong one and is grounding it full time,ck the bolts and you should be fit to go. All three should have a plastic washer on them.
__________________
Old 08-08-2011, 03:35 PM   #16
noclubjoe
noclubjoe's Avatar
Quote:
ok thanks this was the kind of answer i was looking for, when i took it apart only 2 had the plastic washer around them, so i put it back together that way........ maybe this is the reason that the old diode trio was burnt to a crisp, and the volt gauge was jumping around all over the place....??? iam going to take the alternator back apart and double check everything... thanks guys!
Old 08-23-2011, 11:12 AM   #17
snowmann
Newbie
snowmann's Avatar
I have the exact same problem, when my chromey alt went out, got to go to radio shack to get a diode. Anyone have a part #? My local radio shack is lacking a little knowledge in that department. Thanks.
Old 08-23-2011, 11:49 AM   #18
jackandeuces
jackandeuces's Avatar
Broad question without knowing how the alternator is wired ....
__________________
Home of Dirt Cheap HotRods ... Fuller's Frame and Axle....Louvers
Old 08-23-2011, 12:22 PM   #19
noclubjoe
noclubjoe's Avatar
Quote:
doesnt matter any more the problem is fixed
Old 08-23-2011, 12:34 PM   #20
jackandeuces
What was the fix...
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
