Reply
Thread Tools Display Modes
Old 07-15-2011, 05:33 PM   #1
mkrog1
FNG
Default Help!! brake line adapter needed
I need a brake line adapter to install my brake light switch.The switch is the old style that is installed in the master cylinder and I need a adapter to go from pipe thread to flair fitting,female 1/8in npt to male 3/8 flair.I have looked every place I can think of but no luck.
I would like to put the switch in the proportional valve but if any body has any other ideas I'm open to any thing that will work and look clean
offline   Reply With Quote
Old 07-15-2011, 05:38 PM   #2
RICH B
Alliance Member
Default Re: Help!! brake line adapter needed
Speedway has a switch that is male 3/8" flare,
Item #:91031303. I'm sure other vendors sell it also.
Old 07-15-2011, 05:41 PM   #3
F&J
Old School HAMBer
What the heck kind of brake light switch needs that? Or are you remote mounting the switch with tubing?
I have some NOS fittings from my Dads shop in the 1950s, But I think they would be male 1/8 to male flare
Old 07-15-2011, 05:43 PM   #4
53sled
Old School HAMBer
53sled's Avatar
pipe plug and a $10 lever switch, you'd be driving already. the port in the proportioning valve isn't for a brake light switch, is it? I thought that was for the warning light?
__________________
If only the good die young. I'll be here when you're gone.
Old 07-15-2011, 05:58 PM   #5
Royalshifter
Moderator
Royalshifter's Avatar
Napa?
__________________
"I LIKE KUSTOMS"
Old 07-15-2011, 06:35 PM   #6
Fenders
Old School HAMBer
Fenders's Avatar
Or if you don't want the lever type use the button type...
http://www.google.com/products/catal...ed=0CEcQ8gIwBA#
Just weld a bracket so the brake pedal holds it normally open (pushed in).
__________________
It don't squeak? It don't rattle?
Must be a street rod.....
Old 07-15-2011, 08:25 PM   #7
tommyd
Alliance Member
tommyd's Avatar
Won't work in the proportioning valve. I have my switch in a brass block that I think I got at NAPA. It has 3/16 fitting thread on each end and 1/8 pipe thread on top for the switch. If nothing else get a block that has three or four 1/8 pipe thread in it and add the flare fittings you need.
__________________
When I grow up, to beeee heee a man. Will I dig the same things that turned me on as a kid? Will I look back and say, I wish I hadn't done what I did? B. Wilson.
Old 07-15-2011, 08:34 PM   #8
Engine man
Senior Member
Try a trailer dealer. They used to have fittings to connect brake controls to the master cylinder.
Old 07-15-2011, 08:39 PM   #9
62rebel
Senior Member
62rebel's Avatar
truthfully, i'd never plumb in a switch into the brake lines unless it was the only way to go. it creates another potential fluid leak and line failure point. go with a mechanical switch.
__________________
i hate to see her leave, but i love to watch her GO....
Old 07-15-2011, 08:47 PM   #10
old me
Grenade Inspector
Like Rich said, Speedway has one with the flare.
Did a dual reservoir master cylinder change over on my 63 'bird where the original switch is mounted to the master cylinder, and used the Speedway brake light switch. Used a "T" off the new master cylinder and hooked brake line to one side, switch on other side.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
