Reply
Thread Tools Display Modes
Old 05-08-2011, 07:28 PM   #1
dallasdrifter
Newbie
dallasdrifter's Avatar
Default solder or replace brake line?
I searched on here and couldn't find a clear answer about pinched brake lines(hardline). So I thought I would see if anyone has an answer to my problem. I was dicking around with some hosing I was removing from the fenderwell. one thing led to another due to bad lighting, and I ended up pinching a hole in my line by the coil. Can I solder it or flux weld it? or do you advise replacing the line? do the replacement lines come flared? this is on an all drum falcon if that helps. thanks, ray
__________________
"You have to swallow alot of shit in life. The trick is to avoid the big chunks." - Morris Bishop
offline   Reply With Quote
Old 05-08-2011, 07:29 PM   #2
30roadster
Senior Member
30roadster's Avatar
Default Re: solder or replace brake line?
Do it right... replace line.
__________________
I'm a 6 volt guy in a 12 volt world.
Old 05-08-2011, 07:31 PM   #3
Koz
Senior Member
Definitly a replacement! AutoZone, Napa, etc. have brake lines dirt cheap. It just ain't worth it. Pull the line and measure it to get the closest length. I highly reommend the epoxy coated lines. They form beautifly by hand and last longer than a Falcon.
My 2 Cents.
Old 05-08-2011, 07:32 PM   #4
scottybaccus
Old School HAMBer
scottybaccus's Avatar
normal brake pressure can exceed 1200 psi. Do you have really trick solder?
__________________
Shooting down dumb asses one S-10 frame swap at a time...
Tejas Malcontents, Hutto
online   Reply With Quote
Old 05-08-2011, 07:32 PM   #5
Lobucrod
Alliance Member
Lobucrod's Avatar
Replace!!
__________________
Makin it Git with Old Shit
Old 05-08-2011, 07:33 PM   #6
hotrod_32
hotrod_32's Avatar
only one thing to do...replace !
Old 05-08-2011, 07:33 PM   #7
gimpyshotrods
Old School HAMBer
gimpyshotrods's Avatar
Replace. When in ANY doubt, always replace.
You can buy pre-flared lines in numerous lengths, or buy a double-flaring too and DIY.
__________________
Ala Kart had air bags in 1957. Traditional? Yes!
Old 05-08-2011, 07:34 PM   #8
4t6ford
Senior Member
4t6ford's Avatar
Location: Little town with a heart of Gold n Balls of Steel! New Zealand
Replace it ! IF it was a band spanking new line (I'm assuming it wasn't) you had damaged then you would possibly ok to cut the damage out and flare each end / fit a union . I don't recommend you do this with an old line . Bundy tube/fittings are cheap compared to some of the consequences of not doing this job the right way .
__________________
Redneck Speed Shop
Waihi
New Zealand
Frightening little old ladies since 1970
Old 05-08-2011, 07:35 PM   #9
FuelRoadster
Senior Member
FuelRoadster's Avatar
Soldering or welding up of a brake line is a no no,,I mean NO NO.
NAPA or any other reputable auto parts houses have brake line in various lengths,already flared.
Take your old 'coil' off,,un-roll in to straight as possible,,measure it,,go to parts house.
Get a new stick of line that's a little bit longer & make a new 'coil',,install,,bleed brakes,,drive.
Safety first here on the HAMB!
__________________
"That's a cute dune buggy"
Old 05-08-2011, 07:37 PM   #10
TagMan
Alliance Member
TagMan's Avatar
Soldering a brake line = death wish !
__________________
"The problem with Liberalism is that eventually you run out of other people's money" -Margaret Thatcher
Old 05-08-2011, 07:42 PM   #11
Ebbsspeed
Alliance Member
Ebbsspeed's Avatar
Solder is for wiring and radiators, not brake lines. Another strong recommendation to replace from here in Kansas.
Old 05-08-2011, 07:45 PM   #12
dallasdrifter
Newbie
alright. I see a whole hearted agreement on replacing the line. Thanks for the advice. I will take off the line tomorrow. I see that oreilly sells the length i need for 25 bucks.
__________________
Old 05-08-2011, 07:47 PM   #13
clockwork31
clockwork31's Avatar
brakes and steering, two things that needs to be "like new" all the time, REPLACE the line. Better be safe than sorry !
__________________
Reach for the sky cause tomorrow may never come.
Old 05-08-2011, 09:42 PM   #14
Rich Rogers
Senior Member
The amount of pressure that can be put through a brake line and to solder it?? is Russian Roulette. It would be only a matter of time. Replace it without even thinking about it
Old 05-08-2011, 09:46 PM   #15
31Vicky with a hemi
Alliance Member
31Vicky with a hemi's Avatar
Of course you need to replace it
unless it has great sentimental value or something JK
__________________
Thank you, I will be installing a breathalyzer on my keyboard
the hamb relay network
http://www.jalopyjournal.com/forum/g...hp?groupid=214
Old 05-08-2011, 10:48 PM   #16
flamedcoupe
Grenade Inspector
flamedcoupe's Avatar
The parts store has the line you need for 25.00? Look for a new parts store. Steel line is cheap.
__________________
If it had a set of wings, man I know she could fly...
Old 05-08-2011, 10:55 PM   #17
Johnny Gee
Old School HAMBer
Johnny Gee's Avatar
Location: 2.7 miles East of the Broiler on SR42 Downey, Ca
SOLDER !!!!!!!!!!!!!!!
__________________
Mussels with French Fries and Mayonaise
Old 05-08-2011, 11:13 PM   #18
roundvalley
Senior Member
roundvalley's Avatar
You must really be good if you can solder or weld up a brake line!
Replace it and don't become a organ donor.
Old 05-08-2011, 11:16 PM   #19
need louvers ?
Alliance Member
need louvers ?'s Avatar
Quote:
I second this! I just picked up a 60" length of 5/16" line for the girlfriends car and it was 8.00 and some change... Thought that was a bit dear! All the lines on the brakes on a Falcon are 3/16" ad should be about that price or less.
__________________
HOT ROD CENTRAL LOUVER CO.
602.881.0175
louverguyquinn@yahoo.com
Old 05-08-2011, 11:35 PM   #20
DocsMachine
Grenade Inspector
DocsMachine's Avatar
Aw, go ahead and solder it! I did that once, and I only died a little bit when I overran that corner and hit the busload of nuns. Heck, the car wasn't even that badly damaged- all we had to do was replace everything forward of the rear axle, plus a hipbone and a handful of teeth. And most of the nuns.
Doc.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
